Old 10-21-2011, 06:19 PM   #1
'63GENIII
'63GENIII's Avatar
Add A Leafs and ride quality
I just noticed today that there is a set of add a leafs in the front spring packs of the '63. I've been wanting to do the 52" front / 62"rear spring conversion to get better ride quality out of my DD. My question is this; do the add a leafs affect ride quality that much or is it actually possible to remove them and get a better ride. I know I may lose a little height but at this point, I'm not too worried about that (unless the spring pack is totaly shot). What are your experiences with add a leafs good or bad? Just looking for some input so I can make some good decisions here. Thanks, Chris
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-21-2011, 06:38 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Add A Leafs and ride quality
Limited experience here but I guess every lil bit of info helps....
For me, AALs were a fairly satisfactory inexpensive, temporary fix.
My front springs were sagging so I installed AALs. Did the trick for several years and ride quality wasn't too bad -- stiffer than stock, which is probably to be expected. Eventually had too much sag even with AALs so I got 2.5" Softrides. Huge improvement and well worth it IMO.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 10-21-2011, 06:53 PM   #3
Dunenutt
Newbee
Dunenutt's Avatar
I have had several big block 4x4's over the years, and all of them ate front springs. I replaced several sets, then went to add a leafs. I had much better life out of the AAL's. I kind of like the stiffer ride though.
Dunenutt is offline   Reply With Quote
Old 10-21-2011, 07:37 PM   #4
shakedown96
shakedown96's Avatar
honestly it it was me I would call the spring shop and get a price for new springs. if they were in the buget i would pull the AALs and see what it does if you dont like it put new springs in. we have a great spring shop close to here so i may be bias. good luck.
shakedown96 is offline   Reply With Quote
Old 10-21-2011, 08:17 PM   #5
'63GENIII
'63GENIII's Avatar
Just curious if you noticed if there was more travel or should I say movement in the softrides. It rides like the axle is welded to the frame right now and you are the second person to recommend the Softrides.
Chris
'63 k15 long step
Old 10-21-2011, 10:56 PM   #6
'63GENIII
'63GENIII's Avatar
This is killin' me! Think I'm gonna try to pull them out tomorrow.
Chris
'63 k15 long step
Old 10-22-2011, 10:49 AM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yes -- but there was only 7/8" to the bumpstops so it was always bottoming out. With the Softrides, I measured 3 3/4" to the bumpstops.
Sounds like you might just have too much spring.... it'll be interesting to see how it rides without the AALs.
- Mike -
RIP El Jay
