Stock radiator in my swb 4x4? Is this ok?
So I'm building my truck. It's a 1972 k10 swb 4x4. It's got a stock rebuilt 98 vortec 350 and a sm465. I need to get a radiator. Would it be ok to put a stock one in it? 1 ton maby? Any info? This is a 50/50 on road off road truck. Thanks for all your help. Posted via Mobile Device
1972 k/10 4x4 swb 2011 camaro SS/RS M6 |
Re: Stock radiator in my swb 4x4? Is this ok?
Btw it will have electric fans
What engine was in there before? If it had a V8, I would think you will be fine.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
350
Yes the stock radiator will be just fine.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
20' Daredevil (Ret)
![]() Join Date: May 2003
While a stock one will do the job, if you're buying a new one anyway, it doesn't cost much to upgrade to a 4-row.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
My '71 SWB K/10 w/307 had the HD radiator option. That's a stock radiator that's better than anything made today. These trucks were built great. That's why they are so popular these days...not just good looking. They have out lasted all other makes from just being what they are. What came in it would be just fine. But I agree with Stocker. Since you don't have one I'd go for the 4-row.
What?
I just put in a new all metal 4 row into my 350/4speed 1970 K10 just because I could, and it replaced a 3 row that was just old and getting ready to fail.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
You can get too big of a radiator unless you live in Death Valley or something. I once put a 4 core in a vehicle and it was too big. It took forever to warm up. Stock should be fine. If it's an EFI engine with a computer it will probably want to run about 210. Carbed engines liked about 180 degrees.
What?
110 degree summers, low gears, running 3500 RPM consistently on the highway, stop and go traffic, 180 easily obtained just in the morning warm up. Yea, I'm cool with a good 4 row radiator.
![]() I believe if you have the proper thermostat, a good clutch fan along with the right fan shroud. Getting to operating temp is easy, no matter if you run a light or heavy duty radiator.
I think the 4 core I had was in a 67 Camaro 350 street car built to the moon. I run electric only fans all day long with a stock 83 radiator and run at 180.
| Bookmarks |
