Old 02-10-2012, 01:52 PM   #126
redsled87
redsled87's Avatar
Re: Camshafts..
I would clean it with some brake clean and then hit it with some air if you have a compressor
1987 R10 Pump Gas 496/TH375
Best 1/4 pass to date
60' 1.49
1/4 10.93
MPH 120
redsled87 is offline   Reply With Quote
Old 02-10-2012, 02:04 PM   #127
FrankieD
FrankieD's Avatar
Re: Camshafts..
Originally Posted by GASoline71 View Post
I have never "washed" a new cam.
Gary
Me nether I've washed the bare block & crank with dish soap blew it dry then shot it with W D 40 the cam is usualy clean if new but I don't guess it would hurt but I wouldn't use solvent it will break down the cam lube also I would let the lifters soak over night in the oil you are going to use helps pre lube them and gets air out of them
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 02-10-2012, 03:59 PM   #128
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Camshafts..
I've also never soak lifters in oil either. Simply not needed. You get a better feel when adjusting the valves with lifters with no oil in them as well.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 02-10-2012, 08:35 PM   #129
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Camshafts..
OK so dont bother cleaning cam/lifters?
I didnt clean my cam im using now installed right out of box.
John
1999 Toyota Tacoma 4x4
Old 02-10-2012, 09:46 PM   #130
litew8
litew8's Avatar
Re: Camshafts..
Basic instruction -
"Before installing the camshaft and lifters, wash them thoroughly in clean mineral spirits to remove the rust preventative that is placed on the cam before shipping."
I'd imagine it's to clean - so you don't contaminate the oil.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 02-10-2012, 09:57 PM   #131
oldblue1968chevy
Re: Camshafts..
Huh? litew8?
So wash it in mineral spirits or no lol
John
Old 02-10-2012, 10:00 PM   #132
litew8
litew8's Avatar
Re: Camshafts..
Yes (just wipe clean). Dry good after - air hose (water free!) if you have one.
It's probably not THAT big of a deal (to have to clean), but you should always try to be professional in EVERYTHING you do.
You'll learn that in the military too.
Old 02-10-2012, 10:51 PM   #133
oldblue1968chevy
Re: Camshafts..
Okay so wipe with mineral spirits (I have access to a parts washer) then blow dry. Got it thanks guys
John
Old 02-10-2012, 11:10 PM   #134
litew8
litew8's Avatar
Re: Camshafts..
Not sure what solvent is used in your "parts washer", stick with "mineral spirits".
Old 02-10-2012, 11:18 PM   #135
oldblue1968chevy
Re: Camshafts..
Its old mineral spirits. Kinda dirty Its filtered but I think i'll just use some out a bottle.
John
Old 02-10-2012, 11:27 PM   #136
FrankieD
FrankieD's Avatar
Re: Camshafts..
Gary
been doing it for 40 + years feel is the same because nothing is pumped up never had a problem.
Old 02-10-2012, 11:32 PM   #137
oldblue1968chevy
Re: Camshafts..
yay or nay on soaking lifters lol
i didnt soak my comp lifters (same thing)
John
Old 02-11-2012, 12:47 PM   #138
GASoline71
GASoline71's Avatar
Re: Camshafts..
No need to soak lifters. and I'm bettin' most of the cats here that build lots of engines don't either.
Gary
Old 02-13-2012, 10:05 PM   #139
oldblue1968chevy
Re: Camshafts..
Should I bump the engine around to TDC before I take it apart or what? hopefully ima start in the AM soon as I clear a spot in the garage!
John
Old 02-13-2012, 10:59 PM   #140
68Stepbed
68Stepbed's Avatar
Re: Camshafts..
Yes, put it at TDC. It makes reassembly much easier.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 02-13-2012, 11:19 PM   #141
oldblue1968chevy
Re: Camshafts..
TDC compression stroke right
John
Old 02-13-2012, 11:24 PM   #142
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Camshafts..
You mean to tell me this thing is not running yet??????????? LOL
prostreetC-10 is offline   Reply With Quote
Old 02-13-2012, 11:37 PM   #143
oldblue1968chevy
Re: Camshafts..
One more thing
Im leaking oil from my drain bolt
I'll have it in/out alot in the next few days. Can I seal it up by putting something like teflon tape on the threads?
John
Old 02-13-2012, 11:38 PM   #144
oldblue1968chevy
Re: Camshafts..
No its not even torn down yet LOL
I borrowed the puller tonite. Hopefully I'll start tom. soon as I build a fire and clear a spot in the garage out
John
Old 02-14-2012, 12:58 AM   #145
Captainfab
60-66 Nut
Re: Camshafts..
It sounds to me like you need a new gasket on your drain plug.
Old 02-14-2012, 02:02 AM   #146
litew8
litew8's Avatar
Re: Camshafts..
What Captain said. You're suppose to change the drain plug gasket at every oil change (so they say). Thought you were looking for a new pan anyway? If the threads are stripped, don't know what to tell you - other than I think someone makes a repair kit for it.
Old 02-14-2012, 10:33 AM   #147
oldblue1968chevy
Re: Camshafts..
Its a copper crush washer right?
I have a few around I"ll try that and something on the threads
threads are fine not stipped.
John
Old 02-14-2012, 11:25 AM   #148
litew8
litew8's Avatar
Re: Camshafts..
oops, no. I was referring to the nylon kind.
Old 02-14-2012, 04:06 PM   #149
oldblue1968chevy
Re: Camshafts..
Ok 1 more.
My crank sprocket has 3 positions. With the dot @ 12 O clock (crank sprocket) the keyway is @ 2 O clock.
My motor has always ran @ 30* or so with no vac adv and its always puzzled me
Is something wrong here?
Thanks pix soon
John
Old 02-14-2012, 04:11 PM   #150
oldblue1968chevy
Re: Camshafts..
Calling comp now I guess
LMK what i need to do
ps how do i get the lifters out lol there flat with engine lol magnet no worky (sall one)
John
