Old 05-30-2011, 05:57 PM   #1
munchieu
82 front suspension on a 66 questions
I found a 82 donor truck. I want to roll the 82 front end under the 66. crossmember and all. I heard to do this I need to make two holes larger and drill two fresh holes. After looking at the trucks I can see where it needs to be done. My question is what to do with the motor mounts? the 66 was a 6 cyl and will now be a 350. the motor mounts off the 82 do not fit the two top bolt holes of the 66 frame. Where do I go from here?
munchieu is offline   Reply With Quote
Old 05-30-2011, 07:05 PM   #2
66 lwb cs
66 lwb cs's Avatar
Re: 82 front suspension on a 66 questions
Not trying to be a smart a$$ but you may have to fab something up or draw it up and make it out of cardboard as a template then take it to a local welder and have him cut and burn it together. Only other option I can think of is look in the junk yard for a truck same vintage as yours and rob the motor mounts out of it, if it was an 8 cyl. Or maybe try some of the parts vendors they may sell a conversion kit with mounts. Just trying to help hope I did,
66 C20 LWB CS 327/TH400 A/C
66 lwb cs is offline   Reply With Quote
Old 05-30-2011, 07:29 PM   #3
63MOUSE
i have a 63 and i put the front end from an 84 suburban on . you have to drill one hole and elongate one hole and put spacers on top of the frame, you will see how thick you need when you bolt together. done it on 2 trucks for the newer front end and disc brakes. works great, no welding or cutting, just some drilling
63MOUSE is offline   Reply With Quote
Old 05-30-2011, 07:34 PM   #4
Clyde65
Clyde65's Avatar
Why do all that? change the spindles and your done....other than brake lines.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-30-2011, 07:36 PM   #5
munchieu
Want all the updated a arms.
Old 05-30-2011, 08:38 PM   #6
1966Stepside
1966Stepside's Avatar
I actually just finished this exact same swap (same year donor and everything, not that it matters) so hopefully i can help out some.
The best bet for motor mounts would probably be to grab some from a junkyard and clean em up and use those. My 66 had a 350 already with the old 66 crossmember and A-Arms. the mounts don't look like anything special, so I would bet they are factory mounts from the truck the 350 came from (Which was a '76 1/2 ton from the block numbers). They bolted directly in to my frame, and it doesn't look like any work had been done previously to make it fit.
Long story short, go get some v8 mounts from a junkyard 73-87 truck. Should be dirt cheap. Bolt them in directly and win! If you have any other questions about the swap lemme know. I haven't taken mine to an alignment shop yet or anything, but I'm not worried, it'd be tough to do it wrong.
The 73-87 (and maybe 67-72, not sure) A-Arms have rubber bushings, which was the deciding factor for me.
1966Stepside is offline   Reply With Quote
Old 05-30-2011, 09:00 PM   #7
munchieu
I have the mounts from the 82. the two bottom holes obviously mount up because its the 82 crossmember which is in the 66 now. the top holes do not match.
Old 05-30-2011, 09:13 PM   #8
1966Stepside
Would you happen to have a pic? I'm surprised the holes aren't lining up for you. I don't know if the '82 was offered with a 6 cyl, but could it be possible that you have v6 mounts? Just tossing out ideas, since from what I've read and from personal experience the motor mounts should be a straight bolt in.
To verify: When you got the crossmember into the truck you got the bolts (3?)that go through the bottom of the frame and bolt the crossmember to the frame to line up? If so, then I'll admit to being stumped. That should locate the crossmember and the mounts should set right in place. Pics if you've got em, if not some more info on how the holes are missing (too far forward/back or not reaching all the way to the bolt holes in the frame) would give us a better idea of what's needed to get it all together.
Old 05-30-2011, 09:15 PM   #9
munchieu
pics coming right now.
Old 05-30-2011, 09:39 PM   #10
munchieu
bolted to bottom of crossmember
does not line up at top. nowhere near close. These mounts are from the 82. cant use the 66 monts cuz there 6 banger mounts
Old 05-30-2011, 09:43 PM   #11
munchieu
I guess there called frame side engine stands not mounts
Old 05-30-2011, 09:44 PM   #12
SCOTI
SCOTI's Avatar
Did you try to re-use the mm's/towers that were w/the 66 x-member? You might just need to re-drill the holes in the x-member part??
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-30-2011, 09:48 PM   #13
1966Stepside
Wow, that motor mount doesn't look anything like mine! It's tough to say what's going on there. My mount has two bolt holes on the top of the frame and one going into the crossmember. As rusty and aged as it looked, I sure figured it to be original. Maybe the mount I have is some aftermarket piece, since the PO did an extensive *cough* restoration *cough* at some point.
Hopefully someone can identify your mount or point you in the right direction. In the meantime, I'm going to dig around some of my research pages and see what I read about the motor mount being a direct fit....
Old 05-30-2011, 09:50 PM   #14
1966Stepside
I think you're right, but I always either lump them into "engine mounts". If I need to differentiate I call them crossbraces. Everything I know I taught myself so my terminology is often very different from the norm
I was also going to suggest this as what I have on my truck. No idea if this is possible, but do the 350 rubber mounts bolt to the 6 cyl crossbrace?
Old 05-30-2011, 09:55 PM   #15
SCOTI
SCOTI's Avatar
Motor mounts = rubber/steel cushion that bolts to the block.
Towers/stanchions are what connects the mm's to the frame & x-member.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-30-2011, 10:24 PM   #16
1966Stepside
Yup, what I call stuff in my head and what everyone else calls it is different again.
I should make it over to my shop tomorrow, and I'll take some pics of what I have going on. Hopefully it'll give you some info.
Old 05-30-2011, 10:44 PM   #17
munchieu
Those will not work because the were 6 banger towers. one side is longer than the other.
Old 05-30-2011, 11:50 PM   #18
63MOUSE
Here's a picture of my '63 with '84 cross member and mounts...all '84; spacers on top, had to drill holes like you see.
Old 05-30-2011, 11:51 PM   #19
SCOTI
SCOTI's Avatar
I recommend a board supporting vendor then....
http://www.performanceonline.com/Engine-Mounts-c-455/
I used these in a 68 frame w/a notched 73-up x-member. I only had to elongate 1 hole on each sode of the x-member. My buddy now has them in his 72 Blazer that utilizes a post-73 x-member. His install required trimming the frame lip (it was a 4x4) & drilling 1 hole each side on the x-member.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-31-2011, 12:52 AM   #20
firenuttz
2lo4me/ntlonuf/ntfstnf
firenuttz's Avatar
when i swapped an 83 x-member into my brothers 64 i used the motor mounts that came out of the 83 and just put a 1/4in spacer in between the mount and the frame drilled the holes and it holds all 600hp of it without issue
62 GMC swb fleetside~ project: still undecided
84 Chevy 4wd crew cab 8 inch lift and 37" goodyear h1 pulloffs, still rockin the old mans former plate 2LO4ME
65 chevy 1 ton panel~ bagged/bodied duramax plans slowly in progress...
02 Silverado cclb duramax~ sas'd "bro" truck with more rust than imagineable...
firenuttz is offline   Reply With Quote
Old 05-31-2011, 12:55 AM   #21
Captainfab
60-66 Nut
You can use the '82 motor mounts and frame brackets, but you will need a spacer on top of the frame and drill two holes on each side. Just like the pics that 63MOUSE posted. If you were to locate a pair of the frame brackets from a '73-'87 C20, you wouldn't need the spacer on top of the frame.
The alternative would be to use a pair of the original 230/250 I6 and V8 motor mount brackets. I have a few sets if you decide to go that way.
Old 05-31-2011, 08:39 AM   #22
Str8axle
Str8axle's Avatar
I agree. Frame brackets are the same I6 and V8. The only difference is where they bolt to the frame.
Ray
All my life, I've been told I'm a "Bad Influence"
Str8axle is offline   Reply With Quote
Old 05-31-2011, 09:49 AM   #23
kieth
kieth's Avatar
Attachment 754371
Attachment 754372
Attachment 754379
I used motor mounts from a 91 suburban, the engine, the front crossmember, power steering box, itc., had this same problem, we trimmed the truck frame and redrilled new holes on the crossmember. Here is a link to my pictures. Kieth
http://kieth.smugmug.com/Trucks/66-G...03189305_KyUKk
If you will scroll thru the pictures u can see what we did to make the later motor mounts work. Kieth 918-446-2245 we think this lowered the eng/transmission combo enough so we did not have to modify the doghouse (trans tunnel)
kieth is offline   Reply With Quote
Old 05-31-2011, 10:14 AM   #24
Chevy Fleetside
Chevy Fleetside's Avatar
Like said above. You can use the I6 towers for the V8. You don't even have to move them. Get new rubber mounts, why use old ones. My 66 was an I6 Truck and I never touched the towers and just dropped in an 87 year model V8. The 66 towers will bolt up to the newer crossmember without even drilling any holes. Was done when I helped a friend with his front crossmember swap.
Here are some pictures of the V8 sitting on the I6 towers. I put new mounts in because the others were falling apart.
Check out this thread with all the pictures and all the stuff we did to get it done. http://www.chevytalk.org/fusionbb/sh...hp?tid/223597/
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 05-31-2011, 10:18 AM   #25
SCOTI
SCOTI's Avatar
Just to throw this out there in case someone doesn't know this info, the 230/250 6's use the same mm tower as the sbc. The large 6 (292) uses a different pass side from what I recall.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
