Old 10-03-2011, 12:12 PM   #1
rdlackey
1957 Deluxe Heater
I have a 1957 deluxe heater that I am re-doing for my 1957 Cameo truck. My questions is this. What COLOR should the heater box and fan be and what is a good source for a rattle can spray paint that would be close?
I want it to appear as original as possible.
Thanks in advance for your replies.
rdlackey is offline   Reply With Quote
Old 10-03-2011, 01:20 PM   #2
Dan in Pasadena
Dan in Pasadena's Avatar
Re: 1957 Deluxe Heater
Not sure how perfect you need to be but I'd use a Rustoleum hammertone gray
Dan in Pasadena is offline   Reply With Quote
Old 10-03-2011, 03:09 PM   #3
Knothead
Knothead's Avatar
The rustoleum Dan mentioned is what I used also. Well pleased with the color.
Knothead is offline   Reply With Quote
Old 10-03-2011, 03:40 PM   #4
Dan in Pasadena
We likum peechures!
Old 10-04-2011, 04:00 AM   #5
Daze57
Daze57's Avatar
if ya really wanna play your cards right - look hard enough on the heater box and you should find a date of manufacture - you can highlight that in white - subtle but classic
Daze57 is offline   Reply With Quote
Old 10-04-2011, 04:00 AM   #6
Daze57
Daze57's Avatar
dan you truck is really lookin nice --- very good work
Old 10-04-2011, 11:35 AM   #7
Dan in Pasadena
Oh thanks. I hardly get any time to work on it, then I get to it for a day or two and get frustrated when "stuff" gets in my way for another week or two.
Right now its blocked into my driveway by my camper and boat so I can't drive it. Besides the cluster is out of it and I can't start it with the oil line disconnected. So, I'm just piddling at it. Throwing more primer at it. Cleaning up the interior some, etc.
Old 10-08-2011, 03:43 AM   #8
dicer
Jim Carter truck parts has the info and paint
dicer is offline   Reply With Quote
Old 10-08-2011, 11:57 AM   #9
Dan in Pasadena
Hey lackey, whatever happened to our "Before" picture? You owe us one! lol
Old 10-08-2011, 12:20 PM   #10
tmoble
http://67-72chevytrucks.com/vboard/s...d.php?t=441585
one of my pics shows the hammertone pretty good, but it's not green as it looks there.
tmoble is offline   Reply With Quote
Old 10-08-2011, 04:39 PM   #11
rdlackey
here you go..."BEFORE"
Old 10-08-2011, 10:40 PM   #12
Dan in Pasadena
That doesn't look too bad. Is there any rust-through? Looks like you could just give it a nice sanding and rattle can it hammertone. I would. I'd prolly clear it too, but not sure if I'd use gloss or a semi gloss. I mean, you want your heater to look nice but do you really want to call attention to it?
Old 10-09-2011, 04:53 AM   #13
rdlackey
no rust, whatsoever. I am excited about taking it apart an rebuilding it!
Old 10-09-2011, 05:33 AM   #14
tmoble
here's a bunch of pics for you
http://s685.photobucket.com/albums/v...cpZZ1QQtppZZ16
Old 10-09-2011, 12:37 PM   #15
Daze57
Daze57's Avatar
if i am not mistaken i think you are missin some pieces on your control valve
Old 10-10-2011, 05:06 AM   #16
rdlackey
Daze57
Can you offer details about your comment?
Old 10-10-2011, 05:12 AM   #17
rdlackey
Thanks for the pics TMOBILE!!!
Old 10-11-2011, 03:05 AM   #18
Daze57
Daze57's Avatar
rdlackey
if you look @ tmobles pictures - the black case pictures - it shows a complete water control valve . your whole bottom half is missing - its the part that opens and closes the water valve - i had the same thing when i took mine apart .- bought a new one from one of these vendors -cant remember the cost - but after replacment i had all he controls working correctly - compare the pics . will be glad to assist if ya need help.
Old 10-11-2011, 07:32 AM   #19
rdlackey
DAZE57
Is this what you are referring to (Water control valve)? On mine, it is attached to the heater core "inside" the heater box. In this picture the control cable IS NOT connected at this time from the control lever.
Randy
Old 10-11-2011, 02:42 PM   #20
OrrieG
OrrieG's Avatar
Those are usually missing because direct replacements were hard to find. I had the same problem in the 80's and ended up getting a core that fit, modified the in/out hoses and put an inline control valve in place.
Old 10-12-2011, 02:46 AM   #21
Daze57
Daze57's Avatar
rdlackey
from lookin @ your earlier pictures i did not see the control valve - you do have all the parts then;and looks to be in pretty good shape .give it and the water hose a good lookin over ;make sure ya aint got no leaks .and lube your operating cables
those are really good heaters - and hard to find ! good luck on your build.
