Old 03-06-2011, 09:44 PM   #1
ppbr2001
ppbr2001's Avatar
New Carb
Just swapped the quadrajet for an Edelbrock 600 performer. Runs great after hitting the throttle but sure idles rough. I hooks a vacuum gauge to it and set the idle mixture at high vacuum but still sounds like it has a race cam in it!!
ppbr2001 is offline   Reply With Quote
Old 03-06-2011, 09:51 PM   #2
3r!c84
Badass
3r!c84's Avatar
Re: New Carb
did you mess with the air-fuel mixture screw?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 03-06-2011, 11:30 PM   #3
geezer#99
geezer#99's Avatar
Re: New Carb
Vacuum leak!!! What kind of adaptor did you use?
geezer#99 is online now   Reply With Quote
Old 03-07-2011, 03:44 AM   #4
ppbr2001
ppbr2001's Avatar
Re: New Carb
Used an edelbrock 4 hole quad to square bore adapter.
Old 03-07-2011, 03:45 AM   #5
ppbr2001
ppbr2001's Avatar
Re: New Carb
Where's the air-fuel mixture screw?
Old 03-07-2011, 03:31 PM   #6
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: New Carb
it only has 2 screws 1 is air 1 is fuel I believe
John
1999 Toyota Tacoma 4x4
Old 03-07-2011, 08:53 PM   #7
ppbr2001
ppbr2001's Avatar
Re: New Carb
Could it be the float level? I took the vacuum plug off to hook the gauge up and it idled smoother.
Old 03-07-2011, 10:19 PM   #8
SeanPaintsFlames
SeanPaintsFlames's Avatar
Re: New Carb
The two screws are left bank-right bank. They need to be even. I would say turn them all the way in, then unscrew them 6 half turns each.
My 68 cougar restomod build:HERE
SeanPaintsFlames is offline   Reply With Quote
Old 03-09-2011, 01:21 AM   #9
ppbr2001
ppbr2001's Avatar
Re: New Carb
Can't find any vacuum leaks. maybe it ain't supposed to idle smooth!
Old 03-09-2011, 03:34 AM   #10
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: New Carb
If you have a vacuum leak, the gauge would tell you. Is the needle steady or moving? What are the RPMs at idle? Which tranny are you running? A 700R4 should have the angle correction bracket installed.
http://www.centuryperformance.com/tu...e-spg-148.html
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 03-12-2011, 03:34 PM   #11
ppbr2001
ppbr2001's Avatar
Re: New Carb
it has the 700r4 bracket. vacuum gauge is a little jumpy. sprayed ether around fittings and no reaction.
Did readjust float level and helped a little.
Old 03-13-2011, 10:38 PM   #12
rayfinseats
Re: New Carb
GO TO Edelbrock.com. They have a bunch of tuning videos for their carbs. Very informative.
http://www.edelbrock.com/automotive_...ech_vids.shtml
rayfinseats is offline   Reply With Quote
Old 03-14-2011, 11:46 AM   #13
sixshooter798
Desert Rat
sixshooter798's Avatar
Re: New Carb
Originally Posted by seanpaintsflames View Post
the two screws are left bank-right bank. They need to be even. I would say turn them all the way in, then unscrew them 6 half turns each.
+1
sixshooter798 is offline   Reply With Quote
Old 03-17-2011, 04:51 PM   #14
ppbr2001
ppbr2001's Avatar
Re: New Carb
Anybody ever drill holes in the primary butterfies?
Old 03-17-2011, 08:41 PM   #15
Goldfinger
Goldfinger's Avatar
Re: New Carb
How did you install the egr? mine was sucking air through the manifold and it ran super high and rough. If you need a block off for the egr take the spacer on the egr fill with jb weld bake at 400 for 30m and place gasket sealer on it
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ]
1999 k3500 crew cab dually 6.5tdi/4l80e
Goldfinger is offline   Reply With Quote
Old 03-18-2011, 03:34 PM   #16
ppbr2001
ppbr2001's Avatar
Re: New Carb
Will do. Thanx!!
Old 03-26-2011, 02:49 AM   #17
ppbr2001
ppbr2001's Avatar
Re: New Carb
Just blocked off the EGR valve and it idle as smooth as the top of my head!! Thanks for all the advice!!
Old 03-26-2011, 02:57 PM   #18
gchemist
gchemist's Avatar
Re: New Carb
Yea, I run mine without the EGR valve!!
Old 03-26-2011, 05:30 PM   #19
oldblue1968chevy
Re: New Carb
Whats the EGR tube lol
John
Old 03-30-2011, 11:53 AM   #20
Goldfinger
Goldfinger's Avatar
Re: New Carb
Glad it worked for you. The egr is just an obstruction anyway.
