Old 07-17-2011, 08:27 PM   #76
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Project: Ginger
Small update:
Installed the PB hood hinges today.
Also installed the Wilwood master cylinder so I can run my remaining two brake lines.
Also removed the old door gaskets and installed a set of GMCPauls "push-on style" door gaskets.
These are really nice!
I recommend them.
Started to installed my Lokar throttle cable to the 71-72 gas pedal assembly.
I need to machine a piece, to make the connection at the gas pedal.
I'll take pics when I have more to show.
Keith
Convert to disc brakes.
Old 07-17-2011, 08:27 PM   #77
Dinos63
chevy only
Dinos63's Avatar
Re: Project: Ginger
kEIth great job!! love the step side the color and the chassi is perfect nice build brotha!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 07-17-2011, 08:29 PM   #78
lolife99
lolife99's Avatar
Re: Project: Ginger
Originally Posted by SCOTI View Post
Nice job. You're already ahead of me.....
I'm pretty sure you are ahead of me.
You have everything thought out already.
You'll pass me when I'm in the "scratching my head" phase.
Keith
Old 07-17-2011, 08:38 PM   #79
litew8
litew8's Avatar
Re: Project: Ginger
You are correct and I was incorrect.
I just looked at the glovebox door and it says "4522 Bronze".
My buddy had some old 1970 paint books,... and the 522 code said "Copper Poly".
Thanks for the correction.
Is your truck a '70 or '71?
Very cool. Mine is 71'.
Eventually I may need that color code! But wait... Copper Poly and Bronze considered the same? Or are you saying his book was wrong?
litew8 is offline   Reply With Quote
Old 07-17-2011, 08:53 PM   #80
lolife99
lolife99's Avatar
Re: Project: Ginger
I would call it Bronze.
The "Copper Poly" name came from a DuPont color chip page from 1970.
Here's a pic of the same page.
The color is off in this photo,...
Keith
Old 07-17-2011, 09:28 PM   #81
litew8
litew8's Avatar
color
Strange, I get confused easily.
Look at these pages for 71'. Only "copper poly" shown (and has an * = only 71') - but no bronze, med. bronze or bronze metallic. Why would my SPID say anything bronze? lol
The webpage itself mentions "dark bronze poly" above, but it isn't on the spec sheets.
Maybe it's a "special equipment color"??
http://www.chevyinfo.net/?page_id=562
Old 07-17-2011, 09:32 PM   #82
lolife99
lolife99's Avatar
Re: Project: Ginger
I was just as confused.
The "4522" Bronze on the glovebox door, goes with the *522 listed next to the copper poly name on the DuPont page.
Keith
Old 07-17-2011, 09:49 PM   #83
litew8
litew8's Avatar
Re: Project: Ginger
Cool. So the exterior matched your interior nice? I'll have to remember "copper poly" and not bronze. So the manuf. decided to name it differently on the printed SPID. I'm guessing nobody has a SPID that says "copper poly".
Old 07-17-2011, 09:53 PM   #84
lolife99
lolife99's Avatar
Re: Project: Ginger
The color matched the truck nicely.
I have painted the heater delete plate and the radio delete plate with the new paint.
So we'll see how it looks.
I took the buffer to the dash to make the 40 year old paint shine a little,... but the paint so thin,... it wants to burn thru to primer.
Keith
Old 07-18-2011, 05:09 PM   #85
70k52wd
Blaze-Air
70k52wd's Avatar
Re: Project: Ginger
Looking good...really nice hinges.
70k52wd is offline   Reply With Quote
Old 07-18-2011, 05:12 PM   #86
VA72C10
VA72C10
VA72C10's Avatar
Re: Project: Ginger
Love the black with copper/bronze/whatever combo you have going on!!!
Old 07-18-2011, 09:50 PM   #87
lolife99
lolife99's Avatar
Re: Project: Ginger
I needed to finish my Lokar gas pedal cable install.
Since I have no welding skills I fabbed up a cable adapter for the Lokar cable.
This will connect to the 71-72 pedal assembly that I installed with Rokcrln's LFD Gas Pedal Adapter.
(http://67-72chevytrucks.com/vboard/s...d.php?t=371099)
It worked great,... but I found out the stock 71-72 plastic gas pedal bushing is wore out.
Seems like there is always something I need to order,... no matter how well I plan ahead.
Finished the door gasket install.
Spent the rest of the night screwing with my shop air compressor.
The check valve is bad,... so I need to order that now.
(I finally start doing something and the air compressor craps out)
Keith
Old 07-18-2011, 10:11 PM   #88
jmedero
jmedero's Avatar
Re: Project: Ginger
Keith I have a question. Your wilwood master cylinder does not have a booster. Many of the ones if seen don't. Are the manual or power brakes? I've always wondered that.
Sorry for the stupid question.
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 07-18-2011, 10:16 PM   #89
lolife99
lolife99's Avatar
Re: Project: Ginger
Manual disc.
I think it cleans up the firewall.
My red '69 has manual disc and it does just fine.
Most of the plain (low optioned) base trucks in '71 and '72 (factory disc brake trucks),... did not have a booster from the factory.
Keith
Old 07-18-2011, 10:45 PM   #90
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Project: Ginger
Keith....can you share with me what these items are and where you found them...I like that alot!!!...did ya use Lokar universal cable??
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 07-18-2011, 10:59 PM   #91
lolife99
lolife99's Avatar
Re: Project: Ginger
I have the plain black universal Lokar cable.
The adapter I machined at work.
A 5/16"x 5/8" bolt works perfect in the gas pedal hole.
Since I had no way to weld a loop to it,... so I machined that adapter at work from some 5/8" round stock.
I drilled a 3/16" hole in it to accept the pin from the Lokar adapter.
Some people heat and twist the oem gas pedal rod.
(or cut and reweld the end 90 degrees from original)
Mine was already blasted and painted,... so I had to do something else.
Keith
Old 07-18-2011, 11:13 PM   #92
m6z
m6z's Avatar
Re: Project: Ginger
Very nice. You didn't happen to make an extra did you? lol.
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 07-18-2011, 11:14 PM   #93
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Project: Ginger
ok...got ya....thanks for the info....I have a pedal assembly that I was gonna have cut and reweld, but thought if this was easy enough and materials could be found at the local hardware store without having to cut, then I'd go that route instead
Geoff with a G
Old 07-18-2011, 11:15 PM   #94
lolife99
lolife99's Avatar
Re: Project: Ginger
No.
We don't get much machine time at work.
Keith
Old 07-19-2011, 01:43 AM   #95
CheyenneShop
CheyenneShop's Avatar
Re: Project: Ginger
Just getting a first look at your "Ginger" and she is hot, smoking HOT! Can't wait to see how she lays
72 Cheyenne shorty "CheyLow"
72 3/4 long 4X4
69 SWB "Prospector"
68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled"
Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com
CheyenneShop is offline   Reply With Quote
Old 07-19-2011, 01:02 PM   #96
69CST-V
69CST-V's Avatar
Re: Project: Ginger
Great work. Looking nice and clean.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 07-19-2011, 10:20 PM   #97
lolife99
lolife99's Avatar
Re: Project: Ginger
Thanks guys.
I can't wait to see it on the ground and done.
(at least driveable)
I got home late tonight and found the UPS truck had been here.
I got my "sandlewood" dash pad from Brothers Truck Parts.
This is one of the "Made in the U.S.A." dash pads.
The quality is definitely better than the other aftermarket dash pads I have had,... but there were a few "finished" areas on the upper and lower edges that I didn't like too much.
Not terrible,... but just sloppy.
(I guess these are the areas of the dash pad, that are trimmed off after they come out of the mold?)
I'm being too picky,... so I just went ahead and installed it.
I gotta keep plowing forward,...
Keith
Old 07-19-2011, 10:42 PM   #98
litew8
litew8's Avatar
Re: Project: Ginger
I think I can see the "lower" part you don't like. Above the cluster and near the radio? If it were me, I'd send it back and get a replacement.
Old 07-19-2011, 10:50 PM   #99
milner
milner's Avatar
Re: Project: Ginger
Looks good man, between your's and n2billets I really want a stepside now
355,vortec heads, Doug Herbert cam, Performer intake, 750 Holley, Hooker Comps, 2 1/2 duals w/Aero Chambers, 2500 stall and 3.73 posi.
milner is offline   Reply With Quote
Old 07-19-2011, 10:52 PM   #100
lolife99
lolife99's Avatar
Re: Project: Ginger
I think what you are seeing,... is the recessed holes for the lower screws.
I may call Brothers and ask them about it.
I'm sure they have no answers.
They just sell them.
I doubt that they manufacture them.
Keith
