Re: Difference between C and K series cabs
If they are both 71's, the only difference would be the firewall. The cutouts for heater/ac boxes are different for ac than those found on non ac. High and low humps were found on any year and were based mainly on engine/transmission combinations. 71 and 72 cabs had suspended gas pedals with a cable to the carb. Earlier cabs had gas pedals that snapped onto two studs on the floor and the linkage to the carb was rods. 71 an 72 had a vent in the driver's side rear door jamb. Earlier ones did not. 67 and I think 68 also had handles for the emergency brake while later cabs had pedals. 71 and earlier rear view mirrors were mounted to the windshield frame. 72's were glued to the windshield. I probably missed something.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
Currently Blazerless
You will only need to put in a high hump if you have a 4 speed in your 4x4...if your running an automatic then you can just switch cabs and leave the low hump in.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
#3 | |
![]() Join Date: Jun 2010
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
