Old 04-03-2011, 03:03 AM   #26
Hulk Will Smash
Hulk Will Smash's Avatar
Re: Pics of duallies with 19" wheels
Oh yah, and apologies for the digression from the 19s to the 19.5s. Seems like people will casually refer to the 19.5s as "19s". Bad assumption on my part. I'm sure it will turn out sharp no matter which way you go based on the work you've done so far.
'87 R30 Crew Cab Dually
It's 11 PM, do you know where your IAC pintle is?
Hulk Will Smash is offline   Reply With Quote
Old 04-03-2011, 04:34 AM   #27
K30_dump
Originally Posted by pvkj454 View Post
Switched to 8.25" wide 19.5 Accurides.
Are those 245/70s? That sure is a sweet looking truck .
As said, I plan to run 245/70s on my K30. I only have the stock 3-leaf front pack though, plus a Rancho add-a-leaf (supposed to raise 1-1.5"). Hopefully they won't rub too bad. Thoughts?
Thanks,
Joe
P.S. - As far as the confusion regarding the OP and his lowered dually, the fact that it is lowered was never mentioned anywhere in the original post. As said, many refer to 19.5s as 19s. Sorry for the confusion, was just trying to help...
K30_dump is offline   Reply With Quote
Old 04-03-2011, 08:52 AM   #28
SCOTI
SCOTI's Avatar
Originally Posted by Hulk Will Smash View Post
Mine is a 4/6 static drop. I haven't moved the fender wells. It hits from time to time....
What size on the tires?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-03-2011, 02:28 PM   #29
Hulk Will Smash
225/70 Continental HSRs.
Old 04-03-2011, 02:43 PM   #30
SCOTI
SCOTI's Avatar
That's 31.9" of tire height & extremely tall for a lowered truck. How is your truck lowered?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-03-2011, 03:09 PM   #31
Altec
Getcha Pull
Altec's Avatar
Originally Posted by Bigasstrux View Post
How about this......Looks good, rides terrible!
DANG!!!! That is it! The only way that'd be better is if it was a square body Topkick.
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 04-03-2011, 03:27 PM   #32
Hulk Will Smash
2" Bell spindles and 2" lower springs up front, shackles and smaller pack in the rear. Truck rides fine. I've driven it every day since last July. Prior owner did the same for nearly a year before that. It was a street trucks magazine tech article project.
Old 04-04-2011, 12:56 PM   #33
pig rig
pig rig's Avatar
it will take me better part of a day to find the info on tire size but I do know its on 19" brentz wheels
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 04-04-2011, 04:57 PM   #34
DetroitDan
DetroitDan's Avatar
anyone know the specs on the 245/70/19.5 vs 225/70? I seem to be able to find all the specs for the smaller size tires but not those. I need to know how tall they are. I talked to a gm guy who runs them on two of his 1 tons, he's got 8r19.5s, but they look like steer tires, not what I want. Real tall, but ultra skinny with no discernable tread. Wont work on a 4wd that I want to be able to hunt and plow with. I'll be looking for 6 drive tires.
Anyway, I am guessing the 245 will be at least 33". I've got room for 35-36 at least. Anything smaller than 33 is going to look too small imo.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop.
DetroitDan is offline   Reply With Quote
Old 04-04-2011, 04:59 PM   #35
cochino12
It followed me home?
cochino12's Avatar
http://www.1010tires.com/tiresizecalculator.asp-
245-70-19.5 = 33"
225-70-19.5 = 31.9"
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 04-04-2011, 05:31 PM   #36
DetroitDan
DetroitDan's Avatar
Thanks thats just what I was looking for. Def want to go with the 33s, I already have 31s and they're too small for a lifted truck. Plus the big wheel will make the smaller tire look even smaller. I know some (a lot!) of you guys like the look of a big rim and a tiny sidewall, but it's not for me.
Old 04-04-2011, 05:54 PM   #37
SCOTI
SCOTI's Avatar
It's not so much that it's 'liked', it's more out of necessity. Depending on the ride height, you have room for X amount of inches before interference. Deduct the 19" rim diameter & divide what's left by 2 (top & bottom sidewall height) & that's what you have to work with or you're going to have to start cutting/modifying (or raising) the truck.
Me personally.... I feel 4" minimum sidewall height is needed to survive our well kept roads.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-04-2011, 07:15 PM   #38
502ss
502ss's Avatar
Originally Posted by dropd80s View Post
502ss, what are you planning to run for tires? What kind of load rating/size is available? As focused as your build is on keeping the towing ability intact, just curious what you've found.
I have had quite a few tire discussions with Trevor over at TNW&T and spent countless hours researching my options. The discussions started with the standard 245/45-19 recommendation but I really don't want a 27.5" tall tire so I am looking to go with a 255/55-19 and 235/75-16 which will yield about a 30" tall tire which is still 1.75" shorter then the factory setup. Now as far as loads go, my GAWR in the rear is 7500lbs or 1875lbs per tire. All of the tires I found in the sizes listed above are in the 2100-2300lb range so I should be fine. A great resource for researching tire size/options is www.1010tires.com
1984 CC Dually - 454 - TH400 - Western Hauler Edition
Big plans are coming!
My build thread HERE
502ss is offline   Reply With Quote
Old 04-04-2011, 07:28 PM   #39
502ss
502ss's Avatar
So I thought I had my mind made up with my wheel choice but now I am wondering if the classic hole pattern would be cool too!!
What do you guys think?
Old 04-04-2011, 07:45 PM   #40
SCOTI
SCOTI's Avatar
I'm not a fan of the 'classics'. The holes are scaled too small for the wheel mass (it's also what I dislike about my 16" classics).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-04-2011, 07:58 PM   #41
DakotaLS6
Check out American Force Wheels. They make some of the sweetest dually wheels ive ever seen.
1972 Chevy 3/4 ton. Under construction
I'm a Mason! Lodge #624
DakotaLS6 is offline   Reply With Quote
Old 04-04-2011, 08:05 PM   #42
496 BB
496 BB's Avatar
First ones between the two.
1985 Chevy K-20
350ci (8.1L in the works!)
NP203/TH400 (Soon to be 205/400)
Dana 44 and 14 bolt FF
7.6' Western Plow
2001 Silverado LT HD 4x4
496ci (8.1L)
Allison
EFI Live
And more.....
496 BB is offline   Reply With Quote
Old 04-04-2011, 08:29 PM   #43
502ss
502ss's Avatar
Is there such a thing as a 30" tall 19.5" tire? Just wondering??
Old 04-04-2011, 09:13 PM   #44
cochino12
cochino12's Avatar
i thought about the classics but I was going to have trevor make the holes larger, just don't think its worth the extra $200 wheel. Why doesn't anyone make 20" dually wheels?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 04-04-2011, 09:32 PM   #45
Leedogg
Originally Posted by cochino12 View Post
i thought about the classics but I was going to have trevor make the holes larger, just don't think its worth the extra $200 wheel. Why doesn't anyone make 20" dualy wheels?
OR how have the tire companies NOT caught onto the trend- and make better 19.5 and 22.5" tires???? But I agree- 20" dually rims would rock!
1989 Chevy Crew Cab Dually - 454/400, Trans Am Hauler, Future bagged project.
96 Trans Am: 383/m6 - 11.98@115 on 315 M/T D/R's - 408rwhp 394 rwtq
05 VW Passat TDI - 38mpg @75mph
07 Bandit 1250S - Two wheeled fun!
Click here to see my FQuick Garage!
Leedogg is offline   Reply With Quote
Old 03-22-2012, 12:20 PM   #46
tobytuttle
tobytuttle's Avatar
ya heres mine its a 76 454 truck with 64k original miles...it was a 16.5 wheeled truck and finally located some 19.5s turned out trick lookin
tobytuttle is offline   Reply With Quote
Old 05-04-2013, 09:43 PM   #47
Bczik84
I found some older 22.5's steelies and was wanting to put them on 84 reg can c30 but I ain't got a clue if they'll work Any thoughts?
Bczik84 is offline   Reply With Quote
