#2326 |
Re: What did you do to your truck today!
Nothing on mine, but spent the day installing a stereo in a friend's 64 C10. Dash was already cut, but had to make speaker boxes for under the seat and in front of the B&M shifter.
Got done just in time to go to work.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
#2327 |
I took a shot in the face bleeding the master cylinder. Apparently there was an air bubble in the line
#2328 |
yes, i do
sounds like me when i primed the oil system in my 60 because i forgot to install the mechanical oil pressure gauge line. i never want to know what mobil1 tastes like ever again
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
#2329 |
replaced diverter box in air con/heat system and cleaned all other duct work. my "S" duct is damaged so I gotta order another. I adjusted all the cables to ensure full movement and eyeballed every aspect of the system. I rubbed some "bay rum oil" from Plum Island Soap Company in the duct work to condition it and give it a little odor. :}
added a chrome water pump from Jegs and had the lower bolt hole of my a/c bracket welded back together. U never know what u r gonna find when u start digging in these old rods. I added a spring to my passenger side kick panel door vent that will close the door when I switch back to the "outside" air mode. took me forever to figure out how to get that damn door to close on it own. gave the carpet a hair cut where the mats have opened some of the loops. Washed and detailed the engine and suspension. Washed the body also. Installed 2 new parking lamp assemblies in the front bumper. changed the oil and filter. busy boy!!! |
#2330 |
Took her for a 30 minute cruise this morning. Found I have a short in the turn signal switch causing some brake light issues.
Picked up new turn signal switch after another 30 minute cruise this evening. Filled my Camaro tank all the way up for the first time. Fills great no issues and the gas gauge reads pretty darn close to perfect. The kids at the gas station loved the truck and couldn't help but smile as I rolled in blaring Sublime's- Love is What I got.
67 C10 Stepside 66 Mustang Coupe 99 Burb 2500 |
#2331 |
Collector of Projects
Got my CaptainFab booster bracket in the mail and picked up a York compressor for On Boar Air...
![]() ![]() Last edited by mcmlxix; 06-04-2011 at 01:15 AM. |
#2332 |
![]() Join Date: Apr 2004
You'll love they way that York works. Too bad they are so ugly, at least mines bends in with the other uglyness under the hood.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
#2333 |
I hope you had your safety glasses on .
#2334 |
Installed a new 100 amp alternator, new center console and gear shift. Going to wash her up tomorrow and get her ready for her trip to Texas.
71 Chevy Stepside 377/350 |
#2335 | |
"brand new second-hand"
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
#2336 |
Old Skool Club
![]() Join Date: Jun 2001
Unloaded the freshly sandblasted/painted brake drums, 1-inch stabilizer bar, upper and lower control arms and transmission crossmember from my '96. Mocked up the transmission crossmember, then posed a question on here about correct placement.
Life is good.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#2337 |
Hadn't driven mine since yesterday, so i drove it up to the beer store, you know just to keep it limbered up and used to hauling something.
#2338 |
Drove it to the Midwest meet.....
Great guys.....Great trucks.....
'71 Chevy LWB all OG '86 Chevy LWB all OG It's all a matter of perception |
#2339 |
laying low
![]() Join Date: Mar 2001
What is it that Cap Fab booster bracket is supposed to do?
#2340 |
New front shocks. Monroe Gas from ebay for $28 shipped. Old ones were nicely preserved in grease though.
#2341 |
motor exploder
That intake came out nice!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac ![]() ![]() Use the SEARCH function on this forum - it is your friend!! Last edited by BossHogg69; 06-05-2011 at 01:17 AM. |
#2342 |
I relocated my Prop Valve to the frame, then I flared and bent my own brake lines.
Also installed my fender well after remolding it to get rid of some factory bends that do not need to be there to give it a clean smooth look.
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
#2343 |
installed new 6in rods and pistons
Always remember those that had your back Never forget those that turned it Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt, Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner |
#2344 |
looked at it and scratched my head alot... put the rear dr side wheel back on. alot of work to do.....
Dan <---(my name) 67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car |
#2345 |
Started DA-ing my cab. It doesn't take long once you start sanding to see just how messed up your stuff is. These trucks really were built as trucks, go figure.
#2346 | |
Hand Crafted C-10
![]() Join Date: Aug 2006
Did you route those inside your fenderlip into the core support area? Really clean and something I've always wanted to do! |
#2347 | |
I routed them straight down to the frame and bent the right side one far enough to line directly up to where it connects. I will have to either pull it away from the firewall a bit more or purchase some fasteners to keep it from vibrating and rubbing along my firewall, at the time I was more thinking of a clean look and didnt cross my mind about vibrations. also I was thinking on modifying my fenderwells to cover all the way over the frame to hide some extra area's so they may have to run through my fenderwells any how.
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 Last edited by Jeffs70; 06-06-2011 at 01:16 AM. |
#2348 |
yes, i do
hey jeff, some adel clamps should do ya just fine for the anti chaffe.
#2349 |
Powder coated my muncie 4 speed chrome color, now I just have rebuild it.
Brad handshoe |
#2350 |
Installed new door window channels, painted my arm rests, ordered molded rubber floor mat and stainless sill plates. Slow but sure, it is coming together.
