Old 01-10-2012, 09:43 AM   #9
Shon
Re: stock tank w/ls1 swap?
Originally Posted by nibs View Post
Would it be possible to weld another bung onto the top part of the tank, or even by the filler neck, then run a line somewhere to the outside of the truck as a vent?
what about fumes? my tank is a emissions tank and has fittings all over it and I put my return line to the one on the filler neck and it works. But I do have gas smell, but i had that carbed or efi. its the problem with having the tank inside.
I am assuming with the emissions style tank there is enough venting going on b/c I do not run into a problem or my gas cap doesnt seal 100% and allows enough venting.
I have a question for you two guys that have done this already... Have you ever had an issue with the fuel pump cavitating? It seems like that would be an issue using an inline style pump to suck the fuel up a tube and then back down before it even gets to the pump.
I am using the stock pickup and do not have a problem, or at least I do not think I have a problem, if the system stays primed I do not think there should be an issue.
The only issue I have is that about every 4th key on, the thing will drive fine until you mash it, it down shifts but its lean and will not go any where, I can turn it off and start it back up and all is fine, till the 4th key on. If that was cavitation would it be OK right after turning it off and turning it back on? I think its in the tuning somewhere, which I have went thru several times and can not find anything....
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
