Old 09-30-2011, 03:49 AM   #1
moose666
spindles spindles spindles
ok everybody im looking for some information if possible. so my truck has some knock off no name spindles and a buddy of mine has some belltechs on his 78 c10 looking at them booth you can deffinatly see a difference. so im going to buy new ones.
so my question to everyone out there is what kind of spindles do you think are best to run for these trucks????? i have looked at belltech,mcgaughys,ccp has some dont know who makes them but they look ok.. so any information on this would be awesome many thanks for the help.
moose666 is offline   Reply With Quote
Old 09-30-2011, 07:52 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: spindles spindles spindles
Belltech, McGaughy's, CPP, Western Chassis, are all good spindles.
Make sure you measure the width of your rotors before you order.
They make 2 different spindles for 73-87 trucks.
HD 1.25" wide rotors and LD 1" wide rotors.
I like Belltech spindles best.
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 09-30-2011, 08:10 AM   #3
lilpoindexter
lilpoindexter's Avatar
Summit house brand
lilpoindexter is offline   Reply With Quote
Old 09-30-2011, 10:30 AM   #4
njlimbaugh
Definitely check the rotor thickness. I now have one set of McGaughy spindles for the 1inch rotor sitting in a box. My truck has 1.25 rotors! S&*%! Live and measure!!!
njlimbaugh is offline   Reply With Quote
Old 09-30-2011, 11:14 AM   #5
von guido
von guido's Avatar
summit branded spindles are Western,just put in a plain box.
officer,we weren't racing.. he was merely pacing me.
von guido is offline   Reply With Quote
Old 09-30-2011, 11:33 AM   #6
rwhit57
rwhit57's Avatar
I have Belltech's but I have used others. Actually I haven't had any problems with any of them. I had to do a lot more grinding on the Belltech's than any others to get 15" wheels to fit. I don't see buying new ones if the ones you have are working for you.
rwhit57 is offline   Reply With Quote
Old 09-30-2011, 03:21 PM   #7
Nukes16
Nukes16's Avatar
What do you grind? My lower A-arms are in the way of the rim but I don't get how I can fix this by grinding the spindle???
Nukes16 is offline   Reply With Quote
Old 09-30-2011, 03:43 PM   #8
bigwheel15
bigwheel15's Avatar
Define "see a difference" in spindles with yours vs. your friends. Seems interesting.
bigwheel15 is offline   Reply With Quote
Old 09-30-2011, 04:06 PM   #9
faribran
Nukes, i am with you.... thatz what mine are doing... not a spindle problem..
faribran is offline   Reply With Quote
Old 09-30-2011, 04:21 PM   #10
karl
karl's Avatar
I have Western 2.5 drop. Work OK. Bought some DJM 3 inch and will swap out when i do my bags.
karl is offline   Reply With Quote
Old 09-30-2011, 04:24 PM   #11
karl
karl's Avatar
Rotors are cheap. Buy a new set of rotors. I have 1 in now but my new spindles are 1.25 and will upgrade rotors then.
Old 09-30-2011, 06:28 PM   #12
rwhit57
rwhit57's Avatar
You have to grind the a-arm to cure that. You can take off enough to clear, just don't get into the radius. Look where it's rubbing and start removing a little at a time till it clears. You will have to check it full lock to lock. It's a pain taking the wheel on and off, but take your time. Mine like a lot of others running 15" wheels actually rubbed the spindle itself where the caliper mates up also, but there is plenty of material there to remove.
Old 09-30-2011, 06:33 PM   #13
rwhit57
rwhit57's Avatar
You also have to change the calipers and all the bearings.
Old 09-30-2011, 06:40 PM   #14
rwhit57
rwhit57's Avatar
I found a pic of my a-arm. I had to remove a lot to clear my old Americans, but I'm not into the radius. Plenty of miles no problems. Pic is cell phone but you can get the idea.
Old 09-30-2011, 08:30 PM   #15
lilpoindexter
Mine were ground force...not sure if they change them every so often.
Old 09-30-2011, 08:52 PM   #16
gGMC DOG
Mine were ground force to
gGMC DOG is offline   Reply With Quote
Old 10-03-2011, 11:15 PM   #17
1LowToy
The 2.5" spindles are the way to go. The 3" ones is where you may(make that will) need to grind on the lower contol arm for 15x8 rally wheels which is not a pretty thing. Don't go hog wild with lowering springs or you will have ground clearance issues too.
1LowToy is offline   Reply With Quote
Old 10-04-2011, 12:55 AM   #18
von guido
von guido's Avatar
I used to work for summit..When a manufacturer has a overrun summit or jegs buys the extra and says its theit "private label". In reality it can change month to month depending on the market. I opened up a set on "summit" sbc heads and they were Dart Iron Eagles,even had the paperwork from dart with them! My spindles were western and got em for 180 bucks with my summit bucks. They ride great and have no issues
