Old 04-18-2011, 12:00 PM   #1
vintage_car
s10 swap...rim/tire configuration???
I would like to know if this configuration would work on an s10 frame swap. I have the stock rear end, not the 4x4. I don;t have a problem with tubbing, I just want to make sure that there is clearance and that it would look decent. Maybe someone has this setup and could post a pic of how it looks. The truck is at stock height, no lowering blocks or anything.
Front:
rim: 18x8 5x127 Offset 0
tire: 245/40/18
Rear: 20x8.5 5x127 Offset 7
tire: 275/35/20
thanks for any help.
vintage_car is offline   Reply With Quote
Old 04-18-2011, 03:55 PM   #2
rollinrooster
rollinrooster's Avatar
Re: s10 swap...rim/tire configuration???
Im not sure if 0 offset is centered and what that 7 offset is. But 18x8 and 20x8 should look pretty good provided you have the right offset. Here is a couple of pictures of mine with 20x8.5 with 6.25bs and 20x10 with 4.75bs.
rollinrooster is offline   Reply With Quote
Old 04-18-2011, 04:00 PM   #3
vintage_car
is that stock ride height on the truck...not lowered? If so, that looks pretty sick!
what are the tire sizes?
Old 04-18-2011, 04:16 PM   #4
rollinrooster
The pictures are of the truck at ride height. The truck has airbags and will go much lower than pictured. As for the tires they are 245x45x20frt and 295x45x20rear.
Old 04-18-2011, 04:19 PM   #5
vintage_car
what rear end are you running?
Old 04-18-2011, 04:28 PM   #6
youngrodder
youngrodder's Avatar
Rollinrooster-
What brand are your tires? I have been having trouble finding a matching set in those exact sizes that arn't ridiculously priced.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 04-19-2011, 08:06 AM   #7
rollinrooster
9 inch ford about the same width as a 4x4 s-10
Old 04-19-2011, 12:08 PM   #8
vintage_car
that is wider than the stock s10 rear. can't remember buy how much but i will have to take that into consideration on backspacing...
Old 04-19-2011, 12:26 PM   #9
mr48chev
mr48chev's Avatar
At close to stock height I don't think you will have any real problems. Most of the guys have to run spacers on the front to get a more standard size tire out to where it looks right and doesn't set in too far.
The info I found says that the 2wd S-10 rear axle is 53-5/8 wheel mounting surface to wheel mounting surface while the 4x4 axle is 60 inches mounting surface to mounting surface. I've never measured what my tires are outside to outside but I have about a half inch clearance between the fender lip and the sidewall. I have 255-60x15 on 8 inch rims on it now with a mid 70's Nova axle.
With the axle width and the wheel/tire info you should be able to figure the total outside width or what it would be fairly easily by laying a straight edge across the sidewall and measuring from the wheel's mounting surface to the straightedge multiplying that x 2 and adding in the axle width.
Old 04-19-2011, 12:44 PM   #10
rollinrooster
When i had my stock 2wd s-10 it measured around 54.5" hub to hub. From what ive seen most 4wds are around 59". The rear axle in my truck is around 58"
Old 04-19-2011, 12:47 PM   #11
vintage_car
these numbers make my head hurt...
Old 04-19-2011, 12:53 PM   #12
rollinrooster
Originally Posted by youngrodder View Post
Rollinrooster-
Marc
Marc, are you going to be changing youre wheels in the future? If not the size tires i have may not work for you.
Old 04-19-2011, 12:56 PM   #13
rollinrooster
If you can tell me what back spacing you are going with i will help you all that i can with the set up Also if youre going to lower the truck or not makes a big difference in wheel/tire setup as far as how it looks and how it performs.
Old 04-19-2011, 01:00 PM   #14
vintage_car
not lowering the truck...won't be able to get it out of my crazy driveway. as for backspacing, I don't have a clue. I just found out backspacing is different from offset. haha
Old 04-19-2011, 01:43 PM   #15
rollinrooster
You ever considered air bags? With air bags you could get out of youre crazy driveway As for measuring backspace all you have to do is get a straightedge and lay across the back of the rim (not the tire) and measure down to the mounting surface. This will get you pretty close.
Old 04-19-2011, 01:50 PM   #16
vintage_car
thought about airbags...but $$$ is tight.
thanks for the backspace instructions, dumb question... so I assume I can measure the current backspace of my 15" rims and then add the difference from the edge of the fender to the front of the rim to figure out what I would need for the new rims/spacers for the look I want?
Old 04-19-2011, 08:36 PM   #17
BlueJeep
BlueJeep's Avatar
Is it an early bronco 9" or has it been narrowed?
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 04-19-2011, 08:56 PM   #18
youngrodder
I have a set of 20's coming in next month. 20 x 8.5 and 20 x 10 so those sized tires would work well. Whats the brand?
Marc
Old 04-20-2011, 03:12 PM   #19
vintage_car
was it that dumb of a question?
Old 04-21-2011, 11:57 AM   #20
1952ssr
1952ssr's Avatar
I bought mine from Discount tire, Dunlop signature series I went with a 255/35/20 on the 20X10 and 225/40/18 on the 18x8. They were really good on price and they had a rebate to boot.
1952ssr is offline   Reply With Quote
Old 04-21-2011, 12:02 PM   #21
vintage_car
with a stock s10 rear will I need spacers, or is there a way to figure that into the backspacing of the rim?
Old 04-21-2011, 12:35 PM   #22
1952ssr
1952ssr's Avatar
You can figure that in, it all depends on the wheels you want. I could have gotten American Racing Torq-Thrust and had many different choices on backspacing, but the price was CRAZY!!!!! So I decided to get the Boss 338's instead for half the cost.
On back I began w/ the original 2wd s10 rearend but had to run 2 inch spacers. The gear ratio was not what I wanted so I went and bought a 4x4 rearend w/ a better ratio. The 20x10's are 20mm offset w/ a backspace of 6.225.
Up front 18x8's are +2mm offset w/ a 4.517 backspace. I am running 2 inch spacers on the front.
Here's a picture of the truck in which I feel in love with the wheels notice the deep offset. I think it's on a S10 chassis too.
Old 04-21-2011, 12:39 PM   #23
vintage_car
thanks for the info and pic. That is a GREAT look! I have 15" weld rims and really want to upgrade. Might have to put those up for sale and bite the bullet on rims. I had read the Boss 338's had some finish issues? Are you experiencing any of that? Where did you get those 2" spacers?
Old 04-21-2011, 12:51 PM   #24
1952ssr
1952ssr's Avatar
I haven't even washed mine for the first time yet since truck ain't running. So I don't know about issues but, they are definately a popular wheel. I bought my spacers from Ecklers Corvette in 2002 to run 17 X 9.5 vette wheels on my s10 I had at that time. I think they have since discontinued them. They haven't been ran in over 6 years. They actually are sold thought Vette Brakes in St Petersburg, Florida.... I think.
Old 04-21-2011, 12:54 PM   #25
vintage_car
1952ssr- sent you a pm
