Old 05-31-2011, 08:16 AM   #1
Rifter_Chevy
Strange grind coming out of 4 low
Hello all, i have a 1984 K20, its got a 350 smallblock and a Turbo 400 and a NP208. When i shift it slowly out of 4 low it grinds pretty bad. However when i yank it out of 4 low very quickly it goes smoothly back into 2 hi. Should i worry about it or just keep shifting really fast out of 4 low? Also it doesnt grind at all going into 4 low, or from 2 hi to 4 hi.
1984 3/4 Ton Reg cab Longbox 4x4, Carbed 350/Turbo 400 Trans/205 T-Case
Rifter_Chevy is offline   Reply With Quote
Old 05-31-2011, 03:50 PM   #2
Blazer1970
Blazer1970's Avatar
Re: Strange grind coming out of 4 low
Yes, don't worry and shift fast. It usually helps it shift smoother if you are just rolling slowly with the trans in neutral when you shift it.
Blazer1970 is offline   Reply With Quote
Old 06-01-2011, 12:42 AM   #3
Rifter_Chevy
yeah i always shift in/out of low range in neutral with foot off the brake(unless im on a incline then i let it roll slowly as i shift)
