Old 04-19-2011, 01:57 AM   #76
dmack91
dmack91's Avatar
Re: 68 workhorse
Look like the valve for an old set of air shocks. Fairly popular in the 70's. Didn't dampen bumps much, but you could adjust ride height with them.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 04-20-2011, 11:25 PM   #77
heeroyue2002
fat old dude
heeroyue2002's Avatar
Re: 68 workhorse
present from the former owner. he called me a week ago and i had time to pick it up today.
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 04-20-2011, 11:32 PM   #78
VA72C10
VA72C10
VA72C10's Avatar
Re: 68 workhorse
cool! Those look nice!
Old 05-26-2011, 01:36 AM   #79
heeroyue2002
fat old dude
Re: 68 workhorse
ok, so i want to get 6 lug steels with hubcaps.
heres the one that came with the truck as a spare.
i got these from a friend, they came on his 69. are these correct?
Old 05-26-2011, 07:45 PM   #80
67chevy1series
67chevy1series's Avatar
Re: 68 workhorse
hurry up and put those head light bezel and the rims on!
67chevy1series is offline   Reply With Quote
Old 06-14-2011, 09:39 AM   #81
heeroyue2002
fat old dude
Re: 68 workhorse
Took the truck out on sunday to a job. Did well on carrying loads but i did run out of gas once. I had changed the sending unit in the tank and im not still not getting a gas reading. I was also able to drag a stump as big as the hood around the yard while it was loaded to the brim with logs. Really wanted a pix of it loaded but my lame phone turns off by itself and i need to plug it in to turn it on(iphonr with bustef sleep/wake button)
Old 06-14-2011, 09:43 AM   #82
heeroyue2002
fat old dude
Re: 68 workhorse
Oh, also i wasnt all to good with the old manual. Im used to new ones that are all smooth and little effort, so i turned it off a couple times. It seems like my alt isnt charging the battery. I had to get jumped a couple times.
Old 06-15-2011, 03:01 PM   #83
67chevy1series
Re: 68 workhorse
yep those old manuals are a little sloppy lol
Old 06-16-2011, 02:29 AM   #84
heeroyue2002
fat old dude
Re: 68 workhorse
looks like tomorrow or soon the engine is getting pulled and the tranny for my goodwrench 350 with a TH400
Old 06-16-2011, 02:33 AM   #85
67chevy1series
Re: 68 workhorse
we need pics!!!!!!
Old 06-16-2011, 02:36 AM   #86
heeroyue2002
fat old dude
Re: 68 workhorse
my neighbor will be buying the current engine in it and im robbing my 72's drive train. will i need a new driveline?
Old 06-16-2011, 02:38 AM   #87
67chevy1series
Re: 68 workhorse
what tranny did they 68 have and what tranny are you putting in?
Old 06-16-2011, 02:46 AM   #88
heeroyue2002
fat old dude
Re: 68 workhorse
68 had a 4 speed manual and a 327/350.the SPID says 327 but im not sure if it was changed at one point.
the 72 has a 350 goodwrench crate engine with a TH400.
basically guna move the 72 stuff onto the 68
Old 06-16-2011, 02:49 AM   #89
67chevy1series
Re: 68 workhorse
yup you will need a new driv line... i would try and see if you can make it work if not then start huntin around...
Old 06-16-2011, 02:53 AM   #90
heeroyue2002
fat old dude
Re: 68 workhorse
hmm the longbed is two pieces though.
Old 06-16-2011, 02:55 AM   #91
67chevy1series
Re: 68 workhorse
yes you might need a new carrier bearing
Old 06-17-2011, 12:27 AM   #92
heeroyue2002
fat old dude
Re: 68 workhorse
im tired. pulled the engine out of the 68. i thin the 68's engine is long water pump and the 72's is short water pump. was trying to swap pulleys to put all the accessories from the 68 engine onto the 72's. looks like in order for it to work i'll have to make the 72 engine a longwater pump for now?
these is the bottom double belt pulley from the 68 onto the 72 and its not aligning
Old 06-17-2011, 12:48 AM   #93
1972hays
1972hays's Avatar
Re: 68 workhorse
nice
1972hays is offline   Reply With Quote
Old 06-17-2011, 01:11 AM   #94
67chevy1series
Re: 68 workhorse
dayum im impressd buddy! you took the dog house and engine out by yourself? sweet!
Old 06-17-2011, 01:20 AM   #95
heeroyue2002
fat old dude
Re: 68 workhorse
whats the doghouse?
Old 06-17-2011, 02:25 AM   #96
67chevy1series
Re: 68 workhorse
front clip
Old 06-17-2011, 02:37 AM   #97
heeroyue2002
fat old dude
Re: 68 workhorse
oh. yeah i do everything alone.
Old 06-17-2011, 02:44 AM   #98
67chevy1series
Re: 68 workhorse
your pretty beast man!
Old 06-18-2011, 01:32 PM   #99
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: 68 workhorse
Looks like your making progess.. Btw that dirty water pump is the long one and the orange on is a short one..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 07-04-2011, 11:08 PM   #100
heeroyue2002
fat old dude
Re: 68 workhorse
im finally back home and got sometime to get to work. it is really really hard to remove and move the engines around the yard alone.
i removed the high hump and found a rag and some custom foam?
the manual tranny crossmember didnt want to come out in one piece even after i took out the top of the rivets so it just came out in pieces.
4 speed is out.
engine n tranny off the 72. really dusty.
the 72 empty
