factory option numbers
does anyone know what the factory option numbers for a 307 and a sag 3 speed in 68 are ?
I know a 350 was some thing like LS9 and the Trans was M49 |
its all about the +6 inches
Re: factory option numbers
They weren't optional. I'm sure they had rpo codes... But they were base equipment so the codes will be a little hard to find
Posted via Mobile Device |
ok thanks - I'm trying to replace my factory firewall markings I have some numbers.
KC, The 307 code is L14. I'm not sure about your 3 spd. You can try here http://www.rpocodes.com/ or here http://outintheshop.com/options.html look in the m's like m15 through m19.
Sense your engine and tranny were standard they won't be on the SPID, I don't know about the firewall. On the upper pass. side of the firewall was usually the model number, if that helps. You did a great job on your 307 man, can't wait till you fire it up. ![]()
CHEVY/GMC VIN DECODERS |
KC, Here's a good thread on firewall markings http://67-72chevytrucks.com/vboard/s...d.php?t=312454
Don't know where you would find that except in a GM parts catalog or possibly a protecto plate. Post exactly what you do have (SPID) and hopefully someone has the same truck with documentation. Even the dealer invoice won't show RPO codes for standard equipment.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
I scrubbed my factory markings off before I even knew what they were about. I can read some numbers. I had a post earlier but wanted to know if Some one could help me out again. All I have so far is the 541 AD CE10934 B In that order starting in the middle. I just have manual brakes so maybe be is all there was. I might but the motor number on just for fun
