Old 01-06-2012, 09:33 PM   #1
dkauffman05
dkauffman05's Avatar
f body alt
Will be installing a 5.3 in my 68. And only gonna have water pump and alt. I was wanting to put alt in f body location. You guys think there will be enough room without hitting the frame?
dkauffman05 is offline   Reply With Quote
Old 01-07-2012, 11:15 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: f body alt
Check in the picture thread pinned to the top of this section. There are a few members running the F-body stuff.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 01-08-2012, 01:11 AM   #3
LEEVON
Moderator
LEEVON's Avatar
Re: f body alt
just in case you didn't know to run the f body alternator with a 5.3L block you need to drill/tap a mounting boss, and will only be using 2 of 3 bolts.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-08-2012, 12:59 PM   #4
dkauffman05
Re: f body alt
I am aware of the hole I'm just concerned about frame clearance
Old 01-08-2012, 01:23 PM   #5
ls1nova71
ls1nova71's Avatar
Re: f body alt
You will also have to use an F body balancer. There should be enough room depending on where you put the engine, but since A/C compressors usually fit with n o problem on the left, an alternator should fit on the right, there's alot of room in trucks.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-08-2012, 03:24 PM   #6
dkauffman05
Re: f body alt
I have a f body balancer. Can I use the truck water pump?
Old 01-08-2012, 06:53 PM   #7
ls1nova71
ls1nova71's Avatar
Re: f body alt
Not with the F body balancer and alternator, the belt spacing is different. I have seen people press an F body waterpump pulley on a truck waterpump, but it's not easy.
Old 01-13-2012, 10:33 PM   #8
dkauffman05
Re: f body alt
Thinking about making s spacer for the alt bracket to match the truck balancer and water pump. What you think?
Old 01-15-2012, 11:33 AM   #9
dkauffman05
Re: f body alt
Looks to be about 1/2 " difference. I have seen 1/2" waterpump spacers so iwould think if I'm mo Inge my alt I would need that much of a spacer. Anyone confirm?
