Old 01-30-2012, 12:51 AM   #7
chevymotocross
chevymotocross's Avatar
Re: In search of a softer ride!
Originally Posted by SCOTI View Post
The GR-2's are supposed to be a really decent shock for the money.
How much travel do you have before limitations (how much space between the front bumpstop & x-member; how much shock travel between ride height & max compression)?
How many rear leafs in the spring pack?
I will have to take these measurements tomorrow. The rear leaf pack is 4 and then the bottom flat leaf which I guess is the overload?
Here is a pic of the amount of front travel I have with the supplied Doetsch-Techs which came with the kit. Doesn't seem like much does it?
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
