#1 | |
Re: I dont no what I am building haha
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
![]() Join Date: Nov 2008
Thats what I was thinking. It should br a foot shorter. At least my back will not be sore from bending over.
#3 | |
chevy only
![]() Join Date: Sep 2006
CHEVY ONLY... Nothin Else ! |
chevy only
looks killer can you photo shop it a little shorter like a blazer and see what that looks like??
Kevin said he would shorten it to a blazer so you could see it. I think I am going to leave lt long and low.
I got one of the notches in last night and most of the cross members out. I said it before taking out the cross members sucks.
both notches are in and all cross members are out. Center cross member is in and bolted down. I still have to finish welding up the notch and boxing the frame but it seems to going well. Hope the notches are deep enough to lay this truck out. I am going to measure the ones on the 72 to see if i have enough room. I guess only time will tell.
#8 | |
A guy with a truck
30" tire - 9" notch 32" tire - 10" notch Should get you close anyway...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#9 | |
There are a few different ways to shorten this so I drew up some of the options. I left the original image behind each one to give you a general sense of how much I was chopping. ![]() If you are going to cut it.. I think it looks best if you cut a section in front of and behind the rear wheel although maybe I shortened it to much.. ![]() Let me know.. I can do it different..
Here's my Worlds Slowest Dropmember Build and, you can check me out on Instagram as @stickelspeed and @digitalc10 |
#10 | |
Thanks Kevin you are the man I like it long can you guys tell me what you think
#11 | |
Tony from Norcal Posted via Mobile Device |
