good paint for coloring panels and detailing cab
I need a good durable black paint other then cheap spray paint that i can color my panels with and dash.Im trying to make it look good but want it to last and not scrap off
1982 chevy silverado It's all about original guys original let me say again original.
![]() Join Date: Nov 2010
Re: good paint for coloring panels and detailing cab
I have used SEM paints on my truck and they are good. DuPont also makes interior paint. Any paint you apply will wear/scratch off if you rub something against it because it is not actually part of the vinyl or plastic itself. What you want is a paint that will not "flake off" on its own - in other words, it adheres properly to the vinyl or plastic. I have a painted armrest pad on my driver's door with the SEM paint rubbed off in places because I let the seat belt snap back into the retractor on the floor when I release the belt. Anything you paint on will do this. I just take the armrest pad off once a year and respray it. If I were careful in releasing the seat belt this would not be a problem, or I could buy a factory matching color armrest at 3X the cost of the generic one I installed and painted to match. My truck is a a beater work truck so I do not need a show quality interior. Here is a pic of the armrest.
I know SEM has a vinyl dye but i didnt see anything on their site. Their flexible paint is good for plastic but if you are doing vinyl you definitely want a vinyl dye.
Re: good pain for coloring panels and detailing cab
WE USE SEMS for small jobs. Have it mixed up for large
http://www.semproducts.com/ Last edited by mbgmike; 05-20-2011 at 05:51 PM. |
#7 | |
Alright guys thanks for the rply i just found out about this "sem" paint and i asked someone if it was sold locally like pepboys etc.Honestly i find it no big deal im not doing vinyl on my door so i dont need vinyl paint im sure its great tho corky.But i dont think the sem would do anything i couldnt do with soemthing else if tuscon said it already chips.
![]() Join Date: Feb 2010
What about Krylon Fusion? It's not good?
#10 | |
here are 3 from sems dealer finder on link I postd APYS 2925 Gateway West El Paso, TX 79925 Phone: (915) 562-4204 Auto Body Supply 2330 Magoffin El Paso, TX 79925 Phone: (915) 542-1774 Sherwin-Williams 5715 Gateway Blvd, West El Paso, TX 79925 Phone: 915-772-2781 Fax: 915-772-4596 Last edited by mbgmike; 05-21-2011 at 09:39 AM. |
Chipping is not the issue - it only matters if you are scraping something across the surface you painted, which you should not be doing, my seatbelt is an unusual case - I just showed it as an example of what could happen. The big issue is will the paint stick to your surface. $1 a can rattle can paint will flake off and make a mess. SEM paint is about $11 a can, but worth it. I used 3 cans for all of my interior. If you are just painting metal trim, like the headliner trim, etc., then just use cheap paint, unless your are trying to color match the whole interior. Preparation of the surface is always needed, regardless of the paint you use.
this was double posted in the detailing area. locally here are dealers
APYS 2925 Gateway West El Paso, TX 79925 Phone: (915) 562-4204 Auto Body Supply 2330 Magoffin El Paso, TX 79925 Phone: (915) 542-1774 Sherwin-Williams 5715 Gateway Blvd, West El Paso, TX 79925 Phone: 915-772-2781 Fax: 915-772-4596 if you want a crap job that won't last very long by cheap stuff. Sems is not THAT expensive. Last edited by mbgmike; 05-21-2011 at 09:57 AM. |
#16876
Merged
Posted via Stationary Device '71 Custom Deluxe C-20 402. '67 Buick Special 455. '49 Plymouth Special Deluxe. "I love that old car smell" ![]() Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs. |
| Bookmarks |
| Tags |
| paint |
