Old 06-28-2011, 10:09 PM   #1351
kev2809
low n' slo
kev2809's Avatar
Re: 1967 C10 Custom Big Window
"done"?? wtf is that? lol
hoping to get it road worthy next year so i can DRIVE it to your shop...plush i wouldnt mind checking out ronnies '39...
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 06-28-2011, 10:21 PM   #1352
Slick67
Sofa King Crazy!!
Slick67's Avatar
Cool, that sounds like a plan. Maybe he will have the 39 close to driveable by then.
You found the Tater.
My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650
My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650
67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS.
1972 2wd Blazer "Porterbuilt and Sloshed"
Slick67 is offline   Reply With Quote
Old 07-02-2011, 05:06 PM   #1353
Slick67
Sofa King Crazy!!
Slick67's Avatar
Got a little done today. I cleaned and painted my intake so it would look as clean as the engine when it goes back together and also took a couple of pics of how they gave my engine back to me. Chipped paint, grease, different color paint on the front and just sloppy lookin work alltogether. The harmonic balancer was perfect, now not so much. They also scratched my timing chain cover really bad. I drove all over town looking for 5/8 fine thread all thread rod so I could extend my panhard bar, but couldn't find any.
Old 07-02-2011, 05:21 PM   #1354
VA72C10
VA72C10
VA72C10's Avatar
Well, that thoroughly stinks...
....are you going to sand and repaint it? What's your ETA on starting it up (out of the truck)?
Old 07-02-2011, 08:44 PM   #1355
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
That blows goats hope to hear you have it back up and running soon..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 07-02-2011, 11:20 PM   #1356
Slick67
Sofa King Crazy!!
Slick67's Avatar
Yep, sanding it lightly and having the whole thing repainted. Should be able to have it all together so I can crank it in a couple of weeks, if everything goes right.
It will be, just having to be a little more patient than I want to be right now. But it will look better this time around!!
Old 07-03-2011, 04:36 AM   #1357
Jeffs70
Jeffs70's Avatar
hey slick glad to see you got it back but sad to see it in the shape its in. hope you get it all worked out for you. are you going to bench start it first to make sure it dont leak and all that before putting it back in? just an idea maybe.
Jeffs70 is offline   Reply With Quote
Old 07-03-2011, 09:37 AM   #1358
Slick67
Sofa King Crazy!!
Slick67's Avatar
Absolutely. Hopefully there is no issues but it will give me a little peice of mind before it is back in the truck. It will have to be painted before I put it all back together so hopefully it's good!!
Old 07-03-2011, 11:19 AM   #1359
68 TT
Still plays with trucks
68 TT's Avatar
At least you got your engine back.
There are two Chevy oranges. From what I understand one was used on big blocks and is a little darker and the brighter one was used on small blocks. I always use the darker one on everything just because I like the color better.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 07-03-2011, 11:26 AM   #1360
68 TT
68 TT's Avatar
...I drove all over town looking for 5/8 fine thread all thread rod so I could extend my panhard bar, but couldn't find any.
If you can't find any Fasteners can ship it to you.
Grade 8, 5/8" fine threaded rod, 36" length $33.21
http://www.gotbolts.com/index.jsp?pa...D,GRADE.8,FINE
If you call them up they might be able to sell you a smaller length.
If you have to buy the 3' length then get a couple nuts to go with it and thread them on behind where you are cutting it down. After you make the cut and grind the chamfer onto the cut end then thread the nuts off over the cut end. It will straighten out any area of the threads that were damaged by the cutting process.
Old 07-03-2011, 04:10 PM   #1361
kev2809
low n' slo
kev2809's Avatar
is this the shop that fixed it?
in wonder how the hell they could have messed up your paint and stuff..?
-_--_--_ _________
Old 07-03-2011, 07:31 PM   #1362
Slick67
Sofa King Crazy!!
Slick67's Avatar
My engine is painted to match my truck so it has to be repainted completely with the candy and pearl........sux.
Yep, they are the culprits of this travisty. It's obvious they really don't give a sh*t about there customers items. I even asked that they try to be careful of the paint on other peices than the block, well, that didn't work. Thanks alot Motor City Motors!!!!!!
Old 07-03-2011, 10:21 PM   #1363
68chevyLQ4
68chevyLQ4's Avatar
I had the same type of bad experience with a shop I took a truck too for chassis and suspension work.. Man it is stressful. I wanted to go hurt the guy but I know better then that. Was supposed to have my truck three months and he had it a year and a half
68 Chevy C-10. swb fleetside. 6.0 4L80E swap.
http://67-72chevytrucks.com/vboard/s...d.php?t=460877
68chevyLQ4 is offline   Reply With Quote
Old 07-04-2011, 08:35 PM   #1364
Slick67
Sofa King Crazy!!
Slick67's Avatar
I suppose that we hear alot of bad stories, but we don't hear the good ones cause there is no stress that goes with it. I just hope the fix is going to work and it won't have to be taken back.
Old 07-05-2011, 02:46 AM   #1365
slick copper
slick copper's Avatar
Hope it works out for ya bud. We're all waiting for the good news!!
Raymond
1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594
The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939
Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402
slick copper is offline   Reply With Quote
Old 07-05-2011, 06:18 PM   #1366
Slick67
Sofa King Crazy!!
Slick67's Avatar
Yep, me too. I can't wait to post up how great everything is going, unfortunately it'll be a little while. Taking a vacation and really won't be able to do anything to the truck for about 2 weeks, errrrrrrrrrr.
Old 07-06-2011, 03:02 PM   #1367
my67chevytruck
Under Construction
my67chevytruck's Avatar
Great News David!
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 07-06-2011, 08:23 PM   #1368
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Wow, looks like a perfectly nice junkyard core! Glad to see it's back in your posession, glad to know that the shop got their name out there on a sight that so many people go to for referrals and advice! Good luck getting it all back together Slick!
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 07-06-2011, 08:30 PM   #1369
Slick67
Sofa King Crazy!!
Slick67's Avatar
Originally Posted by my67chevytruck View Post
Great News David!
Hey Heath! Hope you are well, haven't heard from you in forever. It is really good news and hopefully it will be painted in about 3 weeks. I'll stop by your build site.
Hahhaha. Yeah they really deserve the publicity!! I gotta have it painted before I put it all back together and hopefully it won't have to be pulled back apart!!
Old 07-07-2011, 10:59 AM   #1370
68 TT
68 TT's Avatar
I have weld repaired a few cracked / damaged blocks, cylinder heads and rear end center sections. It is hit & miss on whether the part will develop a new crack adjacent to the welded area. It all depends upon why the crack was there in the first place. If it was metal fatigue from repeated stress it is more likely to crack again but if it was an impact crack from being dropped or hit in an accident it is less likely to crack again.
We don't know why your block cracked where it did and I am afraid it may develop a new crack in or near the repair area.
I know it is a pain but I think it is worth it to drop the engine in the truck, run it up to temp and let it cool down at least four times before you put the effort into painting it again. You really need to heat cycle that repair a few times to make sure they got it all fixed and that what they did to fix it is going to hold.
I would be inclined to strip off the paint in the repair area to see what is under it and so you could see if the oil is still making its way out the repair area sooner during the heat cycle process. You need to do this part anyway as prep for the new paint so all you are really out is a little time in stabbing the engine in and pulling it back out.
Our trucks are pretty simple so it shouldn't take you more than an hour to do the install and then the removal after the test run heat cycle process on the repair.
You can leave the hood off and run it on straight water to make things easier and reduce the work & possibility of paint damage to the truck.
I know the time, effort and money that will need to go into prepping and painting the block again. I don't want to see you have to go through that a third time if the block repair doesn't hold.
Old 07-08-2011, 04:29 AM   #1371
slick copper
From one Slick to another I think 68TT is right. Probably be a good idea to drop it in even thought it's a pain and run it a few times to make sure it's gonna be good before you get it all show quality again. PIA I know, but you'll be glad if it was to unfortunately start leaking again. Good luck buddy.
Raymond
Old 07-09-2011, 12:10 AM   #1372
dlblzr
dlblzr's Avatar
Nice work. I have alot of work to do as well.
dlblzr is offline   Reply With Quote
Old 07-11-2011, 12:55 PM   #1373
Slick67
Sofa King Crazy!!
Slick67's Avatar
Thanks Bro! I like the flags on the fenders!!! You do have your work cut out for ya, but you are starting with a great platform!
Old 07-12-2011, 09:32 AM   #1374
68Driver
68Driver's Avatar
What fuel cell did you go with? I'm debating whether to go with a plas
tic or steel tank. That tank look like it fits real well. Where did you order it from? Thanks Shawn
68Driver is offline   Reply With Quote
Old 07-12-2011, 02:18 PM   #1375
67chevy1series
67chevy1series's Avatar
sorry to ehar the engine came back in a good shabby state lol. keep it up slick.... remember dont become slacker67!
67chevy1series is offline   Reply With Quote
1967, custom, lwb
