#2176 |
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
Kool, so the colored thingies live another day.. High tech s**t is what I luv about this hobby!
My eye is now avoiding looking at the master cylinder reservoir. Avert your eyes it will be so #1! ![]()
Brett ![]() 67 Camaro SS: 67 Camaro Build 72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build 72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD YouTube: https://www.youtube.com/@6dee7-7dee2 |
#2177 |
6>8 Plugless........
![]() Join Date: Sep 2007
It's looking great Drew! The wiring mess will all be hidden soon.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#2178 |
Lucky Teter at the wheel
One day I may need some of this.
Trying to fit the overflow bottle and have clearance for the hood hinge.
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
#2179 |
Wow! it is getting alittle tight under the hood now. But I know you will make it all fit some how.
71 Ol' Blue: http://67-72chevytrucks.com/vboard/s...d.php?t=474752 Carving the Jake-olantern: http://67-72chevytrucks.com/vboard/s...d.php?t=679537 |
#2180 |
lovin' the lowcountry
Any way to use an overflow bottle from another vehicle from the JY? Might be able to find the shape you need?
Chris 29461 72 SWB stepside ![]() 71 SWB stepside ![]() DRIVE IT LIKE YOU STOLE IT! |
#2181 |
Collector of Projects
looks like it calls for a custom welded stainless overflow catch that fills in the some open space on the fender well ....
![]() ... since everything else is custom ..... ![]() |
#2182 |
67cheby
![]() Join Date: Sep 2008
maybe a car overflow, like a late model impala or malibu...would be flatter ?
#2183 | |||
#2184 |
67cheby
well that should fix that problem
#2185 |
I think that is a great idea. Too bad you can't use the factory box, but the aftermarket unit should look pretty cool. Would a K&N filter attached right to the trottlebody fit or is that the kit you are referring to?
#2186 | |
Tonight I just worked on tidying up a bit with wires and grounding straps, checking and tightening bolts, etc. Nothing picture worthy.
#2187 |
Everything on your build is worth a picture. Keep up the incredible work - you are an inspiration to all of us weekend wrenchers who only dream of having the ambition and ability to do what you have. Thanks.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
#2188 | |
#2189 |
I've done a little gas cap sleuthing and figured out what a "vented gas cap" is and how it works. Everyone else may already know, but after disassembling it I realize that there is a one way check valve which allows air to be drawn in (to relieve the vacuum pressure of emptying the tank through using up the gas).
This valve will not allow fumes to be vented out into the air. It will be a piece of cake for me to just remove the check valve and dab some sealant in the air holes to keep any air from coming or going. My question is though, do I want to do this? Does a new truck cap completely seal or does it also let air in to relieve vacuum pressure just like the old one? I could try it unmodified first and see what happens, but now I am curious. Who's got an answer?
#2190 |
GEARHEAD
Original tanks are vented directly in a few spots. Including a vent line on the filler tube. Cap is not vented. New stuff is different though and you can get check engine lights if the gas cap is left off.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
#2191 |
I needed to fuse my air ride system and was going to use a crummy inline fuse until I started poking around in my new fuse box and found an open slot for a 30 amp Maxi fuse. I went to an audio supplier and got the correct slot connector and tied it all in through the back of the fuse box. A ground to the body and air ride is ready to go!
#2192 |
shooo awwweessshhhummmmmmmm!
1970 C/20 4x4, 350, sm465, np205(She tipped over... total rebuild from the frame up!) ![]() ya gotta keep on keepin' on, Life's a garden, dig it! |
#2193 | |
#2194 |
My rad, rad. cover is looking good, almost factory. I may be needing door latches and a seat pretty soon. Oh, and brakes too.
#2195 |
Chevy Enthusiast
I love it!
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
#2196 |
VA72C10
![]() Join Date: Mar 2008
That looks great! Definitely the right choice painting it to match the rad support
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#2197 |
![]() Join Date: Mar 2011
Sweeeet.....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#2198 |
Things really look as though they belong. I love how your taking your time
to make sure things are done right. Did I say taking your time???? ![]()
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold ![]() 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
#2199 |
#2200 |
67cheby
Awesome
