Old 03-25-2011, 02:04 PM   #26
Re: 383 Stroker Vs. 454 Big Block
I have one of Marks motors, the only big block I would own, in fact I do own one.
http://www.vortecproperformance.com/...binations.html
a goofy little clip of my 5,500 lb truck
Old 03-25-2011, 02:19 PM   #27
pockets
pockets's Avatar
Originally Posted by jrcaprai View Post
What Cam do you have in that 383 ?
http://www.summitracing.com/parts/CCA-CL12-246-3/
Project Bad Karma
pockets is offline   Reply With Quote
Old 03-25-2011, 02:44 PM   #28
parrisc19844x4_468
parrisc19844x4_468's Avatar
Originally Posted by Project77 View Post
i was wondering what would be best for my truck which one is faster and has more get up and go and what kind of transmission and carberator would go best with the engine that meets my needs. i know im thinking a little ahead of my ball game but for future plans id like to start finding this stuff out sooner rather than later. and before i put a motor in the truck i will upgrade everything else such as: Tires, rims, brakes so i can make sure i have maximum performance )))
current truck information:
77 chevy silverado
regular 350 engine
regular 350 tranny
tire rims and brakes they all suck but ill fix it
just let me know what you would go with and why
I was in your position last year and went the BB. and was glad I did. I based my decision on the weight of my truck and went for torque vs HP.
2017 Silverado LTZ 6.2
1984 Scottsdale K10 - 468 700r 4x4 lwb
1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb
1968 GMC 20 305 V6 good ole wood hauler.
Good Fences make good neighbors
parrisc19844x4_468 is offline   Reply With Quote
Old 03-25-2011, 02:52 PM   #29
justinburnett
justinburnett's Avatar
Couldn't say why it was more, just was. Rebuild kit from northern auto was about double the price, flexplate was about 30% more, had to pay shipping for some parts I had to special order cause no one out here has anything that is 400 specific. I'm maybe not double, since the head work would have been the same, but overall I'm a lot more into it than a 350. Less than a 383 though, I'm sure.
justinburnett is offline   Reply With Quote
Old 03-25-2011, 03:11 PM   #30
fun in dirt
fun in dirt's Avatar
x2 these are great motors...quality & price wise.
Put a 475 big block from him in a '67 Chevelle last year & it runs great!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 03-25-2011, 03:14 PM   #31
raisethedead
raisethedead's Avatar
What machine work needs to be done to a 350 block to get it ready for a 383 larger stroke crank? What other parts need to be changed for the conversion?
raisethedead is offline   Reply With Quote
Old 03-25-2011, 06:28 PM   #32
jrcaprai
Originally Posted by pockets View Post
Great Cams... I had the XE284 in my 383...
jrcaprai is offline   Reply With Quote
Old 03-25-2011, 07:03 PM   #33
69GMC910
MOTORHEAD!
69GMC910's Avatar
If you are looking for serious power, always go big block. If you are planning 80% street use and 20% at the track, BUILD A SMALL BLOCK!!
Personally, I'll never build another small block...
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 03-25-2011, 07:27 PM   #34
jrcaprai
What are the specs of your Big block
Old 03-25-2011, 08:06 PM   #35
royo
royo's Avatar
Why stroker? Have you ever driven a fresh 350? You need to try it with vortex heads . What are your plans for the truck? What do you already have there as far as parts for the engines?. Have you ever driven a fresh 400sbc?
check this place for Chevy stuff enginekits.com
nickle and dime
royo is offline   Reply With Quote
Old 03-25-2011, 08:31 PM   #36
jrcaprai
Originally Posted by royo View Post
Why stroker? Have you ever driven a fresh 350? You need to try it with vortex heads . What are your plans for the truck? What do you already have there as far as parts for the engines?. Have you evheer driven a fresh 400sbc?
a 383 will give you about 50 more ft-lbs of torque than a 350, and 25 more HP than a 350...
A fresh 180 HP 350 is still a 180 HP 350.... there are much better heads than Vortech heads these days....
Old 03-26-2011, 11:03 PM   #37
Project77
i want a motor for the streets something that will haul azz. beat everyone on the street and not have any problems. something to make me sink in my seat something that is perfect for speed
Project77 is offline   Reply With Quote
Old 03-26-2011, 11:10 PM   #38
my4by2
my4by2's Avatar
What's your actual engine build budget? And don't forget - if you build a hot street motor, you're also gonna need to at least do a shift kit & better torque converter in your transmission to compliment it!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 03-26-2011, 11:16 PM   #39
BigBlocksRule
Beat everything on the street? Hope you have pockets full of money 'cause that's what it's going to take, especially in a truck. There are N/A Camaros and TransAms out there running high 9's, that'll take somewhere around 900hp to get that done with a truck.
Start with a strong 383 and work your way up from there. Build something that's reliable and affordable and fun, worry about beating everyone on the street later, once you've got some wrenching and tuning under your belt.
BigBlocksRule is offline   Reply With Quote
Old 03-26-2011, 11:19 PM   #40
my4by2
my4by2's Avatar
And "beating everyone on the street" is going to require being able to hook that power up without endlessly spinning your tires too!!! But realistically, you are pretty much NEVER going to run into someone with 900hp driving on the street.....
Old 03-26-2011, 11:24 PM   #41
Project77
i want something to make everyone jealous and in my town i have alot of people who say someone in their family has something better then everyone elses so i want to get my truck beefed up better than what they got and then some and line em up! just to prove them wrong and to tell them i built that and when im older i can look back and remember their faces
Old 03-26-2011, 11:26 PM   #42
85Bowtie
85Bowtie's Avatar
You're never going to beat everyone on the street. If you want to beat everyone, then build a race purpose vehicle and go to the track and win some money to pay for all the things it's going to take to pursue this dream of yours.
9 sec N/A Trans Ams and Camaros? I've never seen one, but I've heard unicorns exist.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
Old 03-26-2011, 11:30 PM   #43
Project77
how bout this i want something that could hit high 10's at the track or somewhere in that region
Old 03-26-2011, 11:31 PM   #44
BigBlocksRule
There's ALWAYS someone faster on the street. Count on it.
Lighter cars don't need 900hp, plus with a good suspension setup, they'll hook while you're spinning. You're not going to get anywhere close with a small block, probably not even with a big block.
How fast of a car have you ever driven? To be perfectly honest, most guys mess their pants at around the 11 second mark, that'll push your eyeballs back in your skull and make you pinch a hole in your seat! And with a 4000lbs truck, that'll take about 600rwhp...again, you ain't gonna get there with any kind of streetable engine, that's 750 at the crank which is a horsey 496 that'll take race fuel and won't want to idle below about 1200rpm.
And there are plenty of 11-second cars on the street, they're all a lot lighter than your truck which makes it a whole lot cheaper and easier than it will be for you.
Get into the 12's first. Baby steps, man, baby steps.
Old 03-26-2011, 11:35 PM   #45
my4by2
my4by2's Avatar
Let me put it to you this way - in my '07 Dodge Ram 2WD CCSB that had the 5.9L Cummins & G56 manual (with numerous mods) I was putting a tad over 425hp & 863ft/lbs to the ground. I had a set of CalTrac bars on it & wider than stock tires - launching it at about 3,200rpm on 3rd I could walk away from a lot of vehicles on the street - especially the obnoxious little imports!!!
Your truck when finished will be a LOT lighter than this one was, so you won't need near that much power. You can VERY easily get 450hp at the crank out of a 383 & it'll feel VERY fast!!! It'll throw you back in the seat too!!!
Old 03-26-2011, 11:35 PM   #46
85Bowtie
85Bowtie's Avatar
Then why are you messing with a truck? Find a Vega, Monza, Duster etc and build it up. You'll get alot farther with less money invested.
Old 03-26-2011, 11:36 PM   #47
Project77
im talking old truck on old truck yea everyone around here understands their aint no old truck gonna keep up with a new lightweight car but if i can at least keep up or go really fast everyone is impressed basically all they are looking for is a truck that will haul ass when the light turns green
Old 03-26-2011, 11:38 PM   #48
Project77
i want a challenge, everyone wants a car because they are lighter and faster than a heavy truck but i want to show everyone trucks can go fast too
Old 03-26-2011, 11:38 PM   #49
my4by2
my4by2's Avatar
Agreed, think you're shooting WAY too far ahead trying to aim for a 10-second pickup off the bat.... That's a lot of investment to get it there & not something that's gonna drive nice on the street without EFI to let it idle ok. A true 10-second car isn't gonna be one that's gonna be your daily driver - you're gonna have to compromise to have something you're happy with daily, but is still respectable at the track or on the street "stop light-to-stop light".
Old 03-26-2011, 11:39 PM   #50
85Bowtie
85Bowtie's Avatar
So then you're on a mission to blow 1000's of dollars on something just to prove a point to people who already know you can make anything fast with enough money and don't really care about your opinion anyway? Awesome...
