Old 03-15-2012, 03:45 AM   #51
chadh100
Re: I hate some previous owner because.....
pulled out my carpet today to find that my truck probably used to have a manual transmision,, i wish it still was. and to seal off the hole the PO just screwed some ugly looking patch sideways over it. thanks for nuthin
also left some other random hole open above the pedals... anyone know what this could've originally been for....?
chadh100 is offline   Reply With Quote
Old 03-15-2012, 03:54 AM   #52
willyp
willyp's Avatar
Originally Posted by losthope View Post
The stepped arms look crazy scary that looks like a really big step and just flat stock with no gussets? Just wondering if you saw the stepped arms and spring perches when you acquired the truck?
of coarse, however it helped my cause to lower the price and i replaced them for less than $100 form the junk yard. = WIN!
The price of cool aint cheap.
willyp is offline   Reply With Quote
Old 03-15-2012, 08:23 AM   #53
Summabish
One my '66....
- Replaced front lower hood panel(great), cut out all brackets for mounting turn signals and hood latch....
- Screwed in cab corners with one screw instead of cutting out old and replacing with new.
- Cut the wiring for the headlights, had to rewire.
- Upgraded to power brakes/5 lug(great), horrible/****ty welds in which I will be fixing soon.
I'm sure I'll find more....
Summabish is offline   Reply With Quote
Old 03-15-2012, 09:50 AM   #54
64fleetside
Originally Posted by LostMy65 View Post
If the proper prep is done on the metal, then painted with epoxy; good.
But that's not what these numbskulls do. They squirt it in there between dirty unprep'd metal cavities, and now moisture is held up against the unprotected metal. I've even read in these forums of guys saying they use the stuff that doesn't absorb moisture. But that still doesn't work. I pulled that great dry foam stuff out of my cab corners. The foam stuff was nice and dry inside, and still holding moisture from condensation against the metal.
I think my buddy blew it out w/an air hose, that's about it. Squirt it in... Rust is already there, and he lives on a gravel road. Poor 51. I saw a 64-5-6 in a salvage yard, the roof had been filled w/great stuff-it almost looked like an acid in the product actually started the corrosion. Rust/corrosion was crazy.
The PO of my '64 went the fiberglass route in the kick panel/floor corner, after buffing the rust w/wire brush on a drill-the glass peeled right off like a orange peel. He also fiberglassed the bed stake holes up. Truck had a camper so there were many holes drilled around the stake holes. I welded it all up.
64fleetside is offline   Reply With Quote
Old 03-16-2012, 03:28 AM   #55
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I think that's for the clutch linkage.
No, wait. maybe not.
The hole above the e-cable I think is for the clutch.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 03-16-2012, 08:12 AM   #56
Rich 5150 69
Rich 5150 69's Avatar
Yes, it`s for the rod going down to th e Z-bar.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 03-16-2012, 05:01 PM   #57
406 Q-ship
406 Q-ship's Avatar
Originally Posted by ctandc View Post
From the multiple project cars over the years.
How about a 350 that had one valve cover where EVERY BOLT was broken off in the head. So what did the guy do? He used some kind of EPOXY to seal the valve cover to the head. And it still seeped.
Or another small block with a pretty normal intake oil leak. Did he pull the intake and replace the gasket? Of course not. He took RTV and forced it into the gap. Of course that stuff was all through the engine.
How about a PO cutting the exhaust off close to where it connects to the manifold. Then using something that looked to be a combination of duct tape and jb weld to try and put it back together?
Mismatch length shocks on the front of a car. (yes I’m serious).
How about a PO cutting the fuse box out of a Chevelle. I said CUTTING. The entire bundle of wires where it exited the fuse box. Then “reinstalling” by simply twisting the cut wires together and taping them with electrical tape. And this was in a car that the guy had paid a body shop to totally strip, replace rusted sheetmetal and do the body work. I know the shop, he paid GOOD money for this. Then what did he do? He RATTLE CANNED the paint job on.
That sounds like a tweeker.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 03-17-2012, 02:23 PM   #58
purzell
purzell's Avatar
Repaired EVERYTHING with electrical tape...including the leaking fuel line
purzell is offline   Reply With Quote
Old 03-17-2012, 09:55 PM   #59
dodgiesdad
dodgiesdad's Avatar
Wiring, my PO had used 12/2 house wiring for the rear lights !@#$
dodgiesdad is offline   Reply With Quote
Old 03-17-2012, 11:03 PM   #60
bama63
bama63's Avatar
hacked out dash for radio, rt motor mount gone and secured with a piece of chain,hacked out center cross member when po swapped to a v8 th350, under hood toggle switch attached to the alternator, 3 different sets of side mirror holes. and must of had at least 10 different bed caps or camper tops by the looks of all the holes in the top bed rails
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 07-01-2012, 02:46 AM   #61
LostMy65
LostMy65's Avatar
As most of us know; the V-8 Motor Mount Perches are a tad tall for the 60-62 'X-Frame'.
Some previous owner solved this issue with cutting the bottom of the perch off.
Old 07-01-2012, 01:25 PM   #62
corvettejim1968
corvettejim1968's Avatar
holes holes holes. i have 28 holes on the outside and a few more on the inside. some from the big mirrors some from the hooks on the sides of the bed and the ones the bug me most are the large ones to mount the tool box to the side rails.
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 08-01-2012, 10:41 PM   #63
LostMy65
LostMy65's Avatar
It's like rivets, tin, and bondo are the next best thing to sliced bread.
Some previous owner riveted tin to the inside of the stepside fender.
Then some future owner (or maybe the same person) put another layer of tin over the previous layer.
There was actually three layers of riveted tin holding who knows how many years of dirt.
Argh!
Old 08-02-2012, 07:28 AM   #64
farmtrucks
farmtrucks's Avatar
Mine was original red/white top, bbw,all the chrome.... Some DUMB S painted it blue inside and out, stripped the chrome... and tried his first time welding skills at filling in the holes....
farmtrucks is offline   Reply With Quote
Old 08-11-2012, 08:02 PM   #65
64thunder
po used two unequal diameter exhaust pipes welded to a t under the transsmission with nothing but spatter for a bead hooked a line from the vacumn on the hei to the brake cylinder wtf but a piece of aluminum foil over the crappy gaskets on the manifolds installed the spark plugs 125643 order on the 230 zip tied the fender to the frame moved the horn to under the dash and rattle can primer over all of the chrome trim, bed wood and turn lights
64thunder is offline   Reply With Quote
Old 08-12-2012, 02:43 PM   #66
CaptainAmerica
CaptainAmerica's Avatar
P/O tried on like 3 or 4 sets of dorky Dumbo mirrors before he settled on something that looked like they came off a Peterbuilt, and left 7 million holes in the doors. Also, cut a huge gas filler hole for an auxillary fuel tank mounted in the bed.
Seems to be the common thing on this thread; HOLES.
CaptainAmerica is offline   Reply With Quote
Old 08-12-2012, 03:36 PM   #67
TopFuel1966
TopFuel1966's Avatar
[QUOTE
Put lots of dents in odd places, and the rust is unbelievable! I went to Wichita to get this truck, I can't believe how much more rust a truck up there has than an Oklahoma truck![/QUOTE]
I didn't think that was possible after getting my POS out of Oklahoma.....
TopFuel1966 is offline   Reply With Quote
Old 08-12-2012, 04:24 PM   #68
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
.........they cut out an otherwise perfect dash for a DIN radio, as well as the doors for speakers.....
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 08-12-2012, 05:00 PM   #69
Rich 5150 69
Same here John except it was for a real cheap radio...I cleaned up the radio area with a dremel, put in a cd player years back, got some old rusted out doors for my patch panels, one day I`ll get a pic of the inside of the door show you guys what one does with a torch so he can get the windows out. HE SHOULD HAVE BEEN LINED UP AND......OH sorry no violent actions here....
Old 08-12-2012, 08:24 PM   #70
Bomp
Bomp's Avatar
My truck was used to push other trucks around with no oil in the motor by a 19yr old. He was real energetic about it too. My '69 Camaro on the other hand had romex house wire under the hood which promptly melted when it touched the header. Started small fire, ruined battery, wire harness, and started a wild goose chase until I finally lost the car in a divorce.
Bomp is offline   Reply With Quote
Old 08-12-2012, 08:49 PM   #71
1972RedNeck
1972RedNeck's Avatar
Originally Posted by maxwoof View Post
For throwing out the parking brake hardware from my 12 inch drum brakes.
That's the first thing I do when I pull the drums off for the first time. Somebody else gets to hate me for that now.
When I was 11 I learned that electrical tape and gasoline don't mix. The sticky part turns to slime.
Wire nuts should be illegal to use on trucks. I hate when they ran out of electrical tape and used masking tape, which is now a white powder.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 08-12-2012, 09:49 PM   #72
Leadfoot Lambert
Leadfoot Lambert's Avatar
You guys with the small holes cut in your tranny tunnel have nothing to complain about, here's mine!
Here's what I cut out to repair it
Here's what it looks like now, I still have holes to patch!
65 Chevy short fleet 350 5 speed, soon to be LSX powered
65 F100 short fleet
91 Heritage softail
94 Fatboy
11 Softail Deluxe [wife's bike]
13 Streetglide
http://www.youtube.com/watch?v=yMFMw...eature=mh_lolz
Leadfoot Lambert is offline   Reply With Quote
Old 08-30-2012, 03:58 PM   #73
dougf
dougf's Avatar
I love this thread! Tonight I am posting why I hate the previous owner of my truck... I have a few good ones
dougf is offline   Reply With Quote
Old 08-30-2012, 06:27 PM   #74
donthekawguy
donthekawguy's Avatar
The wiring in my 66 is all messed up. The PO installed a cut off switch like you see on the rear of sub 9 second drag cars. See pic. Then he put in a toggle switch on the dash that turns on the ignition. See pic. So the starting procedure goes as follows- lift the hood turn the big switch, close hood get inside flip the small switch on the dash, turn key to start. Nice!
66 shorty
donthekawguy is offline   Reply With Quote
Old 08-30-2012, 07:13 PM   #75
LostMy65
LostMy65's Avatar
^Very Nice.
Be sure to post a step by step on how one might do that same wiring tip. ;-p
