Old 07-31-2011, 11:28 PM   #1
ky_kid
ky_kid's Avatar
Replacing windshield seal
I have a very small leak I traced to the lower drivers side corner of the windshield. I am going to replace the seal I think, how difficult of a task am I approaching? I'm confident I can do it I just never have.
84 K10 Custom Deluxe: 350 crate engine w/ 4" lift
ky_kid is offline   Reply With Quote
Old 07-31-2011, 11:51 PM   #2
Telecasterjoey
Re: Replacing windshield seal
The whole rubber gasket around the windshield? Its a Pain in the a$$ but can be done with patients lol I've done it, just pull out the retaining strip and pop the windshield out. I was able to do it alone and without breaking the windshield. Best of luck!
Telecasterjoey is offline   Reply With Quote
Old 08-01-2011, 12:00 AM   #3
ky_kid
ky_kid's Avatar
Anyone have tips on the procedure? Or does anyone know about a thread that details the job? I would have at least one guy helping me I just don't wanna compound the problem by screwing up...
Old 08-01-2011, 02:18 AM   #4
juiceman650
juiceman650's Avatar
I remember I saw a tv show that had tips on replacing it, but I can't remember what show it was on. Ill post it if I can think of it.
juiceman650 is offline   Reply With Quote
Old 08-01-2011, 10:29 PM   #5
cjlinkster
cjlinkster's Avatar
It'll be a two person job. It's not too hard though, and I bet that you could find a video on the internet.
You basically will be using a piece of string/rope to get the glass to go into the new seal. One person will need to be holding the glass, while the other person slowly pulls the rope causing the seal to accept the glass between the outer and inner seal.
nothing to it. should take around 30 minutes with a 2nd person helping out.
1984 C20, 454, 4 speed named "Gold Member"
cjlinkster is offline   Reply With Quote
Old 08-01-2011, 10:31 PM   #6
cjlinkster
cjlinkster's Avatar
If it is just a small leak.... a little bit of black silicon sealant may work just fine. I would try that first.
Old 08-02-2011, 09:34 AM   #7
dropd80s
dropd80s's Avatar
I wouldn't. If water is getting under the seal it needs to be replaced. Depending on where you place your silicone you could cause water to be retained, rusting out the windshield frame underneath, if its not already.
"I'm Dirk Diggler enough to own and operate a vehicle of this caliber" -veinbar
Dropped and LS Swapped SWB 87 Build Thread
dropd80s is offline   Reply With Quote
Old 08-02-2011, 10:26 AM   #8
ky_kid
ky_kid's Avatar
I shined a flashlight under the dash and can see some rust that has started where water is coming through about the size of a quarter. I don't think there is too much rust but how risky is it to take the seal out? I mean could I get myself into a much more expensive problem?
