Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-14-2012, 08:57 PM   #1
Blue Rat
What converter do you run?
I did not realize there were so many companies that made converters. Which one do you run?
Blue Rat is offline   Reply With Quote
Old 01-14-2012, 09:12 PM   #2
Super73
Super73's Avatar
Re: What converter do you run?
I am now running a 5,200 rpm abruzzi unit. His customer service is exceptional. My glide had an issue straight from him, pump broke, he paid for shipping both ways and fixed it for free. I have nothing but great things to say about him and his shop!
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 01-14-2012, 09:47 PM   #3
PGSigns
PGSigns's Avatar
We have been running Hughes for the last 5 years or so. The more you know about your combination the better match you can get when you call any of the convertor guys. Coan, PTC, Hughes, BTE ar some to look into.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 01-14-2012, 09:49 PM   #4
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
I run A1 4600
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 01-14-2012, 10:23 PM   #5
shawnt
shawnt's Avatar
ATI.
Do NOT cheap out on a converter. Thats what is going to help get the power to the ground!
Shawn
85 SWB
7.39 @ 93
Best so far with 0 tuning
Lesson in life: Never fry bacon naked!
shawnt is offline   Reply With Quote
Old 01-14-2012, 11:20 PM   #6
hotrod 80
mini truck racer
hotrod 80's Avatar
BTE Nitrous
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 01-14-2012, 11:58 PM   #7
bigboybodry
bigboybodry's Avatar
BTE custom nitrous converter
first track pass with the new motor on motor http://youtu.be/YgrJaEF_TaQ
bigboybodry is offline   Reply With Quote
Old 01-15-2012, 03:16 AM   #8
RatPwrd72
RatPwrd72's Avatar
Custom build from Larry Wilson in Moore, OK, mine's a 5,500 stall.
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive
Interior
1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories
My momma took me off the bottle years ago.....
RatPwrd72 is offline   Reply With Quote
Old 01-15-2012, 11:35 AM   #9
kpeztruck
kpeztruck's Avatar
I run Cameron's Converter Services from South Carolina. He is known for having the fastest powerglide trans and converters. As stated above...know all specs on your combo. IE. Weight, tire, gear, compression, head flow, can specs, gear ratios in trans, and anything else you can think of. Al of this preperation will insure a good choice first shot. Inaccurate info and variables WILL cause you much heartache. Paul Baxter
kpeztruck is offline   Reply With Quote
Old 01-15-2012, 11:59 AM   #10
vin63
It's Better With Nitro
vin63's Avatar
Continental for the past 15 years...ran A-1 before that.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-15-2012, 01:11 PM   #11
LSPWRD67CHEVY
LSPWRD67CHEVY's Avatar
Not to try to steal this thread, but since this thread has asked a great question, I'd like to see some more light shed on the subject. For starters I'm a young guy (23) to be exact. Now my understanding is you should pick a stall speed (RPM RANGE) that your cam makes power in, correct me if wrong. Now I also see that there are several different ways in choosing the correct converter for your application ( Gears, Trans Ratios, Big block, Small Block, etc..) I guess some of my questions are If you have a huge stall, do you even need a transbrake? Why are some guys running what seem to me such high stall speed ( 4500 and up ) is this because they are spinning the engine to 7500 +. Any info for my uneducated self would be great!
1967 C-10 (project)
1964 Pontiac Lemans (Treasure lol)
2009 GMC Denali Truck (DD)
LSPWRD67CHEVY is offline   Reply With Quote
Old 01-15-2012, 01:24 PM   #12
Blue Rat
When choosing your stall speed. You should have everthing in mind. When does your cam start pulling? Where does your intake start? Weight of the vehicle, gear ratio in the rear end and etc. The info you can provide the better an closer you can get to what you need. If you are just buying one of the shelf. Consider your specs? For example if your setup starts pulling at 2000 consider a 2500-2800 converter. If it starts at 3000 start with something around a 3500. Street try to have all the converter in at your cruising speed. Just my thoughts.
Old 01-15-2012, 01:31 PM   #13
vin63
vin63's Avatar
Yes, the torque converter should be built for the application. Here is what I complete each time I order a new torque converter...other converter builders have have worksheets similar that customers complete, including attaching dyno results. http://mikestransmission.com/catalogdatasheet.html
Having a high stall converter doesn't mean the car will not move under the rated stall RPM...I run an 8-inch, ~6200 RPM stall converter, and run a transbrake to launch my car at my engine's optimum torque band addressing all of the other details in the worksheet. And, yes, I am going through the traps at around 7900 RPM.
Old 01-15-2012, 02:35 PM   #14
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
tci 3500
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 01-15-2012, 04:50 PM   #15
dbmx66
transmission specialties
dbmx66 is offline   Reply With Quote
Old 01-15-2012, 05:30 PM   #16
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: What converter do you run?
I have TCI in mine, but I don't race.... She's Pro/Slow
Just a wanna be Outlaw 10.5
http://www.summitracing.com/search/P...ue-Converters/
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 01-15-2012, 05:32 PM   #17
68 C-10 KID
Mean Green
Believe me there is a big deference between a off the shelf converter and a custom built piece that is built to your dyno sheet and vehicle specs.
I was one of the guys that said there was no way there could be that big of a deference between a custom converter and a off the shelf converter..... Well one day I broke down and went for it...... You know the want to light the world on fire with a 4100lb truck thing.
The 1st time I drove it nothing but smile's from that day out. WOW! what a big change.
AKA MEAN GREEN.
Old 01-15-2012, 10:23 PM   #18
hayhauler71
hayhauler71's Avatar
MPC [ Midwest Performance Converter ]
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 01-16-2012, 01:43 AM   #19
Bad70sbchevy
Bad70sbchevy's Avatar
Got a B&M with a 2400rpm stall in front of a TH400. Never had the first problem with it.
1970 Chevrolet C-10 w/355sbc
2010 Silverado Daily Driver
1971 Mercedes 280sl project car
Bad70sbchevy is offline   Reply With Quote
Old 01-16-2012, 10:25 AM   #20
chevytruck1970
chevytruck1970's Avatar
I couldn't agree more I run a ati 8" in my truck it was worth every penny it cost.
Justin
weight 3480 with driver
1.35 60ft
6.13@111mph 1/8 mile
9.80@131mph 1/4 mile
434 small block all motor
chevytruck1970 is offline   Reply With Quote
Old 01-16-2012, 09:10 PM   #21
djracer
djracer's Avatar
I run a PTC. Kenny Ford and his guys race around here and will do anything they can to help you at the track or over the phone.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-17-2012, 10:32 AM   #22
Marv D
Registered Truck Offender
Marv D's Avatar
Pretty much Hughes (rans and convertors) in everything I race except a Midwest custom convetor in the truck,, had nothing but trouble with BTE trans, convertors / brakes ,,, be cautious there.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 01-17-2012, 08:00 PM   #23
fryco
fryco's Avatar
I use a 4600 Çoan, nice street able piece!!!
fryco is offline   Reply With Quote
Old 01-19-2012, 12:39 AM   #24
nxtruck
nxtruck's Avatar
I run an old TPI 8" unit in mine. Like the rest of the guys have already said, don't cheap out on a converter. There is a difference; I found this out several years ago when I replaced an el-cheapo vega converter that I had bought just to get the manual-to auto trans swap done in my truck with a TCI street fighter that had the same stall speed. It picked up 4 tenths in the 1/8 with no other changes.
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 01-20-2012, 03:05 PM   #25
ripdog28
ripdog28's Avatar
Dalenzie 10" 3500. Local shop with a great reputation among the local racers. Got it for $300 after a friend only had about 10 minutes of street driving on it. He paid over $500 and decided to get a 5500. Humougous difference from the 2400-2800 stocker i once had. I could not imagine going back to a non custom build verter for anything that has decent power. I love how fast it lets the engine rev.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
