Frame mounted brake booster vs exhaust clearance
Anyone have some good under vehicle pics or cab off pics of exhaust clearance with a frame mounted brake booster (1950) and motor and auto Trans mounted??
Wanting to go this route but before I order the parts I want to make sure I don't have to run the exhaust low or routed in a awkward manner. Or is this normally even an issue? Thanks Blake Posted via Mobile Device |
Re: Frame mounted brake booster vs exhaust clearance
It was an issue on my 59 truck. I have a 3" exhaust and turbo 400 with a two stage booster. Things got close on the drivers side, but I would still recommend the frame mount booster. Just keep in mind that you must clear speedometer cable, booster and shift lever when fabricating exhaust. And I ran the exhaust over the trans crossmember. I did notch crossmember as it was 2" square tubing. No pics. Sorry.
This solves the issue.
1950 3600. 370cid, th400, 9", billet 80mm turbo under the bed, 4 link coilovers, hoping for a single digit! http://67-72chevytrucks.com/vboard/s...d.php?t=380212 |
i have 1000's of pics of my truck, none of the exhaust or under the truck after assembly.
the lowest thing on a 47 to 59 truck is the bottom of the doors and steps, on my 58 the door is 5-6'' lower than the frame. it makes it a pain in the butt to get on a hoist, but easy to run an exhaust to the rear axle. my exhaust is 3-4'' below my frame, every frame mounted booster is frame mounted i can't imagine any clearance issue with an exhaust system. i can't imagine any need for a 3'' exhaust system either. ![]()
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
[i can't imagine any need for a 3'' exhaust system either.QUOTE][/QUOTE] LOL, 3" exhaust as in "Corvette"
Hey Blake. Do you make the street rod show there in Springfield held in May? That show is one of our favorites. |
Here is what I have for photos from the engine to the mufflers. I used stock rams horn exhaust, under frame brake booster and MC, auto trans and transfer case, keeping the original crossmember and modified stock trans/transfer crossmember. The original muffler guy did a good job of keeping everything up high so there was less to scrape off with rocks and logs. It is 4wd so I had a little more room to work with, but good muffler guys can do amazing work.
![]() Join Date: Dec 2011
Here was my fix, I sure hated to do it this way but better then the exhaust heating up my wiring harness and booster... But it works and have no worries now
1952 suburban
I don't know what you think about them, but Sanderson headers that route through the inner fenders would fix the problem.
