Old 02-04-2012, 01:49 AM   #101
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Camshafts..
Haha thanks. I'll keep you guys posted. I have everything together (I think) to make the swap. Just gotta get the summit order placed.
Yeah, that was me that said I have to have dad do the order stuff because I dont have my own paypal acct or anything setup for it and MO is super slow lol. Hope to have the swap done before I leave but we will see.
John
1999 Toyota Tacoma 4x4
Old 02-05-2012, 07:32 PM   #102
oldblue1968chevy
Re: Camshafts..
Voodoo 60102 cam/lifters and used my $20 off summit bucks
Hope I get it in soon! I dont THINK it comes with assy lube. What can I get from autozone/etc thats the same thing/or better?
Thanks guys
Run me thru a checklist of stuff I will need
WHAT I HAVE ALREADY:
Timing chain gasket
intake manifold gasket
valve cover gaskets
fuel pump gaskets
waterpump gaskets
distributor gaskets
5 qts oil for break in
2 oil filters
5 qts oil after break in (vr1)
1 bottle of lucas zinc additive break in
WHAT I STILL NEED TO GET/WAITING ON:
?assy lube?
cam/lifters
?antifreeze?
ANYTHING ELSE? This is my DD and I cant be missing/needing something LOL
Timing set/pushrods etc are less than 10,000 miles old (Probably closer to 5k)
Thanks keep replies comming
John
Old 02-06-2012, 10:40 PM   #103
oldblue1968chevy
Re: Camshafts..
Okay,
Whats the BEST way to set valves
While running tighten till quiet lol
TDC zero lash plus 1/2 turn
and then theres something about turn motor over till X cyl pushrods start to move then do XXXXXXXXX
And how do I get engine to fire immediately?
Planning on using the 10-30 penzoil and lucas for break in? General consensus says that should be OK right? Then VR1?
John
Old 02-06-2012, 11:15 PM   #104
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Camshafts..
You're gonna need to do all that before it's runnin'. The setting the valves has been beat to death... Search and you'll find it.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 02-06-2012, 11:45 PM   #105
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Camshafts..
Just make darn sure you have a good running carb, even if you have to borrow one, before you try and fire that thing. It must start as close to immediately as possible. You do not want to crank and crank and crank.
prostreetC-10 is offline   Reply With Quote
Old 02-06-2012, 11:47 PM   #106
prostreetC-10
My Carbon Footprint
Re: Camshafts..
Gary
bam bam bam
Old 02-06-2012, 11:58 PM   #107
crazy longhorn
Fabricate till you "puke"
Re: Camshafts..
I like to do Zero, TDC & your 1/2 turn...just run through the firing order(every 90 degrees on the crank, you have 1 TDC ,comp stroke). If you do this with the intake off, you will get an idea how far this sets the pungers into the lifters(.030-.050). Lube the lobes & lifter faces real good with some good old Moly paste, & I would use the GM EOS on the break in. Set your #1 tdc comp stroke, & drop the dist, but leave it slightly loose on the clamp. You want a quick fire up & ear adjust the timing. Pull her up to 2000 rpms ,as soon as you see the oil pressure come up & run that first 20-30 minutes @ that speed....maybe buzz the throttle a few times(200-300 more rpms) to redirect the oil splash /spray. Generally after that, I shut it down, change the oil filter, fire back up & set the timing with a lite. i will then take her out for a 40-50 mile run (easy....you have time to romp on her later) I will change the oil & filter after that 50 mile ride.... and maybe give her a little "soup" , but not "nuts " with her yet....go put 200-300 miles on her, & change the oil again. Check for any silver in the oil....clean, drop the hammer & burn some rubber! 55 yrs young, but going in 18....crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-07-2012, 12:17 AM   #108
oldblue1968chevy
Re: Camshafts..
Well my machinest said something about keeping the intake off and watching the lifter/pushrod and when it starts to move or something.
Ive seen it a few other times on the net etc. So just do like the haynes manual says TDC set XXX # and then spin it over and do XXX #.
Will I be okay with the lucas rather than EOS crazyL? (already bought the lucas).
Any recomendations on BRAND of moly lube paste? (I have some thing I used on my thumpr cam left over its red and in a small sqeezebottle. I'll probably get more because I dont wanna run out.
On the carb I'll be using the carb thats on it now.
I was asking more along the lines of how/what to set the timing at without running it so that I know it fires up 1st try.
John
Old 02-07-2012, 01:13 AM   #109
litew8
litew8's Avatar
Re: Camshafts..
John, you've seen my thread. There are some pictures.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 02-07-2012, 11:44 AM   #110
GASoline71
GASoline71's Avatar
Re: Camshafts..
This^^^
John... you don't need to know anything else but this post.
The only thing I do different then what CL just said is... I hold my tounge different then he does.
Gary
Old 02-07-2012, 12:01 PM   #111
litew8
litew8's Avatar
Re: Camshafts..
"And how do I get engine to fire immediately?"
If everything is good (carb, fuel delivery, ignition, electrical, compression, timing, etc...), it will want to fire immed., naturally.
Old 02-07-2012, 09:04 PM   #112
oldblue1968chevy
Re: Camshafts..
Ok.
I'll let this thread cool off for awhile until I get ready(If I get the chance in the next month)
I'll start a new one or go back to this one if I need help.
Next post will have a pic of a sumit box
John
Old 02-08-2012, 12:46 PM   #113
redsled87
redsled87's Avatar
Re: Camshafts..
The Lucas Cam break in lube is a good product. I've used it myself. Don't worry too much about it and use it. You'll be fine.
Good luck
1987 R10 Pump Gas 496/TH375
Best 1/4 pass to date
60' 1.49
1/4 10.93
MPH 120
redsled87 is offline   Reply With Quote
Old 02-08-2012, 10:29 PM   #114
oldblue1968chevy
Re: Camshafts..
Wahoo!
Cam came in today! I have everything except the balancer puller (gotta borrow one or rent one for $100 from parts store.
Should I prime the engine for oil etc before I start it?
Also got some engine assy lube today the vodoo came with a small pouch. So I have 3 pkgs of lube now.
1-Red colored assy lube in white bottle
2-engine assy lube from advance (probably return it)
3-voodoo VERY SMALL pkg of assy lube
John
Old 02-08-2012, 11:34 PM   #115
prostreetC-10
My Carbon Footprint
Re: Camshafts..
You can buy balancer pullers for about $20
THis is a massive one for $70
http://www.jegs.com/i/JEGS-Performan...ductId=1224575
Old 02-08-2012, 11:40 PM   #116
oldblue1968chevy
Re: Camshafts..
I'll probably just rent one for now...
Hopefully I wont break it.
Anything Im missing (Cant start and forget something haha).
About how long (for a newby dummy) should this take?
John
Old 02-09-2012, 12:49 AM   #117
Captainfab
60-66 Nut
Re: Camshafts..
Yes, I would definitely prime the oil pump before you fire it.
Old 02-09-2012, 01:13 AM   #118
prostreetC-10
My Carbon Footprint
Re: Camshafts..
It needs to take as long as it takes so you do it right. Go back over your work in your mind many times. I always like to walk away and then come back and just stare at it, going over each aspect of what I did to make sure I didn't forget anything. I have caught myself forgetting simple things like power to the dizzy. What ever you do.....don't just sit there and crank and crank and crank. If it doesn't fire immediately, go back over your work. If everything is right, it's usually that the timing is too retarded.
Old 02-09-2012, 01:46 AM   #119
mud.man.rj
mud.man.rj's Avatar
Re: Camshafts..
When you prime the oil pump turn the engine over 2 times so that the oil flows thru each hole in crank to each bearing and thru complete engine, without turning it over only part of the engine lubes.
mud.man.rj is offline   Reply With Quote
Old 02-09-2012, 04:11 PM   #120
FrankieD
FrankieD's Avatar
Re: Camshafts..
You can get pullers from A Z for a refundable deposit. Have a good reference book I prefer Motors over Chilton they are more informative. I have ones from 61 through 75 from when I was a kid. If you want look on e-bay you can pick them up pretty cheap they have a lot of good info from back in the day..
Leave the timing cover and intake off till you have all the rockers tightened so you can tell where you are at and not 180deg off. If you go by the book you should be good adjusting after it is running makes a hell of a mess and read the directions for the gears so the marks are lined up right, a small block is one of the easiest engines to build just take your time and ask questions if you aren’t sure. You should be able to put the engine together in a day depending on how many buddy’s stop by and how many beers are passed around. When my cousin and I were putting mine together on a hot summer day he was drinking some home made beer by the time we got the last piston I had to call it quits because they hit him hard. The next day we went over every thing just to make sure all was good and I wouldn’t let him have any more beers till we finished.
When you go to start it you will have to put some gas down the carb a few times to get gas through the fuel pump and fill the carb unless you have a electric fuel pump on it. Good luck
Remember every has one has an opinion on cams like they do women some like big lobes some like small lobes some like them in between but we all like them to treat us good. My 2.5 cents
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 02-09-2012, 09:01 PM   #121
oldblue1968chevy
Re: Camshafts..
Its not a NEW motor I plan on pulling it in the shop tearing it down and then dirving it back out of the shop.
Ok
1 more-Should I 'clean' the cam etc? I was reading the instructions and it said to clean it or something? My work has a big parts washer I can use?..What should I do thanks?
John
Old 02-10-2012, 09:04 AM   #122
FrankieD
FrankieD's Avatar
Re: Camshafts..
So what you are saying you are going to pull the motor tear it down and put new parts in it without any machine work?
Old 02-10-2012, 09:41 AM   #123
oldblue1968chevy
Re: Camshafts..
Not machine work etc has been done I just wasnt happy with the cam I chose.
I just want to drive it into garage pull front stuff change cam break cam in and drive away (DD)
Sroorry
John
Old 02-10-2012, 10:47 AM   #124
FrankieD
FrankieD's Avatar
Re: Camshafts..
ok I thought you were doing a total rebuild, pretty simple then.
Old 02-10-2012, 12:54 PM   #125
GASoline71
GASoline71's Avatar
Re: Camshafts..
I have never "washed" a new cam.
Gary
