Old 05-28-2011, 11:01 AM   #1301
Slick67
Sofa King Crazy!!
Slick67's Avatar
Re: 1967 C10 Custom Big Window
Originally Posted by 68 TT View Post
Nice score.
You might want to wait until the engine is back in the truck before you install it just in case the extra weight moves things out of alignment from where it will be now without the engine. Just a thought.
Since I have bags on the truck and no alignment yet, will that still affect it?
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 05-28-2011, 11:08 AM   #1302
68 TT
Still plays with trucks
68 TT's Avatar
With the bags you can set it at your desired ride height and the engine not being in place won't matter.
I would install the bar with it aired up to be in the middle of your ride height range so the end of the sway bar has room to slide for both going up and down in ride height without it pulling out of the bushing.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 05-28-2011, 11:15 AM   #1303
Slick67
Sofa King Crazy!!
Slick67's Avatar
Excellent advice. Should I use baby powder to help the bushings from squeaking or does that help just to slide them into place? Maybe a light silicon?
Old 05-28-2011, 11:33 AM   #1304
68 TT
68 TT's Avatar
Are they rubber or poly bushings? Hard to tell in the pics.
Poly takes a special grease but rubber you can use a silicone spray or even WD40 to get them assembled. I've never tried baby powder.
Old 05-28-2011, 01:32 PM   #1305
VA72C10
VA72C10
VA72C10's Avatar
That was a good score, looks good in pc, and will help the handling!!!
Old 05-29-2011, 03:58 PM   #1306
jbice70gmc
jbice70gmc's Avatar
Truck looks nice!! Something a little different nice LWB. I live over on the eastside of town in the Baytown area. I have several friends that live out in the Tomball/Cypress area. I'm going to check out one of those niffty fiffty shows soon. I have a SWB GMC 70 model and plan on running the same basic suspension setup as you. My question is did you have to do any kind of modifications to your inner fender wells front or back? The fronts look untouched.
1969 GMC SWB Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=486320
jbice70gmc is offline   Reply With Quote
Old 05-29-2011, 07:44 PM   #1307
Slick67
Sofa King Crazy!!
Slick67's Avatar
They are rubber. WD-40 it is!!!! Baby powder does wonders on stuff like this, especially in humidity.
Absolutely!!! Can't wait to test it out.
Welcome to the board!!!! Hope to see ya at one of the shows, with your truck! I did no mods to front or back and it is a 20 22 combo with a c-notch. One peice of advice, don't go with the panhard bar in the back, do a two-link minimum with the stock arms and you will get the straight up and down travel with the bags.
Old 05-29-2011, 08:19 PM   #1308
jbice70gmc
jbice70gmc's Avatar
Awsome my first piece of advice. I will definately keep that in mind when I get to that point. I have actually already bought a set of wheels and tires from a friend. the wheels are 20X8.5 front and 20X10 rear. Hear is my wheels on my buddies truck.
Old 05-29-2011, 08:48 PM   #1309
jbice70gmc
jbice70gmc's Avatar
My little buddie at work that is helping my green ass out sugested a watts link. What do you think?
Old 05-29-2011, 09:51 PM   #1310
Slick67
Sofa King Crazy!!
Slick67's Avatar
That's a sweet truck! I would research it here on the board in the suspension area first then make a well educated decision. A long bed is gonna be a little different from the short of course. I have yet to decide on what to do with mine, but I don't wanna run the panhard bar for sure.
Old 05-30-2011, 09:31 AM   #1311
kev2809
low n' slo
kev2809's Avatar
my panhard bar is run from the driver side frame to passenger side trailing arm, its a lot less movement than the stock ones. the longer the bar, the less movement you have.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 05-30-2011, 02:29 PM   #1312
Slick67
Sofa King Crazy!!
Slick67's Avatar
I will have to check into mounting mine on the trailing arm then. My panhard bar is adjustable so maybe I can make it extend far enough or put another end on it to adjust it futher. Thanks Kev!
Old 05-30-2011, 03:31 PM   #1313
kev2809
low n' slo
kev2809's Avatar
np! the one i bought was extendable too but cpp makes 3 sizes i think, and i got the shortest one lol. i just cut it in half, welded a 1" thick bar in between in the length that i needed. works fine!
-_--_--_ _________
Old 05-30-2011, 08:20 PM   #1314
Slick67
Sofa King Crazy!!
Slick67's Avatar
Cool! Thanks Kev. Another little project I can do while waiting on my engine.
Old 05-30-2011, 09:34 PM   #1315
kev2809
low n' slo
kev2809's Avatar
cool, post some progress! just dont do what i have been doing while waiting on buying a compressor...i shaved the firewall (didnt plan on it), shaved up the mirror holes (didnt plan on it), and now about to move my bags on the axle (once again, didnt plan on it) lol.
-_--_--_ _________
Old 05-30-2011, 09:50 PM   #1316
Slick67
Sofa King Crazy!!
Slick67's Avatar
I know how that is. Mine was supposed to be a simple driver build. Dangit.
Old 06-04-2011, 03:27 PM   #1317
77chris03
77chris03's Avatar
Well, enough complaining. Gotta move on with this project. Found a really good deal on Craigslist. Got a 1969 sway bar and all the brackets, with new bushings and already powdercoated for $60. The larger brackets are custom made for lowered trucks. Thought that was a pretty good score. I will have something to do on Memorial Day!
Attachment 753113
Attachment 753114
not fair....i paid 150 for mine...and it cost me a 18 pack to have it blasted and then painted....i got 1 up on ya tho.. my motor is in..haha j/k
68 C10 Stepper #1- GONE 68 C10 Stepper #2
1977 Chevy Cheyenne...gone...was my first Chevy
04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD
99 Sierra Stepside, 17 Denali HD, 84 K10
My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333
My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310
77chris03 is offline   Reply With Quote
Old 06-05-2011, 05:59 PM   #1318
Slick67
Sofa King Crazy!!
Slick67's Avatar
Yeah, keep rubbin it in. One day mine will be there.......again.
Old 06-08-2011, 09:04 PM   #1319
Slick67
Sofa King Crazy!!
Slick67's Avatar
Talked with the engine shop today..........he actually did something. He sprayed the engine with brake cleaner where the crack is supposed to be and could not get anything to come through. He said the timing chain cover is coming off tomorrow so he can better see the suspect area and then weld as needed. I asked when I could get it and he said the end of this week or sometime next week. Yep, I can live with that.
Old 06-08-2011, 10:03 PM   #1320
Jeffs70
Jeffs70's Avatar
awesome to hear Slick. hope he comes through with it. although I think he could have done more work then just sprayed it with cleaner and looked at it in one day. IMO any how.
Jeffs70 is offline   Reply With Quote
Old 06-09-2011, 09:40 AM   #1321
Slick67
Sofa King Crazy!!
Slick67's Avatar
Yep.......what a turd.
Old 06-09-2011, 10:00 AM   #1322
eagleuh1
eagleuh1's Avatar
Hope he makes sure to get all the brake cleaner out of the crack before welding on it. Makes some nasty stuff if theres any left and it gets heated. I think its like Phosgene gas. Used during the 1st war to gas the troops. Good luck on the engine. The trucks awesome.
eagleuh1 is offline   Reply With Quote
Old 06-09-2011, 01:08 PM   #1323
Slick67
Sofa King Crazy!!
Slick67's Avatar
Long time, no hear! He's about as sharp as a bowling ball, maybe I should call him before he kills himself with the homemade chemical weapons. Never heard that before, pretty cool info! Thanks for stopping by eagleuh1!!!!
Old 06-09-2011, 03:17 PM   #1324
David67
David67's Avatar
Hope everything works out soon enough! I gotta see this truck!!
'67 C10
David67 is offline   Reply With Quote
Old 06-09-2011, 03:46 PM   #1325
Slick67
Sofa King Crazy!!
Slick67's Avatar
I hate to bring it out without the bed and the interior done, but it might just happen before the end of the Niftee 50ees 2011 season.
1967, custom, lwb
