Anyone have power steering pump pic's
Looking for some pictures on power steering mounting hardware, i bought a bracket at longbeach swap meet but i don't think it's the right one. anyways any pictures will help.
Re: Anyone have power steering pump pic's
What motor?
Here is a shot of the pump being installed:
1. from the drivers seat with the steering arm http://kieth.smugmug.com/Trucks/66-G...76075194_7Zf6Y 2. from the front: http://kieth.smugmug.com/Trucks/66-G...76075211_oopYL 3. Inner frame reinforcing plate: http://kieth.smugmug.com/Trucks/66-G...76075235_sCxRb this is the kit from classic chevy, cpp, etc.....did not know captaing fab at the time. Kieth ps power steering pump was from a 91 suburban 2 wd 1/2 ton. |
Nice. More info!!
You looking for the pump brackets on the motor or the PS box brackets on the frame. |
#6 | |
![]() Join Date: Aug 2005
#8 | |
Who Me?
Nuttin fancy here, but it works.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
So it's a 283 so no holes in the head then. Here's a bracket on ebay that might work.
http://cgi.ebay.com/ebaymotors/NEW-5...Q5fAccessories |
http://www.scribd.com/full/17608177?...qy43h7a9pmdutn
I think you might be looking for this...on page 113
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
60-66 Nut
If your 283 still has the original short water pump, you will need brackets, pump and the pulley from a '68 and older car, or a '72 and older truck. Those parts can usually be found either on ebay or here on the forum in the '67-72 classifieds. The truck parts seem to be easier to find.
Here is one setup minus the pump http://www.67-72chevytrucks.com/vboa...d.php?t=474688 And here's a guy with just about every bracket imaginable..... http://www.67-72chevytrucks.com/vboa...d.php?t=439166
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 07-15-2011 at 12:59 AM. |
#15 |
#16 |
#17 |
Never Ending Projects
I used my '68 C10 bracket, which stock is a short water pump. In my '65 it was changed over to a long water pump. I was able to add three washers to the main part of the mount (where it attaches to the block) and cut and re-weld the rear bracket (where it mounts to the motor mount).
Not a great pic but you can kind of see what I did. Again, this was a stock '68 C10 bracket and pump. ![]()
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#18 |
#19 |
#20 |
#21 |
#22 |
#23 | |
#24 |
60-66 Nut
How about posting a couple pics of what you have. Then we can help you figure out how to use what you have instead of just random pics and suggestions.
#25 |
