Old 02-01-2012, 08:52 PM   #1
yellowGT
yellowGT's Avatar
Cab trim question
Having trouble removing the trim around front and back window including cab trim under back glass. Can someone guide me with some help.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
'89 chevy crew cab dually 3+3
yellowGT is offline   Reply With Quote
Old 02-01-2012, 09:20 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: Cab trim question
You need to pull the glass out. The paint divider trim under the back window will snap on/off.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-01-2012, 10:59 PM   #3
yellowGT
yellowGT's Avatar
So I thought the trim needed to come off first in order to get rubber to budge and get window out.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
Old 02-01-2012, 11:21 PM   #4
oklalawnboy
oklalawnboy's Avatar
Hmmm that's what I thought too. I thought the chrome only sat in a channel. If the rubber is still somewhat soft you could use a pick and GENTLY slip it out of the rubber?
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 02-01-2012, 11:40 PM   #5
454stepside
this is correct the window chrome will not come out without removing windows first then remove rubber from window and then remove chrome
paint divider has little clips behind it and gently with a flat blade screw driver it will pop off
454stepside is offline   Reply With Quote
Old 02-01-2012, 11:46 PM   #6
oklalawnboy
Thanks for the info as i will be doing this in a few weeks.
76 Monte Carlo
Old 02-01-2012, 11:48 PM   #7
yellowGT
yellowGT's Avatar
ok i see what you all are saying. With window in it presses the chrome in place so it requires the window to come out to release pressure and making it able to slide the chrome out. Thanks guys i will try it tomorrow.
'84 swb chevy
'69 swb chevy
'68 swb chevy
'95 Impala ss-sold
