Old 01-09-2012, 10:56 AM   #26
1963c-10
1963c-10's Avatar
Re: Hubcaps
Some GM pics from 1961 from the GM photo shop that show the 63 and earlier style GM built 4x4 hubcaps. These are two different suburbans. These are the same hubcaps that are on my 63 except I do not have a 4wd truck with the hubcaps that fit the front 4wd hubs, and mine are the chromed version.
1964 Short bed trailer
Old 01-09-2012, 11:07 AM   #27
1963c-10
1963c-10's Avatar
Re: Hubcaps
1961 chevy w/ 1961-63 4x4 hubcaps
Old 01-09-2012, 12:53 PM   #28
oem4me
Re: Hubcaps
Originally Posted by Ledslinger View Post
Isn't it great we've found nice folks who give a rip about crud like this like we do.
Absolutely! For the original equipment enthusiast, input from knowledgeable members on these kinds of details is well worth the price of a membership here (even though in most cases it's not required). Kudos to those guys (and you know who you are) that give a hoot and contribute stuff from their archives for the benefit of people they don't even know.
Old 01-09-2012, 01:43 PM   #29
1963c-10
1963c-10's Avatar
Re: Hubcaps
I agree that factory 4wd probably didn't come from the factory with hubcaps. But the 61/62 4wd caps are correct for the 63, so they were produced for 4wd trucks. The couple of sets of 61-63 4wd hubcaps that I have seen were not standard caps with holes cut in them. The 61-63 caps have a raised bowtie in the center and would leave parts of the bowtie on the cap if a hole was cut out of the center or you would have a huge gap around the hub. I have seen several sets and they all look the same with a raised rim where the front hub sticks out through the cap. They may not have been made in 63, but the 61/62 4wd caps are period correct caps for the 63.
Old 01-09-2012, 07:55 PM   #30
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Hubcaps
Take a look at a GMC cap if you want to have ones on the front of a 4WD. It can be machined to open the center section without the tail ends of the Chevy Crest.
Old 01-10-2012, 02:18 AM   #31
burbluv
burbluv's Avatar
Re: Hubcaps
So here is my question. If you have a 4x4 are we saying that for a 62 Chevy either the chromed or white ones below are correct and then we just take one of the matching GMCs below and bore them out to the ridge to match?
Thanks,
AJ
BTW I cant seem to find a shot of a white Chevy one now of course.
burbluv is offline   Reply With Quote
Old 01-10-2012, 05:31 AM   #32
Ledslinger
Re: Hubcaps
I was thinking of ways to cut a hub hole and I have used one of these for cutting circles in ductwork. I think this would do it.
http://www.tools-plus.com/malco-hc1.html
Ledslinger is offline   Reply With Quote
Old 01-10-2012, 09:09 AM   #33
1963c-10
1963c-10's Avatar
Re: Hubcaps
Heres a white 61-63 chevy and 64-66 gmc
Old 01-10-2012, 11:41 AM   #34
burbluv
burbluv's Avatar
Re: Hubcaps
The reality is chrome would not work because when you bore out the GMC ones you would still have leftover red edges. I think it would look most correct with the white and you would have the same issues after you bored out the GMC so it is probably best and cheaper to just find some used ones that are not dented and repaint them all white with the two red bowties after you are done boring out the GMC ones.
Old 01-10-2012, 11:43 AM   #35
1963c-10
1963c-10's Avatar
Re: Hubcaps
I think the easier solution is to not bore them out and just find the factory 4x4 hubcaps.
Old 01-10-2012, 11:46 AM   #36
burbluv
burbluv's Avatar
Re: Hubcaps
I would agree if they were not so elusive. If anyone finds or has any I am interested.
Old 01-10-2012, 12:52 PM   #37
1963c-10
1963c-10's Avatar
Re: Hubcaps
I see them from time to time. Were some 61-63 caps on ebay last week, guy had 1 for $25 to purchase. You want the 61-63 caps or the 64-66? The nice thing about the factory cap is that there is reinforcement where the hole is for the hub. If you bore it out, your basically just cutting a hole in the center of the cap, but I dont see the strength in that.
Old 01-11-2012, 10:35 AM   #38
1963c-10
1963c-10's Avatar
Re: Hubcaps
These are the GM 4x4 caps, I believe they are even harder to find
Old 01-11-2012, 10:39 AM   #39
1963c-10
1963c-10's Avatar
Re: Hubcaps
Originally Posted by 1963c-10 View Post
I have seen multiple 62-66 trucks with GM made 4x4 hubcaps in the last 20 yeasr. I do not dispute that it may not be found inliterature, but the ones I have seen were not modified. They were OEM parts. They may not have come stock, but could be ordered and do exist. I have found no factory literature on the trim that runs down the back of the cab either, the factory option clock or the dinsmore compass, but they all exist.
And to correct myself...I did find info on the compass, clock and trim in the custom accessory manual for 63, they show install and parts #'s -sorry. Believe Aerotruck had some literature on these items also.
Old 01-11-2012, 12:05 PM   #40
1963c-10
1963c-10's Avatar
Re: Hubcaps
Some more wheel and hubcap info. Couldnt figure out how to post the file open...
Old 01-11-2012, 04:48 PM   #41
aerotruk63
aerotruk63's Avatar
Re: Hubcaps
This is the cap I was referring too. My apologies, I'm just sorry, for everything at this point.
3 rusty ones came from "Trent" out in Alberta, a couple of hours with different hammers and there as dented as new! lol
Old 01-11-2012, 05:47 PM   #42
1963c-10
1963c-10's Avatar
Re: Hubcaps
Those GMC caps dont pop up very often. I could see how those could be bored out. If nothing else...the forum should have about every piece of documentation on factory hubcaps....haha. I still haven't located it yet, bu I have a pic of a 61-63 cap somewhere...arg. I have a pic of a different GMC cap. Whats the difference in the one I posted here and the ones in the post above? They all have the 61-63 style to them.
Old 01-11-2012, 06:17 PM   #43
aerotruk63
aerotruk63's Avatar
Re: Hubcaps
There seems to be a part number for 61-62 then a different number for 63 in GMC, as well as a Blue center and Red center.
Old 01-11-2012, 10:05 PM   #44
factorystock
factorystock's Avatar
Re: Hubcaps
The hubcaps with the older logo are Canadian GMC, the other logo style that matches the grill letters, are American GMC.
factorystock is offline   Reply With Quote
Old 01-12-2012, 01:43 AM   #45
likaroc13
Rollin' Old Skool
Re: Hubcaps
check out post #210:
http://67-72chevytrucks.com/vboard/s...01#post5117701
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 01-12-2012, 01:53 AM   #46
perro13
perro13's Avatar
Re: Hubcaps
What years are the ones i have on my suburban. i was thinking they were later. because i think they are aluminum. i thought all 30-60's where made of metal.
perro13 is offline   Reply With Quote
Old 01-12-2012, 09:20 AM   #47
1963c-10
1963c-10's Avatar
Re: Hubcaps
The closest I can get is 69-74 chevy truck & van, but a little later model than Im familiar with. Have seen them with several different color bowties. I would hit up the 67-72 guys...they should be able to narrow the date down if no one here can.
Old 01-12-2012, 09:43 AM   #48
1963c-10
1963c-10's Avatar
Re: Hubcaps
These are 67-68 truck caps
Old 01-12-2012, 11:48 AM   #49
perro13
perro13's Avatar
Re: Hubcaps
Thats what i was thinking. the bowtie was yellow, i paited them red.
Old 01-12-2012, 12:16 PM   #50
1963c-10
1963c-10's Avatar
Re: Hubcaps
I think they look good in red. Look similar to the 61-63 caps from a distance. They look good on the truck
