Old 06-25-2011, 05:48 PM   #1
tazman87
tazman87's Avatar
transmission controlled spark switch
what is it and why do i need it. it is not connected at the moment.
tazman87 is offline   Reply With Quote
Old 06-25-2011, 05:52 PM   #2
tazman87
tazman87's Avatar
Re: transmission controlled spark switch
also i'm having problems with the choke. even after it warms up and flipping choke down manually. burp the gas and it flips back up. any ideas?
Old 06-25-2011, 06:43 PM   #3
MadManAndrew
If you can flip your choke down manually, I'm going to assume you're missing your choke controls. You can get a choke cable from any auto shop, or a block mounted heat riser thingamajig from a junkyard. As for the tranny thing, I have no idea.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 06-25-2011, 08:40 PM   #4
geezer#99
geezer#99's Avatar
The tcs switch controlled an electric solenoid. The vacuum from your carb went to it. Another vac line went to your vacuum pot on your dizzy. Was there so you only had vacuum advance in top gear. For emissions and mileage. You can bypass it.
I assume electric choke. Set up too rich. Loosen screws on black cap and move it to a leaner position. Should be marked on cap.
geezer#99 is online now   Reply With Quote
Old 06-26-2011, 12:38 AM   #5
tazman87
tazman87's Avatar
ok thx
