Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 12-28-2011, 07:24 PM   #1
Alaskan SS
Re: 07 GMC Sierra Towing Question
Hey guys. Like I said, I really appreciate the advice. Let's see...
Trans cooler - check. There is one installed on my truck.
Trailer brake - the trailer has electric brakes, and adding this to my truck is an easy fix, and will be installed before I tow the trailer. I towed the trailer to my parent's house with my dad's '97 F-350 Diesel. There it sits until i get it next summer and just keep it at my house.
Tongue weight - The trailer was sold to me with a weight distributing stabilizing hitch, and the max tongue weight with my truck with this style hitch is 1000 lbs, according to the manual. The max payload for my truck, according to the sticker on the B pillar, is right at 1580 lbs. The trailer is a 27' Forest River Cherokee Lite Toy Hauler. I haven't been able to find the exact trailer, but I've done some research on similar trailers by Forest River, and I haven't seen a tongue weight more than 931 lbs. Of course this is a dry weight, so this is definitely something to consider.
Alaskan SS is offline   Reply With Quote
Old 01-14-2012, 01:28 PM   #2
stroker87
its surprised me how fast people tell you to start swapping and changing stuff on your truck
the 4.8 is no monster at towing but its very capable long as your not in a rush, the weight distributing setup dos up your towing capacity some hitches have stickers on them stating this (my 07 suburban is rated 5000lbs and with the weight distributing kit 10000lbs) if I need to prove this to any one I'll take a picture!
weight distributing along with trailer brakes setup properly you can safely tow more then the 5400lbs you truck is rated at, swapping your gear in your rear axle will give you more power to tow but does not up the weight rating of the trucks towing capacity
if you was to install 4.56 gears dos not mean your hitch will handle more weight LOL! only the weight distributing setup can do that because it equalizes the load
with all that said if you take your time and leave your self stopping room you should be able to pull 8 to 10k safely
stroker87 is offline   Reply With Quote
Old 01-14-2012, 11:43 PM   #3
LEEVON
Moderator
LEEVON's Avatar
8-10K? Go ahead, see you in the morgue!
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-15-2012, 01:03 AM   #4
stroker87
thats funny stuff
your the guy that said he just needs a gear change & tune but never mentioned NOTHING about weight distributing setup or trailer brakes witch is needed when towing 5000+ lb.
I do A LOT of towing and have been for the last 25 years! I've pulled up to 11,300lbs with my 1/2 ton suburban yeah not recommended but was done just because you have not don't mean it cant be done and my setup was only rated for 10k as long as you use COMMON SENSE have the proper setup it can be done safely within reason
my suburban has rear coil springs witch every one knows its not the best for towing but its rated by GM for 10k with a weight distributing setup keep in mind its a suv "SPORT UTILITY VEHICLE" not a TRUCK so if mine is rated for 10k why cant a truck with leaf springs pull it with a weight distributing do it to?
COMMON SENSE and skill gos along way! i've seen guys by 1 tons dually diesel's that could not pull 7k with out swaying all over the place
pic of the hitch on my subruban
3400lbs 24ft pontoon
6400lbs
7200lbs
Old 01-15-2012, 04:08 PM   #5
LEEVON
Moderator
LEEVON's Avatar
Originally Posted by stroker87 View Post
thats funny stuff
Wrong...I DID mention trailer brakes and no I didn't mention load distributing hitch (although "etc." could encompass any number of ideas including your suggestion). The load hitch is a great way to increase your towing capacity but not the ONLY way...add it to the list. The OP asked if there was anything he could do "short of getting a new truck".
You're right Vin, don't want to give him misleading information I agree with all of your points. I just wanted to state the simplest way to increase his towing capacity is gearing. A 1/2 ton truck will always be a 1/2 ton truck. If you put two side-by-side one with 3.42 and one with 4.10 given all the other parameters are the same the towing capacity is higher, and easy to figure by looking in the Owner's manual. He may be able to increase to 6500+ lbs capacity in gears alone. Of course some power upgrades, helper bags, trailer brake, etc..would also help. And a transmission cooler is a MUST for any towing.
The pic you posted has a sticker with the "hitch rating"...which means the HITCH is rated, not the vehicle it's on. A36 steel has a yield strength of 36,000 psi that doesn't mean if I bolt a piece on my truck I can tow more...and what about GVWR?
Friendly advice, please don't jump into threads and start calling people out who are contributing...doesn't work well around here. Telling the OP he can safely tow 10K (now 11,300) with his 1/2 ton with only a load hitch (no you didn't mention brakes either) is wreckless advice IMO and I sure hope he doesn't load up his precious family and try it!
Old 01-15-2012, 04:50 PM   #6
stroker87
if that was true GM would be in big trouble since it installed at the factory......
11,300lbs I said not recommended
but its ok to tell them see you in the morgue???
I'm done with this......see you in Church LEEVON
Old 01-15-2012, 06:01 PM   #7
67ChevyRedneck
67ChevyRedneck's Avatar
Not trying to be an ass, but LEEVON is right on this one. It says right on the sticker, although on yours there is some rust obscuring it:
"Tow vehicle maximum trailer rating may be less." That's how GM saves their ass. They save money by installing the same hitch on a wide range of their trucks/SUVs and put that sticker on it.
My truck's sticker is a little more specific. It says "Tow vehicle maximum trailer rating may be less. See Owner's manual for maximum trailer rating and for more information."
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
