Old 03-09-2012, 02:10 PM   #1
white 67
turn signal switch wireing
Today i started to replace the turn signal switch on my 67, but the plug on the truck has 8 pins and my new one has 9. Is there any way to make the new one work ?
white 67 is offline   Reply With Quote
Old 03-09-2012, 02:53 PM   #2
burnout2614
burnout2614's Avatar
Re: turn signal switch wireing
See if the wires match up. The number of cavities in the connectors usually don't matter as long as the wires match. If the connectors won't plug together then you have a problem. peace
"There's something women like about a pickup man!" Joe Diffie
burnout2614 is offline   Reply With Quote
Old 03-09-2012, 04:41 PM   #3
Wrenchbender Ret
There is an adapter made for this but you can cut the wires off the old switch about 2 in. from the connector & cut the new switch & splice the wires. It is best to solder them & use heat shrink tubeing but you can use but connecters.
Wrenchbender Ret is offline   Reply With Quote
