Old 03-24-2011, 09:34 PM   #26
bestray
Re: What battery do you prefer post or side terminal?
I prefer top post mostly because I've never had anything but bad luck with side post batteries.
1999 S10 blazer 4WD
1979 GMC 2WD 1/2 Ton
bestray is offline   Reply With Quote
Old 03-24-2011, 09:46 PM   #27
travo77
travo77's Avatar
Originally Posted by hotrodhomi View Post
Dual post batteries are great. I like the side post hook up with the top posts free for jumps/ stereos.
exactly why i buy dual post batteries
travo77 is offline   Reply With Quote
Old 03-30-2011, 02:15 AM   #28
jesse977
jesse977's Avatar
I bought a battery with both. woohoo
jesse977 is offline   Reply With Quote
Old 03-30-2011, 07:59 AM   #29
BigBlocksRule
GM's sandwich design with multiple connections on side-posts are a royal pain, great place for corrosion to build up and leave you stranded.
OTOH, I've seen where top post batteries get a thin layer of film on top, it actually conducts and slowly drains your battery.
As has been recommended multiple times, get 'em with both!
One other tip: Interstate Batteries. Go to a warehouse, not a parts store. I've bought nothing but their blems for 10 years or so, never had a single problem out of 'em and I pay $39 apiece. I found some 75-pounders there last time I was there, they're fire truck take-offs (they're immediately swapped out if a truck doesn't start on the first try, they can't afford a firetruck that can't respond) and they get $75 apiece. That's what I'm going to mount in the triangle box in front of my trailer for the winch, I know a guy using the same setup and he only charges it once a month and loads 4 - 5 cars a week!
BigBlocksRule is offline   Reply With Quote
Old 04-01-2011, 11:02 PM   #30
DetroitDan
DetroitDan's Avatar
Originally Posted by 78 Big10 454 View Post
My square has factory dual batteries. My primary is side post and my secondary is top post.
I've always heard that if you run dual batteries it is very important to have a matched pair. A lot of guys will even check the date stamp to make sure they are identical. Having one better than the other creates a disturbance in the force (little Star Wars reference just for fun) and will lead to premature alternator failure. Or so I'm told. Went through it with my diesel so I believe it to be true.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop.
DetroitDan is offline   Reply With Quote
Old 04-02-2011, 05:58 AM   #31
jesse977
jesse977's Avatar
Impressive..most impressive...
