Old 07-22-2011, 12:31 AM   #1
ghettoluxury
ghettoluxury's Avatar
Front suspension Question
Will 1 ton spindles bolt up to my 1/2 ton control arms or will I need to get the control arms off of the truck as well?
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 07-22-2011, 11:04 AM   #2
Desert1957
Desert1957's Avatar
Re: Front suspension Question
No, But send Forum member "PigRig" a PM message. he is good with 1 ton suspension questions..
Desert
Desert1957 is offline   Reply With Quote
Old 07-22-2011, 01:43 PM   #3
SCOTI
SCOTI's Avatar
What year suspension?
On 6x-87's, the upper a-arms share a standard bolt pattern on BJ's so the 1-ton BJ's can be used. The lower arms use different press fit BJ's w/the 1-tons a larger diameter. You would need 3/4 or 1-ton specific lowers to use 1-ton spindles.
88-98's I believe are a direct swap.
That being said, be aware the 73-87 3/4 & 1-ton upper a-arm shaft utilizes larger diameter studs to secure them to the x-member (where the shims go for aligning). So the upper arms can't be swapped w/o mods. I'm not sure how big of a deal it makes though since the load is on the lowers (upper studs = 1/2 ton @ 1/2"; 1-ton @ 9/16").
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-22-2011, 02:23 PM   #4
ghettoluxury
Thanks guys. I have a 79 that I want to convert to use my 20's with and my buddy is parting out an 85 6.2L 1-ton so I can get everything I need off of that truck.
