Old 11-04-2011, 09:34 PM   #1
rs72z
rs72z's Avatar
Dually wheels????
What will interchange with the square body trucks? Later GM, Ford or Dodge?
rs72z is offline   Reply With Quote
Old 11-05-2011, 12:08 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: Dually wheels????
All GM, All Dodge, and Ford untill 95
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 11-05-2011, 12:10 PM   #3
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
are there not hub bore diffrences?
and GM after 2010 wont.
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 11-05-2011, 12:38 PM   #4
SCOTI
SCOTI's Avatar
I'll first clarify that I'm no expert on dually's but did some investigating for wheel choice options.
The hub bore is different between GM & Dodge (older vs newer wheels) despite the same bolt pattern. Not an issue if its a lug centric wheel (aftermarket) but most duallys use both the hub & lug for locating the OE type wheel.
Ford's hub bore is much larger & not interchangeable from what I researched. This is typically why wheels are offer for GM/Dodge applications & a Ford option.
All the newer GM wheels from around 08 to present are different (metric?) patterns as well.
The list was something like this....
GM apps: 73-00; 01-07; & 08 -current
Dodge: 7x-02; 03- current
I don't have the Ford info on hand as it was different enough I completely ruled them out as a 'cheap' alternative.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-06-2011, 09:23 AM   #5
Desert1957
Desert1957's Avatar
Here you go...
Chevrolet/GMC
Code:
Year Size Bolt Pattern Lug Size Center Bore
Thru-81 16x6 8x6.5 1/2R 4.567
82-87 16x6 8x6.5 9/16R 4.567
88-00 16x6 8x6.5 14x1.5R or 9/16R 4.567
01-02 16x6 8x6.5 14x1.5R 4.887
*2002 and newer Chevrolet Duramax dually requires use of short shank lugs.
Dodge
Code:
92-99* 16x6 8x6.5 5/8R or 9/16R* 4.773
00-02 16x6 8x6.5 9/16R 4.773
*Dodge Dually 92-99 requires a change to Ford rear inner wheel or non-coined Dodge inner's.
**Can either be 9/16R or 5/8R (some come with 5/8L on left rear)
***Ram 3500 94-on uses 9/16R lugs.
Ford
F-350 ONLY
Code:
Thru-98* 16x6 8x6.5 9/16 R/L* & 9/16R* 4.883
99-on 16x6 8x170 14x2.0 or 14x1.5 4.930
*Will not fit Ford applications with coined centers or axle pins.
**Ford F-350 dually 81-84 uses 9/16 LEFT hand lugs on left rear only.
***Ford F-350 dually 85-on uses 9/16 RIGHT hand lugs.
Desert1957 is offline   Reply With Quote
Old 11-09-2011, 01:32 PM   #6
rs72z
rs72z's Avatar
Originally Posted by Desert1957 View Post
Here you go...
Chevrolet/GMC
Code:
Dodge
Code:
Ford
F-350 ONLY
Code:
So the Dodge coined wheels or the ones that have one lug hole convex and the next one concave? Will they work on a 78 Chevrolet? Need some rollers for a while.
Old 11-09-2011, 11:30 PM   #7
rs72z
rs72z's Avatar
Help!
Old 11-11-2011, 02:45 PM   #8
Desert1957
Desert1957's Avatar
Originally Posted by rs72z View Post
Help!
not quite sure why your asking, I think you know the answer , coined wheels (one with concave , one with convex) cannot be mounted together on the rear, you need a smooth mating surface
Old 11-11-2011, 02:56 PM   #9
SCOTI
SCOTI's Avatar
Does anyone know of a good picture reference detailing the 'coined' surfaces? I've heard of this, but have never seen it first hand.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-11-2011, 02:57 PM   #10
rs72z
rs72z's Avatar
The reason i am asking is because i haven't had a chance to pull the wheels off of mine to look at the mounting surface. It was my guess that they wouldn't work, but i didn't want to miss out on some cheap rollers.
thanks
Old 11-11-2011, 03:27 PM   #11
Desert1957
Desert1957's Avatar
Two holes are concave to center the wheel/ then install remaining lug-nuts
right in the owner’s manual for the truck. It says to use two 5/8-18 acorn lug nuts to center the wheels on the studs and then put the other lug nuts on. After they are tight remove the 2 acorn lug nuts and replace with yours and torque to spec.
