frying your HEi coil and pickup
hey all,
just a note to all who may be installing better guages. I unknowingly fried my coil and pickup in my MSD streetfire ignition by accidently (??) grounding the tach lead while connected to distributor and in the engine. Must have happened when putting the guages in. Result was erratic stalling, hard starting, a nervous tach needle that looked like a heart monitor (up and down spikes). See this link if you need info- very bottom of page is note about avoiding this. Also good info for testing out you dizzy pieces. http://www.angelfire.com/realm2/84ca...coil/coil2.htm
![]() 76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262 http://beerbreadbike.wordpress.com/ |
78K & 79C Jimmys
Re: frying your HEi coil and pickup
guess i'm lucky mine didn't fry when i hooked up mine
was shorted to the side
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
did you not disconnect the battery?
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] ![]() 1999 k3500 crew cab dually 6.5tdi/4l80e |
78K & 79C Jimmys
me?mine was the tach signal
just need to clarify that it was the cold and module under the rotor, not the pickup at the shaft of the rotor. see picture attached. flat black plastic piece between screws is module.
| Bookmarks |
