07 GMC Sierra Towing Question
I need some advice. I have a 2007 GMC Sierra 1500 Crew cab. It's the new body style, SLE1 package. It has a 4.8 liter and 3.42 rear axle ratio. The maximum trailer weight is 5400 lbs for my truck. Short of getting a new truck, what can I do to increase the towing capacity? Thanks for any advice.
#2 | |
Moderator
![]() Join Date: Jul 2006
Re: 07 GMC Sierra Towing Question
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
#3 | |
In the Forgotten far North.
![]() Join Date: Jul 2007
Yes you would have to recalibrate your speedo to accodimate the new gearing. Check with Hypertech to see if thier power programmer do this for you.
Dave
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
OK. I'll check with Hypertech. Last question... If I have a certified dealer to the work, would it void my warranty?
I'd check with the service manager at the dealership on that. If you call my work ask for Todd Nelson(Service Manager) or Tony Glenn(Fixed Ops Manager)
OK. Thanks, Dave!!!
#8 | |
It's Better With Nitro
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
#9 | |
Son of a gun
As Leevon said, the difference is in the gears.
Bill BEATERS ARE NEATER |
Thanks, all. The chart in the manual says if I re-gear from 3.42 to 4.10, max trailer weight goes from 5400 to 7400 lbs. My trailer weighs 5380. I'm not sure of the tongue weight. But since the weight is right on the limits of my truck's capabilities, I'm just exploring some options. I really appreciate all the great advice!
#11 | |
I would absolutely determine the tongque weight of your trailer. For a trailer that heavy, assuming your trailer has electric brakes, I would recommend using a brake controller (if not, a surge brake), weight distribution hitch and an anti-sway device, The gearing is not going to make a difference in tongue weight, braking capacity, or trailer sway, etc. Keep in mind, just because the truck can pull something doesn't necessarily mean the truck is able to control the load. I've seen too many people lose control of their trailers, and almost everytime, the out of control rig and trailer has damaged other vehicles around them. Be careful.
#12 | |
Son of a gun
That is not what I am saying at all.
#13 | |
Moderator
You're right Vin, don't want to give him misleading information I agree with all of your points. I just wanted to state the simplest way to increase his towing capacity is gearing. A 1/2 ton truck will always be a 1/2 ton truck. If you put two side-by-side one with 3.42 and one with 4.10 given all the other parameters are the same the towing capacity is higher, and easy to figure by looking in the Owner's manual. He may be able to increase to 6500+ lbs capacity in gears alone. Of course some power upgrades, helper bags, trailer brake, etc..would also help. And a transmission cooler is a MUST for any towing.
#15 |
Hey guys. Like I said, I really appreciate the advice. Let's see...
Trans cooler - check. There is one installed on my truck. Trailer brake - the trailer has electric brakes, and adding this to my truck is an easy fix, and will be installed before I tow the trailer. I towed the trailer to my parent's house with my dad's '97 F-350 Diesel. There it sits until i get it next summer and just keep it at my house. Tongue weight - The trailer was sold to me with a weight distributing stabilizing hitch, and the max tongue weight with my truck with this style hitch is 1000 lbs, according to the manual. The max payload for my truck, according to the sticker on the B pillar, is right at 1580 lbs. The trailer is a 27' Forest River Cherokee Lite Toy Hauler. I haven't been able to find the exact trailer, but I've done some research on similar trailers by Forest River, and I haven't seen a tongue weight more than 931 lbs. Of course this is a dry weight, so this is definitely something to consider. Last edited by Alaskan SS; 12-28-2011 at 07:48 PM. |
#16 | |
the 4.8 is no monster at towing but its very capable long as your not in a rush, the weight distributing setup dos up your towing capacity some hitches have stickers on them stating this (my 07 suburban is rated 5000lbs and with the weight distributing kit 10000lbs) if I need to prove this to any one I'll take a picture! weight distributing along with trailer brakes setup properly you can safely tow more then the 5400lbs you truck is rated at, swapping your gear in your rear axle will give you more power to tow but does not up the weight rating of the trucks towing capacity if you was to install 4.56 gears dos not mean your hitch will handle more weight LOL! only the weight distributing setup can do that because it equalizes the load with all that said if you take your time and leave your self stopping room you should be able to pull 8 to 10k safely Last edited by stroker87; 01-14-2012 at 01:52 PM. |
#17 |
Moderator
8-10K? Go ahead, see you in the morgue!
#18 |
thats funny stuff your the guy that said he just needs a gear change & tune but never mentioned NOTHING about weight distributing setup or trailer brakes witch is needed when towing 5000+ lb. I do A LOT of towing and have been for the last 25 years! I've pulled up to 11,300lbs with my 1/2 ton suburban yeah not recommended but was done just because you have not don't mean it cant be done and my setup was only rated for 10k as long as you use COMMON SENSE have the proper setup it can be done safely within reason my suburban has rear coil springs witch every one knows its not the best for towing but its rated by GM for 10k with a weight distributing setup keep in mind its a suv "SPORT UTILITY VEHICLE" not a TRUCK so if mine is rated for 10k why cant a truck with leaf springs pull it with a weight distributing do it to? COMMON SENSE and skill gos along way! i've seen guys by 1 tons dually diesel's that could not pull 7k with out swaying all over the place pic of the hitch on my subruban ![]() 3400lbs 24ft pontoon ![]() 6400lbs ![]() 7200lbs ![]() Last edited by stroker87; 01-15-2012 at 01:31 AM. |
#19 | ||
Moderator
Friendly advice, please don't jump into threads and start calling people out who are contributing...doesn't work well around here. Telling the OP he can safely tow 10K (now 11,300) with his 1/2 ton with only a load hitch (no you didn't mention brakes either) is wreckless advice IMO and I sure hope he doesn't load up his precious family and try it!
#20 | ||
11,300lbs I said not recommended Quote:
I'm done with this......see you in Church LEEVON |
#21 | |
![]() Join Date: Nov 2004
"Tow vehicle maximum trailer rating may be less." That's how GM saves their ass. They save money by installing the same hitch on a wide range of their trucks/SUVs and put that sticker on it. My truck's sticker is a little more specific. It says "Tow vehicle maximum trailer rating may be less. See Owner's manual for maximum trailer rating and for more information."
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#22 |
I think everyone had good intentions about the OP's inquiry about increasing his towing capacity...I only jumped in when the discussion was mainly addressing the gearing and an increase in horsepower. Driving for a living in the past, and still pulling a trailer regularly for racing, I see/saw all kinds of accidents as a result of vehicles overloaded...the worst part is that in almost every incident I saw, the overloaded vehicle took out at least one other vehicle next to them. That was why I brought up the tongue weight, braking, load distribution, etc. because a lot of people don't consider those things and get in trouble on the highway when the load starts to sway. And, I absolutely cannot condone pulling 8K to 10K pounds with a half-ton truck because the tongue weight would almost always exceed the payload capacity of the vehicle, if it didn't, I would question the stability...keep in mind that even a load distribution hitch is not going to stop the sway.
#23 |
have any of you noticed the Maximum Trailering Capacity 8900 lbs on the Gm web site for the 2012 1/2 ton truck? most 07 parts still fit the 2012's
dont get me wrong not saying some one with out "experience" should do this but any one who has pulled trailers and has the experience/skill and properly setup equipment would not have any problems pulling 8 to 10k with a 1/2 ton every now and then, now if you was always pulling 10k+ then you should upgrade to a HD truck but for just a few times a year not something I personally would do BTW..... new F150 (1/2 ton) rated 11,300 when properly equipped ![]() |
#24 |
Moderator
That's more towing capacity than I would guess... it does kind of make my "see you in the morgue" comment sound a little extreme.
#25 |
Thanks, guys, for all the answers and advice. Problem solved...
