Old 03-13-2012, 07:23 PM   #26
cb1965
cb1965's Avatar
Re: I hate some previous owner because.....
very poor maintenance,
i assume my brakes are the original ones. drums are still rivited... is that possible?????
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline   Reply With Quote
Old 03-13-2012, 07:38 PM   #27
chadh100
chadh100 is offline   Reply With Quote
Old 03-13-2012, 07:53 PM   #28
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
.... we all have it....
Stupid foam, or tar, or caulking dumped in the cab corners so moisture will never dry out, and to ensure the cab corners become completely shot.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 03-13-2012, 08:37 PM   #29
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I just happened by accident, to come up with a new version of POS.
Previous
Owners
Syndrome
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-13-2012, 09:00 PM   #30
joedoh
joedoh's Avatar
I cant stand the rattle can.
Old 03-13-2012, 09:04 PM   #31
likaroc13
Rollin' Old Skool
won't say i hate, but i extremely dislike
1) cut original radio hole bigger to fit newer radio (not bad tho)
2) poorly filled the holes in the bed for factory back-up lights, so when the light hits it right you see the outline
3) holes cut into dash for 2 aftermarket gauges
4) used Gorilla Glue to reattach the cab/door weatherstripping on the passenger side
that's all i know of for now, which is relatively minor compared to some others
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 03-13-2012, 09:19 PM   #32
rideblue00
rideblue00's Avatar
lol! both of mine had that
rideblue00 is offline   Reply With Quote
Old 03-14-2012, 01:25 AM   #33
argonaut
argonaut's Avatar
Lets see. The PO of my K10 but about a million holes in the dash for toggle switches. He must've thought it was an airplane... He also pulled the transfer case and put in a tandem axle with carrier bearing. The carrier bearing was held up with ropes and hangar wires...
That's all I can think of right now. But I know I've cursed them many other times!
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 03-14-2012, 01:42 AM   #34
raylube
raylube's Avatar
Originally Posted by k98al View Post
po had apparently had a huge camper on my '62...drill all kinds of holes in the cab and roof. I like this big one, though.....
Put lots of dents in odd places, and the rust is unbelievable! I went to wichita to get this truck, i can't believe how much more rust a truck up there has than an oklahoma truck!
Po also rigged some "helper" leaf springs on the back, not quite as nice as the factory ones.
I have that same hole in the lh side of my cab. The prior owner said it was for a spotlight, the same thing but the spotlight is missing, i bought my truck from the original owner grandson at it was a massey furgeson shop truck.
raylube is offline   Reply With Quote
Old 03-14-2012, 05:05 AM   #35
kevinc
kevinc's Avatar
My PO put a floor shifter in for a manual trans which is fine, but he put it in the wrong place, so instead of patching it and trying again he just elongated it. So there's a hole about 6" wide by 18" long in the trans tunnel. Guess he was WAY off.
Going thru all the trouble to have the truck sand blasted, perfectly block sanded and painted laser straight, but skimp on the metal prep just to have the paint crack on the left side of the bed and right front fender.
Doing actually a great job fiberglass patching the floor by the rocker panels. It's actually un-noticable when you see it from the top or bottom. He went thru all the trouble and could have welded instead.
He sold every single part off the truck for some unknown reason so it was just a shell leftover.
1988 C1500 Regular Cab, Long Bed, 2WD.
kevinc is offline   Reply With Quote
Old 03-14-2012, 06:46 AM   #36
Turkey
Turkey's Avatar
for using JB Weld on the tailgate trunion bolts. Thanks jerk.
Turkey is offline   Reply With Quote
Old 03-14-2012, 08:16 AM   #37
Rich 5150 69
Rich 5150 69's Avatar
they had used spray adhesive on the entire floor pan and kick panels for home carpeting foam, what a bit## to remove..
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 03-14-2012, 09:16 AM   #38
willyp
willyp's Avatar
thanks for:
cutting the dash to install a POS radio
using a wood 2X4 to mount the floor shifter
using a foil gum wrapper around a blown fuse instead of changing the fuse
using wire nuts in the engine bay and under the dash on wires
breaking 10 of the 24 wheel studs off
shimming the drivers side window with toothpicks
not installing a cotter pin the the brake pedal clevis
stripping out 2 of the 3 bolts for mounting the steering wheel
using a cereal box for a gasket
buying the cheapest tires ever.... i had a blowout on the way home
fabricating some sweet rear swing perches
lowering the front end by "stepping" the lower control arms
i know there is more i cant remember, i wish i took more pics!
The price of cool aint cheap.
willyp is offline   Reply With Quote
Old 03-14-2012, 09:22 AM   #39
ctandc
From the multiple project cars over the years.
How about a 350 that had one valve cover where EVERY BOLT was broken off in the head. So what did the guy do? He used some kind of EPOXY to seal the valve cover to the head. And it still seeped.
Or another small block with a pretty normal intake oil leak. Did he pull the intake and replace the gasket? Of course not. He took RTV and forced it into the gap. Of course that stuff was all through the engine.
How about a PO cutting the exhaust off close to where it connects to the manifold. Then using something that looked to be a combination of duct tape and jb weld to try and put it back together?
Mismatch length shocks on the front of a car. (yes I’m serious).
How about a PO cutting the fuse box out of a Chevelle. I said CUTTING. The entire bundle of wires where it exited the fuse box. Then “reinstalling” by simply twisting the cut wires together and taping them with electrical tape. And this was in a car that the guy had paid a body shop to totally strip, replace rusted sheetmetal and do the body work. I know the shop, he paid GOOD money for this. Then what did he do? He RATTLE CANNED the paint job on.
____________________________
ctandc is offline   Reply With Quote
Old 03-14-2012, 12:55 PM   #40
K98AL
K98AL's Avatar
Kevinc - how did they skimp on metal prep? I'm new to painting, and am sanding, primering, etc...more than I have ever done. Have I missed something?????
K98AL is offline   Reply With Quote
Old 03-14-2012, 01:21 PM   #41
losthope
losthope's Avatar
Originally Posted by willyp View Post
The stepped arms look crazy scary that looks like a really big step and just flat stock with no gussets? Just wondering if you saw the stepped arms and spring perches when you acquired the truck?
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 03-14-2012, 02:27 PM   #42
Apache63
1# Drobmember in Germany
Apache63's Avatar
Custom made Upper Shock mount on my 63´Suburban!!
Pat
Apache63 is offline   Reply With Quote
Old 03-14-2012, 03:11 PM   #43
kevinc
kevinc's Avatar
I'm not a body man either which is why I bought the truck I did since the body work looked done. I knew about the floorboards with some rust by the rocker panels and the hole in the floor. There are some cracks in the paint on the front fender and left rear bed side. I don't know what causes it other than there is some rust forming under the paint, or there was some contamination on the sheetmetal before the paint was applied. Really ticks me off. There doesn't seem to be any dents that were fileld in with bondo, so I don't think that's the problem. After stripping the inside of the fenders I found where they pushed bondo thru a couple small holes at the bottom. So it looks like my truck may fall apart in a few years and will need to be redone at that time. I guess I'll be learning how to do bodywork.
Kevin C
Old 03-14-2012, 04:09 PM   #44
LostMy65
LostMy65's Avatar
Kinda makes you wonder what the new owner of the truck you created and sold is going to say! LOL
I got to hear some of that when I bought back my 65. The fella asked if I was the idiot who cut the gigantic hole in the firewall and then threw some sheetmetal over the hole. Nope! wasn't me. Fortunately I have a donor cab to fix it.
The other thing was my 65 was now on a 62 frame. That was me. . However, I was like 19 and a friend had a 62, and the price was right. I wrecked my 65 longbed, and built a Short Stepside with what I could find before there was the internet.
Old 03-14-2012, 05:16 PM   #45
64fleetside
Lostmy65, my buddy just filled the cab corners on his 51 w/Great Stuff last week & was tellin me how quiet it is now.
64fleetside is offline   Reply With Quote
Old 03-14-2012, 05:19 PM   #46
64fleetside
I had one 76 C10 yrs ago-350 engine smoked like crazy-all the ring gaps were lined up perfectly, skirts were off 3 pistons(and not in the pan), had a big valve head on one side, small valves on the other.
Old 03-14-2012, 05:55 PM   #47
FetchMeAPepsi
FetchMeAPepsi's Avatar
because....
They hacked up the wiring to install some stupid toggle blinker.
Just buy the right part. It'd been a lot less work.
Oh, and they threw away the emergency flasher and installed this stupid toggle in the hole where it says 'Pull'
This +1
Too many "Get-R-Done" mechanics out there. Quick with a saw and slow with a thought.
FetchMeAPepsi is offline   Reply With Quote
Old 03-14-2012, 10:25 PM   #48
awbrown
I totally missed the step the first time ..duh
awbrown is offline   Reply With Quote
Old 03-14-2012, 11:43 PM   #49
sigshooter
sigshooter's Avatar
Reading all of this makes me appreciate my one owner unmolested truck even more. The PO bought it new, drove it for about ten years and then parked it. Everything was siezed up pretty solid but was original paint, and unmolested...... Wait, He did install those hideous dual saddle tanks and cut holes in the side of the bed for the doors. That is about all I can gripe about.
1965 long bed ( grandpas old truck )
1964 long bed BBW Custom Cab
1966 Short stepside
1964 long bed
1965 long bed Custom Cab, factory air, V-8, powerglide
sigshooter is offline   Reply With Quote
Old 03-15-2012, 12:51 AM   #50
LostMy65
LostMy65's Avatar
If the proper prep is done on the metal, then painted with epoxy; good.
But that's not what these numbskulls do. They squirt it in there between dirty unprep'd metal cavities, and now moisture is held up against the unprotected metal. I've even read in these forums of guys saying they use the stuff that doesn't absorb moisture. But that still doesn't work. I pulled that great dry foam stuff out of my cab corners. The foam stuff was nice and dry inside, and still holding moisture from condensation against the metal.
