Old 03-19-2011, 09:44 PM   #1
85_C10_Sleeper
85_C10_Sleeper's Avatar
Removing wheel wells?
Im working towards removing my wheel wells, and i think i might of bit off a little more then i could chew on this one. I have the wheel wells loose to were i can move them, but i cant for the life of my figure out how to get them out. and I dont really want to cut them.
I have my fender bolts so i have a little bit more room, still cant figure it out.
If any of you guys have some experience with this it would be greatly appreciated.
85 C10 LWB
305ci - 700r4 - 10 bolt - 3:08 gears
Collecting parts for a 'mild prerunner"
85_C10_Sleeper is offline   Reply With Quote
Old 03-19-2011, 10:12 PM   #2
Davidmichael
Davidmichael's Avatar
Re: Removing wheel wells?
I always removed my fenders with the wheel wells. It's more work to get everything lined back up, but if you replacing them, you can also paint up in inside of your fender this way.
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 03-19-2011, 10:22 PM   #3
Telecasterjoey
Don't think you can do it without taking off your fender. Take the fender off it will come right out! Good luck.
Telecasterjoey is offline   Reply With Quote
Old 03-19-2011, 10:29 PM   #4
85_C10_Sleeper
thanks guys, any tips on pullin the fenders?
what all needs to come off to get the fenders off?
85 C10 LWB
Old 03-19-2011, 10:49 PM   #5
87 chevy silverado
theres three under the radiator support bout 8 right inside the fender(where the tire is ) then two on the back the bolt to the fire wall and i would take the tire off to get the inner fender off
87 chevy silverado is offline   Reply With Quote
Old 03-19-2011, 10:49 PM   #6
Telecasterjoey
There are a lot of hidden bolts. There are 3 9/16 inch bolts. One on top of the fender near the hood hinges. One in the upper door jamb,and one on the bottom of the fender on the back side near the door hinges. Then there are like 8 or 9 1/2 inch ones along the front. That's bout it. Open your door a bit so the fender can wiggle out. Watch the front near the bumper it's easy to scratch the paint. Good luck.
Old 03-20-2011, 04:51 AM   #7
SS Delux
SS Delux's Avatar
You do not need to pull the fender to get the inner one out. Just make suer you have it all unbolted, the tire off and just wiggle it in and out and you got it ! I did it with out taking the fender off.
SS Delux is offline   Reply With Quote
Old 03-20-2011, 06:01 AM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Listen to this guy. I pulled mine yesterday and didn't fool with the fenders. Take the front wheel off and it will drop right out.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 03-20-2011, 08:23 AM   #9
Davidmichael
They are correct. you DO NOT need to pull the whole fender off. I just gave my opinion for why pulling the fender is a good idea. If you don't want to. Just remove the tire and take out the inner well as stated above.
01 S10 ZR2
Old 03-20-2011, 10:06 AM   #10
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
ill quadruple the sentiment as ive done it on ifferent trucks without removing the fenders. get o ut all the bolts remove the tire and alot of creative positioning and it comes out
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-20-2011, 01:08 PM   #11
JAG66
Lot's of different size bolts and screws. Just make sure everything on top of the inner fender is disconnected. But it comes right out. Just replaced the RF inner fender on mine. No need to remove the fender.
JAG66 is offline   Reply With Quote
Old 04-14-2011, 12:30 AM   #12
85_C10_Sleeper
I messed with it one day... didnt have any luck getting them out...
can anyone further explain how to get them out without removing the fenders? i can get them loose but i cant get them out!
Also were did you guys endup putting your batteries?
85 C10 LWB
Old 04-14-2011, 07:27 AM   #13
RandyP
Getting Old; Going Broke
RandyP's Avatar
I've never had an issue getting them out, seems they usually fall out once all the bolts are removed. I seem to have more issues getting them back in, but it is really not that big of a challenge to do. No way do you have to remove the fenders to get the wheelhouse in and out.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 04-14-2011, 12:19 PM   #14
motornut
78K & 79C Jimmys
motornut's Avatar
had to remove the inners on the 88 (heater core bolts i think)did so with out removeing the fenders
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 04-15-2011, 03:10 AM   #15
SBTork
Garage wrench
SBTork's Avatar
anyone?
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 04-15-2011, 04:11 AM   #16
85_C10_Sleeper
ill give it a shot tomorow with the wheel off. do i need to jack the truck up or something to get some clearance?
85 C10 LWB
Old 04-15-2011, 07:12 AM   #17
87 chevy silverado
just jack the truck up under th lower a arm take tire off and take out all the bolts and and it should just bout fall out
Old 04-15-2011, 09:17 AM   #18
85chevy4x4
85chevy4x4's Avatar
i just put mine back on yesterday i pulled them off to paint then finally put em on yesterday i didnt take the wheel off either i just kinda worked it around the tire. but mine is also a 4x4 so it was probably easier for me
85 custom deluxe 4x4 4 speed 350sb
85chevy4x4 is offline   Reply With Quote
