Old 03-31-2011, 09:56 AM   #1
gcburdic
Restoration Virgin!
gcburdic's Avatar
Interesting Tag
I'm sure others have seen this too, but I was cleaning up the spindles for the 71 super project and found this metal band/ tag on the driver side spindle...I've looked up the part number on the tag, but haven't found anything.....any thoughts/ input??
BD 3986231
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 03-31-2011, 04:11 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Interesting Tag
anybody got thoughts or ever seen this...or is this like a rare corvette option
Geoff with a G
Old 03-31-2011, 04:21 PM   #3
Rodk65
Rodk65's Avatar
Re: Interesting Tag
After 20 years of driving trucks I have seen thousands of these. It is a seal used to seal the doors on a trailer or shipping container. The number on the seal was put on your bill of lading to verify that the load was not tampered with. They are made of plastic now but they used to be metal. It looks like it has been cut when it was removed. Not sure how it would end up in your truck.
ROD
1969 K10 4x4 Short Fleet. Tuned Port Injection 350/700R4, Cruise, tilt and factory A/C.
1971 C20 Camper Special. 350/350. SOLD
2002 Chevy Tahoe LT
Rodk65 is offline   Reply With Quote
Old 03-31-2011, 04:35 PM   #4
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Interesting Tag
Thanks for the input Rod.....Yeah...I cut it off of the spindle....maybe that was a bad idea???....Wondering if the spindle was changed out long ago and they left this seal on it when it was installed....sure looks like a GM part # to me though??
Geoff with a G
Old 03-31-2011, 04:37 PM   #5
4X4GMC1972
4X4GMC1972's Avatar
Re: Interesting Tag
I'm sure it was for identification purposes on the assembly line or the supplier to GM. Very common.
1978 Dodge Omni
4X4GMC1972 is offline   Reply With Quote
Old 03-31-2011, 04:38 PM   #6
Shane
Shane's Avatar
Re: Interesting Tag
cut one off my '70 back when I installed the ECE drop spindles ... still got it somewhere
Shane is offline   Reply With Quote
Old 03-31-2011, 04:45 PM   #7
KEL
72 GMC
KEL's Avatar
Re: Interesting Tag
Mine start with "D & L"
One is 3985127
The other is 3985490
They were both attached to the seat frame of my 72 GMC
KEL is offline   Reply With Quote
Old 04-01-2011, 10:22 AM   #8
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Interesting Tag
Dang...thought I had a rare item....Thanks for everyone's input!!!
Geoff with a G
Old 04-01-2011, 10:26 AM   #9
Piece of Work
Cultural Infidel
Piece of Work's Avatar
Re: Interesting Tag
For you it's rare... you only have one!
posted via La-Z-Boy
-Mark
1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold
1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 Also sadly Sold!
It may be that your whole purpose in life is simply to serve as a warning to others.
A man is not complete until he is married -- then he is finished.
Piece of Work is offline   Reply With Quote
Old 04-01-2011, 10:38 AM   #10
Keith Seymore
Keith Seymore's Avatar
Re: Interesting Tag
I agree.
It is the assembly plant "broadcast code", to help the line side operator choose the correct part.
There would be a different two letter (or three letter) code associated with each different part number permutation: so 2wd 1/2 ton would get one, 2wd 3/4 ton a different one, different one for 4wd, etc.
That way the operator needs only to walk over to the rack and select a "BD", rather than trying to remember part number 3986231 (vs trying to remember 3986232, 33, etc.).
They could be attached using the small bands you see here, or could be a paper tag stuck on the lug nut or an adhesive sticker stuck in some conspicuous place. You may even see paper tags wrapped on a part, like an ebrake cable or coil spring.
Hope that helps -
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-01-2011, 10:42 AM   #11
faribran
Re: Interesting Tag
Keith.. you are the man.
faribran is offline   Reply With Quote
Old 04-01-2011, 10:49 AM   #12
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Interesting Tag
Thanks Mark....I like your optimistic thought!!!
Hope that helps -
K
Wow....that helps explain it....Thankas for your input Keith!!!
Geoff with a G
Old 04-01-2011, 11:26 AM   #13
68Stepbed
68Stepbed's Avatar
Re: Interesting Tag
Cut one off the stock 72 spindles when I converted my 68 to 5 lug a few years back.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 09-05-2015, 02:48 AM   #14
Mistercates
Mistercates's Avatar
Re: Interesting Tag
I have this exact tag on the upper control arm of my 86 crossmember that I put under my 66 c10. I too was thinking it may be a part number. Wonder if its an inspection tag?
______________________________________________
RON
66 short fleet cc bbw
factory 283 3spd
Mistercates is offline   Reply With Quote
Old 09-05-2015, 09:58 AM   #15
Keith Seymore
Talking Re: Interesting Tag
Did you read my post (#10)?
K
1979-1986
1986 - 2019
