Old 03-19-2011, 05:30 PM   #1
JBRAVO383
JBRAVO383's Avatar
traction bar set up ?s
I have an 85 c10. I went from a 30x12.50 to a 28x10.50 tire and also a different offset wheel. I am going to do a spring under set up to lower the rear of my truck another 4-5 inches. These are the traction bars i have now:
Will these still work with a spring under set up?
IF not, Whats should a use?
JBRAVO383 is offline   Reply With Quote
Old 03-19-2011, 07:17 PM   #2
mooseknuckles
mooseknuckles's Avatar
Re: traction bar set up ?s
they should....might be alot closer to the ground tho...you could allways cut a couple inches out of the mounts and weld them back up.
mooseknuckles is offline   Reply With Quote
Old 03-19-2011, 07:20 PM   #3
mooseknuckles
like this
Old 03-19-2011, 08:40 PM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
Cal tracs Work!
Old 03-20-2011, 07:46 PM   #5
JBRAVO383
JBRAVO383's Avatar
Okay thank you. How much was that cal trac set up?
Old 03-20-2011, 07:51 PM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
http://calvertracing.com/cart/index....products_id=29
And i believe a board vendor may carry them also.
I can say my 73 hooks hard enough to spin the wheel inside the tire.
Old 03-20-2011, 08:31 PM   #7
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I have custom made tracion bars. The front stopper is on the leaf not the mounting point.
Mine are also nice and tucked up on the leafs.
The design has a large U directly under the axel tube. The tube actually "hooks" by hitting the U. The U cradles the axel. I need to retake some pictures and post them.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 03-20-2011, 10:44 PM   #8
bigblockrock
bigblockrock's Avatar
x2 on the caltrac setup. My brothers truck hooks real hard with them. I believe lakewood also makes traction bars for our trucks with axles on top of the springs.
bigblockrock is offline   Reply With Quote
Old 03-20-2011, 11:32 PM   #9
3r!c84
Badass
3r!c84's Avatar
man you could make a set of caltacs they look simple!
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 03-22-2011, 06:30 PM   #10
JBRAVO383
JBRAVO383's Avatar
They do look pretty simple to make, does anyone have any more pictures of there set up?
Old 03-22-2011, 09:08 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Forum Vendor Capt Kaos is a dealer for Cal-Tracs. Get with him for a good price and great service.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-22-2011, 09:35 PM   #12
my4by2
my4by2's Avatar
Here's the set-up I am running. First pic is them on another truck just because it's finished & mine isn't. The kit is from WFO Concepts - they are the shop building my truck. Mine is a 4x4, but they'd work as well on a 2WD version. Very nice set-up if you can do your own welding or know someone who can. Just a thought for you to consider.
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 03-23-2011, 02:55 AM   #13
JBRAVO383
JBRAVO383's Avatar
That looks real good my4by2
Old 03-23-2011, 03:03 AM   #14
Altec
Getcha Pull
Altec's Avatar
Ditto. That looks clean! I dig how the upper link is adjustable.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 03-23-2011, 03:24 AM   #15
my4by2
my4by2's Avatar
Yeah, I really liked the way it's built & the built-in adjustability. I had a set of CalTracs on my '07 Dodge Ram & they were pretty good as well. Think these are much better though in how they are built & designed - they're also a lot more unique. You can find these at: http://www.wfoconcepts.com/cr/Torque-Arms/4140/3857 if you're interested - or just call Trevor at the shop.
Old 03-23-2011, 10:05 AM   #16
hotrodbones
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
hotrodbones is offline   Reply With Quote
Old 03-23-2011, 10:16 AM   #17
my4by2
my4by2's Avatar
Uh-oh, think I see the flashing blue lights of the "thread police" coming up behind you.... CalTrac bars are pretty nice though - made my Ram 3500 ride & hook up much better overall.
Old 03-24-2011, 01:44 AM   #18
JBRAVO383
JBRAVO383's Avatar
Yeah apparently! But yeah i like the look of that set up.. and it also looks like it would be pretty easy to build my own. I will be looking into that some more.
My neighbor just gave me the Ford 9" out of his 78 bronco, so now I'm trying to figure out what its going to take to put that in my truck and How much a gear set and Detroit is going to run me.
Old 03-24-2011, 08:01 AM   #19
BigBlocksRule
Cal-Tracs are the cat's a$$. Ride great on the street, easy to adjust. They're made for conventional or axle/spring flip, too.
BigBlocksRule is offline   Reply With Quote
Old 03-25-2011, 10:21 AM   #20
JBRAVO383
JBRAVO383's Avatar
Does anyone know anything about these ?
http://www.ballisticfabrication.com/...it_p_1822.html
Thanks,
John
85' c10 swb 383 th400 ran:
13.26 @ 99 w/ a 1.8 60'
