02-17-2011, 03:02 PM | #51 |
Re: C4 Dropmember and Trailing Arm Conversion Install
Average vehicles prob only use 2-3" of compression travel depending on spring & shock rates.
04-19-2011, 02:44 AM | #52 |
Always a work in progress
Wild83-Are you running an intercooler? Do you have pics of where it is monted and what size you got? I will be running a turbo setup similar to yours with a Borg Warner st80 modified by Forced Inductions(83mm turbine/80mm compressor w/1.10 A/R on a T4 flange)
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
04-19-2011, 10:00 PM | #53 |
I do have an intercooler, it's a large procharger intercooler. It's mounted behind the grill to the radiator support. I will try and get some pictures soon and post them up.
83 C10 Stepside (SOLD, it was a blast!) 383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt S475 and C4 DM running, fine tuning turbo= Douchebag Racing: Runs Fine all the Time |
04-22-2011, 11:26 PM | #54 |
Sweet! Forced induction is da bomb!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
