#26 |
Re: Need some 292 guidance
Not sure and don't know. I've yet to take the bottom end apart. That's good to know, I'll be looking out for that. Thanks for the tip.
Beauty is in the eye of the beer-holder. Praise the lowered! |
#27 |
Had the head rebuilt. Now on to the block. Any one want to recommend and an engine paint? I'm between eastwood and POR15.
And still collecting these 292 parts slowly - boy are they hard to come by! I've been looking all over for a thermostat housing and I'm only finding ones for the 250.
#28 |
It's the 12 lobe crank. I finally got the motor on the stand. It looks like a stock GM cam - it's stamped with GM32, anyone know where I can find info on the cam?
#29 |
Picked up an offy valve cover this weekend, but it doesn't have the hole for the PCV setup. I'm wondering if there is an alternative set up for the 292 that works as well as having the other valve cover with the PCV hole. I understand why I need it, so I'd like to set something up. Any advice or pics???
#30 |
so easy a caveman can do it...
![]() Join Date: May 2006
Subscribed. I'm going to be tearing into mine soon too
#31 |
OK, did some digging on this site and came up with what looks like an acceptable solution. Anyone see a problem/limitation with this configuration?
#32 |
That setup should be fine, just make sure you have a baffle under the pcv / breather so you don't have trouble sucking oil splashed up from the rockers. Good luck, 292's are pretty cool engines!!
Sean "If your gonna be dumb, you gotta be tough" 1960 Chevy Impala Sedan - my 25 year search is over!! 1969 C-10 longbed - Nice day DD ![]() 1970 Chevy Nova - Street and Strip Project ![]() 2002 Acura MDX my DD 2007 Honda Odssey - My Wife's "Mommy Van" |
#33 |
![]() Join Date: Feb 2002
Did you look in Leo Santucci's book?
