Old 07-26-2011, 10:56 PM   #1
bradford
What??
http://austin.craigslist.org/cto/2478856092.html
What the hell is this guy talking about?
bradford is offline   Reply With Quote
Old 07-26-2011, 10:58 PM   #2
camshaftgsxr
camshaftgsxr's Avatar
Re: What??
4.3? i donno could be just another crazy, could be a guy that knows his stuff but has trouble explaining.
camshaftgsxr is offline   Reply With Quote
Old 07-26-2011, 11:00 PM   #3
lilpoindexter
lilpoindexter's Avatar
Re: What??
4.3...I understood the geezer perfectly
lilpoindexter is offline   Reply With Quote
Old 07-26-2011, 11:12 PM   #4
bradford
Re: What??
Yeah I was kinda thinking this as well but that makes it sound like there is a V-8 in it with the back two cylinders empty or something.
Terrible explanation.
Old 07-27-2011, 12:02 AM   #5
8T1stepper
8T1stepper's Avatar
Re: What??
Maybe you could use the other 2 cylinders for an onboard compressor.......
A smith compressor uses a ford 302 with one bank to run and one bank as a compressor.
Some say "The glass is half empty."
Some say "The glass is half full."
I say "the glass is twice as big as it needs to be, chop it off!!!
8T1stepper is offline   Reply With Quote
Old 07-27-2011, 12:45 AM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: What??
Not bad for a starter project.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 07-27-2011, 12:52 AM   #7
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: What??
call him an ask him if he can unblock the cylinders and throw in two more pistons for you HAHA
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 07-27-2011, 01:04 AM   #8
rcflyer1234
rcflyer1234's Avatar
Re: What??
GM must have ran out of 4.3 blocks when that truck was built so they just used a 350 block and modified it.
Still a nice truck though.
rcflyer1234 is offline   Reply With Quote
Old 07-27-2011, 01:33 PM   #9
veinbar
veinbar's Avatar
Re: What??
Has anyone called this guy? I live in South Austin. I may have to see this one of a kind engine for myself;-)
veinbar is offline   Reply With Quote
Old 07-27-2011, 01:36 PM   #10
88Jimmy4x4
88Jimmy4x4's Avatar
Re: What??
lol...please do I want pics
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 07-27-2011, 11:58 PM   #11
67_SS396
Re: What??
The 4.3 has the same bore/stroke as a 350. I remember when they first came out all the talk about it being just like a 350 with the rear two cylinders cut off.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 07-28-2011, 12:15 AM   #12
cheepin
Re: What??
I worked with a guy that swore up and down that was how GM made these.Dude was always right so you couldn't correct him.You know the type.
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14,
cheepin is offline   Reply With Quote
Old 07-28-2011, 10:41 AM   #13
motornut
78K & 79C Jimmys
motornut's Avatar
Re: What??
thought the 229 was with two removed......never heard or seen this
took out a 229 put in a 350 quite ez
can't just be loose floating parts?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 07-28-2011, 10:55 AM   #14
67_SS396
Re: What??
A 4-3 is a v6 block, simple as that, there are not any "open" cylinders. The '85-up 4.3L V-6 has the same bore and stroke as a 350 V-8 (4.000x3.480), and takes the same pistons, cam bearings, main bearings, valvetrain parts, timing cover, oil pump, and front dress.
RevLimit Offroad
Old 07-28-2011, 11:06 AM   #15
motornut
78K & 79C Jimmys
motornut's Avatar
Re: What??
lookin it up the 229 stopped and changed to 262? in 85
mine was 81
sounds like the earlier one had even more in common, in parts
John
Old 07-28-2011, 11:11 AM   #16
67_SS396
Re: What??
The 229 has a bore/stroke the same as a 305 whereas the 4.3 has a bore/stroke the same as a 350. 305 parts are interchangable with the 229 and 350 parts are interchangeable with a 4.3.
RevLimit Offroad
Old 07-28-2011, 11:13 AM   #17
motornut
78K & 79C Jimmys
motornut's Avatar
Re: What??
good to know thanks
I had always just heard and compared it to a V8 with two cylinders removed
John
Old 07-28-2011, 11:59 AM   #18
jrcaprai
Re: What??
I emailed him....
jrcaprai is offline   Reply With Quote
Old 07-28-2011, 12:10 PM   #19
veinbar
veinbar's Avatar
Re: What??
Originally Posted by jrcaprai View Post
I emailed him....
Dude, you should post your email and the conversation that ensues?
Old 07-28-2011, 12:53 PM   #20
jrcaprai
Re: What??
I will...
Old 07-28-2011, 01:06 PM   #21
gchemist
gchemist's Avatar
Re: What??
Get an address or phone number. I'll drive by and take a pic of the mysterious engine.
Old 07-28-2011, 10:31 PM   #22
motornut
78K & 79C Jimmys
motornut's Avatar
Re: What??
http://67-72chevytrucks.com/vboard/s...d.php?t=476734
he's looking for picks of the power steering for that block
John
