#26 |
Re: I hate some previous owner because.....
very poor maintenance,
i assume my brakes are the original ones. drums are still rivited... is that possible?????
'66 chevy lwb c10 '65 chevy lwb c20 |
#27 |
#28 |
But Found Her 25yrs Later!
.... we all have it....
Stupid foam, or tar, or caulking dumped in the cab corners so moisture will never dry out, and to ensure the cab corners become completely shot. Posted via Mobile Device
#29 |
Never Ending Projects
I just happened by accident, to come up with a new version of POS.
Previous Owners Syndrome
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#30 |
![]() Join Date: May 2007
I cant stand the rattle can.
#31 |
Rollin' Old Skool
won't say i hate, but i extremely dislike
1) cut original radio hole bigger to fit newer radio (not bad tho) 2) poorly filled the holes in the bed for factory back-up lights, so when the light hits it right you see the outline 3) holes cut into dash for 2 aftermarket gauges 4) used Gorilla Glue to reattach the cab/door weatherstripping on the passenger side that's all i know of for now, which is relatively minor compared to some others
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#32 |
#33 |
![]() Join Date: Aug 2008
Lets see. The PO of my K10 but about a million holes in the dash for toggle switches. He must've thought it was an airplane... He also pulled the transfer case and put in a tandem axle with carrier bearing. The carrier bearing was held up with ropes and hangar wires...
That's all I can think of right now. But I know I've cursed them many other times!
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
#34 | |
![]() Join Date: Jan 2012
#35 |
My PO put a floor shifter in for a manual trans which is fine, but he put it in the wrong place, so instead of patching it and trying again he just elongated it. So there's a hole about 6" wide by 18" long in the trans tunnel. Guess he was WAY off.
Going thru all the trouble to have the truck sand blasted, perfectly block sanded and painted laser straight, but skimp on the metal prep just to have the paint crack on the left side of the bed and right front fender. Doing actually a great job fiberglass patching the floor by the rocker panels. It's actually un-noticable when you see it from the top or bottom. He went thru all the trouble and could have welded instead. He sold every single part off the truck for some unknown reason so it was just a shell leftover.
1988 C1500 Regular Cab, Long Bed, 2WD. |
#36 |
for using JB Weld on the tailgate trunion bolts. Thanks jerk.
![]() Last edited by leddzepp; 03-14-2012 at 06:56 PM. |
#37 |
they had used spray adhesive on the entire floor pan and kick panels for home carpeting foam, what a bit## to remove..
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#38 |
thanks for:
cutting the dash to install a POS radio using a wood 2X4 to mount the floor shifter using a foil gum wrapper around a blown fuse instead of changing the fuse using wire nuts in the engine bay and under the dash on wires breaking 10 of the 24 wheel studs off shimming the drivers side window with toothpicks not installing a cotter pin the the brake pedal clevis stripping out 2 of the 3 bolts for mounting the steering wheel using a cereal box for a gasket buying the cheapest tires ever.... i had a blowout on the way home fabricating some sweet rear swing perches lowering the front end by "stepping" the lower control arms i know there is more i cant remember, i wish i took more pics! ![]() ![]()
The price of cool aint cheap. Last edited by willyp; 03-14-2012 at 09:29 AM. Reason: redneck spellcheck |
#39 |
From the multiple project cars over the years.
How about a 350 that had one valve cover where EVERY BOLT was broken off in the head. So what did the guy do? He used some kind of EPOXY to seal the valve cover to the head. And it still seeped. Or another small block with a pretty normal intake oil leak. Did he pull the intake and replace the gasket? Of course not. He took RTV and forced it into the gap. Of course that stuff was all through the engine. How about a PO cutting the exhaust off close to where it connects to the manifold. Then using something that looked to be a combination of duct tape and jb weld to try and put it back together? Mismatch length shocks on the front of a car. (yes I’m serious). How about a PO cutting the fuse box out of a Chevelle. I said CUTTING. The entire bundle of wires where it exited the fuse box. Then “reinstalling” by simply twisting the cut wires together and taping them with electrical tape. And this was in a car that the guy had paid a body shop to totally strip, replace rusted sheetmetal and do the body work. I know the shop, he paid GOOD money for this. Then what did he do? He RATTLE CANNED the paint job on.
____________________________ |
#40 |
Kevinc - how did they skimp on metal prep? I'm new to painting, and am sanding, primering, etc...more than I have ever done. Have I missed something?????
#41 |
The stepped arms look crazy scary that looks like a really big step and just flat stock with no gussets? Just wondering if you saw the stepped arms and spring perches when you acquired the truck?
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
#42 |
1# Drobmember in Germany
Custom made Upper Shock mount on my 63´Suburban!!
Pat |
#43 | |
Kevin C ![]()
#44 | |
The other thing was my 65 was now on a 62 frame. That was me. ![]() ![]() Posted via Mobile Device
#45 |
Lostmy65, my buddy just filled the cab corners on his 51 w/Great Stuff last week & was tellin me how quiet it is now.
#46 |
I had one 76 C10 yrs ago-350 engine smoked like crazy-all the ring gaps were lined up perfectly, skirts were off 3 pistons(and not in the pan), had a big valve head on one side, small valves on the other.
#47 | |
![]() Too many "Get-R-Done" mechanics out there. Quick with a saw and slow with a thought. |
#48 |
I totally missed the step the first time ..duh
#49 |
Reading all of this makes me appreciate my one owner unmolested truck even more. The PO bought it new, drove it for about ten years and then parked it. Everything was siezed up pretty solid but was original paint, and unmolested...... Wait, He did install those hideous dual saddle tanks and cut holes in the side of the bed for the doors. That is about all I can gripe about.
1965 long bed ( grandpas old truck ) 1964 long bed BBW Custom Cab 1966 Short stepside 1964 long bed 1965 long bed Custom Cab, factory air, V-8, powerglide |
#50 | |
But that's not what these numbskulls do. They squirt it in there between dirty unprep'd metal cavities, and now moisture is held up against the unprotected metal. I've even read in these forums of guys saying they use the stuff that doesn't absorb moisture. But that still doesn't work. I pulled that great dry foam stuff out of my cab corners. The foam stuff was nice and dry inside, and still holding moisture from condensation against the metal.
