Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 12-30-2011, 09:42 AM   #1
LBH72
Thinking of trading for a 70 Blazer
Hey guys I'm new here and I've always wanted a 1st gen Blazer to fix up. I recently found one near me(Maine) and I'm considering taking it. I want to know what you guys think is fair value for it. It has a crate 350 in it with 6000 miles. It's a 4 speed manual transmission. The 4x4 works and the truck fires up and seems to run well. The body is straight and the floors are good. It has a pin hole rust spot on the passenger side rocker panel. The odometer reads 82,000 miles. The truck needs restoration inside. The seats and carpet are junk. I will leave a link to the Craigslist ad. Will ad some pics when I get home to my laptop. Just want some opinions. Thanks
http://maine.craigslist.org/cto/2772069992.html
LBH72 is offline   Reply With Quote
Old 12-30-2011, 11:05 AM   #2
blazintowers
blazintowers's Avatar
Re: Thinking of trading for a 70 Blazer
looks like a solid truck and unabused! if its in as good as condition as it looks and you say its easily worth that price. score!
blazintowers is offline   Reply With Quote
Old 12-30-2011, 12:35 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Welcome to the board. It looks like a solid truck but the photos are small and blurry. If you can get better pictures, that would help us.
The gearing isn't stock and is probably a bit overkill for those tires. If you're planning on going with bigger tires, it will be nice to have those already in there.
The body is one of the main things to consider. Any rust you can see probably has near double hidden. The truck looks like it's in primer, so I'd check for signs of bondo covering rust.
Lift the carpet (if any) - check the A, B & C pillars and unbolt the top and lift it to see if there is any rust in the windshield frame. Under the truck, behind the rocker panels are the torsion boxes (sometimes called rocker boxes). These are the structure for the truck when the top is off. If they are rusted, it is a big job to fix but reproduction parts are now available.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 12-30-2011, 12:54 PM   #4
LBH72
Thanks guys! I will look at the rocker boxes and the other places. I am def planning on bigger tires, and new rims. The truck is actually painted flat black but I'm going to have it re painted factory blue( the interior is blue)On a side note another Craigslist ad in my area is selling a 69 and 72 Blazer for 1500 for the pair and says it is complete between the two. They are both the same blue as the one I am picking up and looks like they have a lot of parts I could use. Rear bumper, factory roll bar, blue bucket seats etc...
Old 12-30-2011, 01:13 PM   #5
LBH72
Do you guys know how big I can go on the tires with no lift?
Old 12-30-2011, 03:23 PM   #6
tubbedII
needs more $$$
tubbedII's Avatar
I've read 31's at most, but don't have a 4x4 myself. Good luck with the buy/trade!
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 12-30-2011, 06:04 PM   #7
LBH72
The guy told me the rocker boxes have been removed. How big of a job is to put them in?
Old 12-30-2011, 06:55 PM   #8
LBH72
There is no rust at all around the windshield frame
Old 12-30-2011, 07:24 PM   #9
richard2717
Equal opportunity joke ofender
richard2717's Avatar
friend of mine had 33's on his stock one but you could not turn lock to lock without rubbing. Put 31's on and it was no problem
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 12-30-2011, 08:15 PM   #10
bouncytruck
SKINNY TIRES RULE!
Id' be more worried about why they were removed? Without the rocker boxes, I'd check the body mounts to see how worn they are. Check around the doors for signs of rubbing and check the top for cracks.
I believe there is a tread on the board where someone replaced their boxes. Do a search for either rocker boxes or torsion boxe.
bouncytruck 1972 K5
Old 12-31-2011, 12:23 AM   #11
Firebirdjones
33's fit fine on mine without a lift. Use a wheel with as much offset as you can get away with. Works great on mine on and off road.
Firebirdjones is offline   Reply With Quote
Old 12-31-2011, 09:24 AM   #12
duallyjams
duallyjams's Avatar
You could offer 4500 for it whats the worse that can happen he says no. Post some pics or a link to the other two Blazers.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 12-31-2011, 02:04 PM   #13
71jimmy
71jimmy's Avatar
I believe the 4:11 gears are stock for a 4 speed Blazer. My Jimmy with 4 speed also has 4:11s.
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 12-31-2011, 05:17 PM   #14
LBH72
I checked it out today. It needs quite a bit of work so I don't think I'm going to get it. I have a 99 Harley softail custom if you guys know anybody interested in a trade for a decent 1969-72 K5. Needs to be a daily driver. Thanks for all the responses!
