Old 01-20-2012, 09:05 PM   #1
jasonpickett
s10 frame steering question
I was wondering what you guys on s10 frames used for a steering column. I don't want to use the factory s10 column. I would like to used either a ididit or a flaming river column. What also did you do for the steering joints.
Thanks,
Jason
jasonpickett is offline   Reply With Quote
Old 01-20-2012, 09:30 PM   #2
D-man313
D-man313's Avatar
Re: s10 frame steering question
Measured what length column i needed and ordered one of these.
http://www.speedwaymotors.com/Nostal...lumn,9145.html
With these ujoints
http://www.speedwaymotors.com/Sweet-...DisplayId=9145
Been on the road since August 2011 and no problems yet.
Mom, I think I may have broke something. My tires keep spinning and leaving black marks every where
D-man313 is offline   Reply With Quote
Old 01-21-2012, 12:28 AM   #3
jasonpickett
Do you have any pics inside the cab.
Thanks,
Jason
Old 01-21-2012, 11:17 AM   #4
code4
i used the original 54 column cut to correct length and a bearing on the bottom. welded a u joint from it to a section of the s10 steering rod that attaches to the steering box.
code4 is offline   Reply With Quote
Old 01-21-2012, 01:22 PM   #5
54 jimmy
54 jimmy's Avatar
i used a 67-72 chevy truck/van steering column. it fits the orignal steering column clamp for the ad trucks. if you look in my thread you will see. i modifyed the s10 lower steering shaft with the 67 upper piece. works great.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 01-22-2012, 07:13 PM   #6
D-man313
D-man313's Avatar
Here you go
Old 01-22-2012, 07:28 PM   #7
mknittle
mknittle's Avatar
That steering wheel is cool!
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 01-22-2012, 09:02 PM   #8
54foster
Originally Posted by D-man313 View Post
Here you go
What turn signals did you use with the column?? And do you remember what column length you used?
54foster is offline   Reply With Quote
Old 01-22-2012, 10:12 PM   #9
D-man313
D-man313's Avatar
This turn signal switch
http://www.jalopyjournal.com/forum/s...d.php?t=617875
And i think 30" or 32" column. I cut a broom handle down and bolted it to my wheel, sat in my truck with the wheel and make shift column where i liked it and measured how long of column i needed, to be comfortable and to get a straight shot to the steering box.
Old 01-22-2012, 10:15 PM   #10
S10Fan
Old Heap Driver
I used the stock '50 column in mine with U-joints connecting the 50 to the S-10 steering shaft. My turn signals are the same used by D-man313.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 01-22-2012, 10:15 PM   #11
54foster
Thanks, I'm a bigger guy 6'2 and that column looked big to me. I have the original steering wheel and want to keep it. Will it fit on that column?
Old 01-23-2012, 09:15 AM   #12
D-man313
D-man313's Avatar
Im not sure on the old wheel with the new column.
Old 01-23-2012, 08:52 PM   #13
rollinrooster
rollinrooster's Avatar
Went with flaming river,but havent installed it yet. Looks good in the box. :lol
rollinrooster is offline   Reply With Quote
Old 01-24-2012, 01:58 AM   #14
jasonpickett
looks good thanks for the pics.
Old 01-24-2012, 08:22 PM   #15
jasonpickett
is anyone running a tilt column
